  3. Pressure sensor - arduino low memory (SOLVED)
pressure
25 Posts 7 Posters 17.8k Views 2 Watching
  • N
    N
    niccodemi
    I tried IDE 1.0.5 and codebender with same results - sensor stops responding after 3-4 hours. Is anyone running this sensor successfully?
    Upon searching for arduino board with more SRAM I found arduino micro. It has 2.5 KB SRAM (0.5 KB more than Nano). Would it work with Mysensors?
      You could try with some other Arduino library for the pressure sensor perhaps.
      N 1 Reply Last reply
        N
        N
        niccodemi
        @hek sure, I can try. Do you have anything specific in mind?
          Did a quick google but I couldn't find anything good.
          How do you power your pressure sensor? It could be the radio that hangs after a potential power-spike.
          • m26872M
            m26872M
            m26872
            Why not start with a more simple sketch?
            #include <Adafruit_BMP085.h>
                #define BARO_CHILD 0
                #define TEMP_CHILD 1
                unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in seconds)
                Adafruit_BMP085 bmp = Adafruit_BMP085();      // Digital Pressure Sensor
                float lastPressure = -1;
                float lastTemp = -1;
                boolean metric;
                  gw.begin();
                  gw.sendSketchInfo("Pressure Sensor", "1.0");
                  if (!bmp.begin()) {
                    Serial.println("Could not find a valid BMP085 sensor, check wiring!");
                    while (1) { }
                  // Register sensors to gw (they will be created as child devices)
                  gw.present(BARO_CHILD, S_BARO);
                  gw.present(TEMP_CHILD, S_TEMP);
                  metric =  gw.getConfig().isMetric;
                  float pressure = bmp.readPressure()/100;
                  float temperature = bmp.readTemperature();
                  if (!metric) {
                    // Convert to fahrenheit
                    temperature = temperature * 9.0 / 5.0 + 32.0;
                //  int forecast = sample(pressure);
                  Serial.print("Temperature = ");
                  Serial.print(temperature);
                  Serial.println(metric?" *C":" *F");
                  Serial.print("Pressure = ");
                  Serial.print(pressure);
                  Serial.println(" Pa");
                  if (temperature != lastTemp) {
                    gw.send(tempMsg.set(temperature,1));
                    lastTemp = temperature;
                  if (pressure != lastPressure) {
                    gw.send(pressureMsg.set(pressure, 0));
                    lastPressure = pressure;
                  gw.sleep(SLEEP_TIME);
            • N
              N
              niccodemi
              pressure sensor and radio are powered off Nano. There is capacitor on radio vcc / gnd pins. I will try simple sketch and report back.
                MagKas
                @niccodemi and @hek : unfortunately there is a bug in the sketch for the pressuresensor.
                I have to go now but I will look up how I fixed this and report here in the evening!
                  MagKas
                  wrote on last edited by MagKas
                  @niccodemi:
                  Here I am again.
                  The problem is in the sample() function. It saves the pressure every minute in the array pressureSamples[]. This one is declared for 180 values which means you can use pressureSamples[0] to pressureSamples[179]. Writing to pressureSamples[180] means you are writing outside the defined array and might be writing over some other stuff in your program.
                  In my case it resulted in radio messages which got status 'fail' all the time. First I thought it was a problem with the radio but after debugging I found the problem to be the sample() function. It always happened exactly 180 minutes after I restarted the Arduino...
                  You have to change the following lines of code:
                  if (minuteCount > 180)
                    minuteCount = 6;
                  into:
                  if (minuteCount == 180)
                    minuteCount = 5;
                  The problem with the original code was that it wrote a value to pressureSamples[180] before it restarted with 6 again (which should be 5 according to me).
                  When looking at the code I also found that the wrong samples seem to be used for the first 5 minutes. If minuteCount has reached the value of 5 it means that samples 0 to 4 has been filled. The code is using 1 to 5 in stead.
                  To fix this, change the code under if (minuteCount == 5) into:
                  pressureAvg[0] = ((pressureSamples[0] + pressureSamples[1]
                  		+ pressureSamples[2] + pressureSamples[3] + pressureSamples[4])
                  		/ 5);
                  To be clear: this bug is not something @hek introduced, he just used the code supplied by the link in the sample()-function.
                  Edit: But maybe he can make sure the sketch is updated so no one else will get the same problems? :)
                    Thanks @MagKas!
                    I've pushed an update to github.
                      MagKas
                      @hek: great, but not completely correct...
                      It should be: if (minuteCount == 180)
                      Could you also consider to update the sketch with my proposal in my other comment for the pressuresensor-sketch regarding changing
                      to
                      float pressure = bmp.readSealevelPressure(205)/100; // 205 meters above sealevel
                      I assume most people would like to have the same pressure values as the local wheather station or airport has.
                        wrote on last edited by hek
                        #23
                        @MagKas
                        Ok, done!
                        Also had to update to the latest library-version to get the readSealevelPressure()-function.
                        • N
                          N
                          niccodemi
                          thanks, pressure sensors works ok with updated code (7 hours now).
                          • nikitech0103N
                            nikitech0103N
                            nikitech0103
                            Still this code is working?
