Pressure sensor - arduino low memory (SOLVED)
@hek: great, but not completely correct...
It should be: if (minuteCount == 180)
Could you also consider to update the sketch with my proposal in my other comment for the pressuresensor-sketch regarding changing
float pressure = bmp.readPressure()/100;to
float pressure = bmp.readSealevelPressure(205)/100; // 205 meters above sealevelI assume most people would like to have the same pressure values as the local wheather station or airport has.
Still this code is working?
