  3. Nrf24l01 powering problem with LE33
7 Posts 3 Posters 2.1k Views 3 Watching
  • L
    L
    linkos
    Hello
    I'm bulding a node (a motion captor) with an atmega328p and a 5v source
    I want to use a LE33 for the VCC pin of the nrf24l01 but it's not working.
    the debug log tell me that the radio is ok but I've a TSM Failure error and I can't connect to my gateway.
    if i connect the VCC pin on the 3v out of a UNO card (that's the only thing a had for testing) its work like a charm.
    I think i've missed something but I don't understand the problem
    someone could help me a little bit?
    Best regards
    • L linkos
      Hello
      Best regards
      @linkos did you connect a capacitor close to the nrf?
      For power troubleshooting, see the flowchart at https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help
      • L
        L
        linkos
        I don't test with a capa because I was thinking it was not necessary because it was working with the 3v of the UNO.
        Thanks for the link. I'll try it tonight
        Best regards
        • dpressleD
          dpressleD
          dpressle
          What capacitor are you using?
          • L
            L
            linkos
            I'll try with a 4.7uf. But actually I've not allready try it. I'll test tonight after work
            • dpressleD
              dpressleD
              dpressle
              4.7 uF is not enough, you need at list 10uF.
              I had the same problem in my boards.
              • L
                L
                linkos
                Ok thanks for your answer
