  3. Calculation of time interval
5 Posts 2 Posters 1.8k Views 2 Watching
  • benyaB
    benyaB
    benya
    I am trying to calculate time interval by calling millis() function in loop().
    Looks like returned values are affected by smartSleep(). I mean time doesn't grow much during sleep.
    Is there a more reliable way to detect timeout?
    AWIA 1 Reply Last reply
    • benyaB benya
      AWIA
      AWIA
      AWI
      @benya the 'sleep' function causes the millis() timer to stop. Using an external clock (rtc) would be the best solution for low power operation. If you know how long you sleep you can do some calculations in the loop. Smartsleep() is not very predictable in this case ;)
      benyaB 1 Reply Last reply
      • AWIA AWI
        benyaB
        benyaB
        benya
        @AWI If there is no RTC, should I opt to use requestTime() and receiveTime()?
        • benyaB benya
          AWIA
          AWIA
          AWI
          @benya That would be a solution just be aware that you need to wail for reception of the time information.
          • AWIA AWI
            benyaB
            benyaB
            benya
            wrote on last edited by benya
            @AWI If node requests time and values before going to sleep, it will receive them upon return from smartSleep?
              requestTime();
              request(1, V_STATUS);
              request(2, V_STATUS);
              smartSleep(200);
            void receiveTime(unsigned long ts)
