  3. EEPROM wearing
EEPROM wearing
6 Posts 4 Posters 2.0k Views 5 Watching
  • N
    N
    napo7
    Hi there !
    I was about to use saveState function, but I first aked myself about the wearing of the EEPROM.
    It seems that the EEPROM has a life of about 100.000 writes.
    So, if I do 100 writes per day (4 state change every hour), it takes 1000 days to write 100k times : about 3 years and the EEPROM may start failing.
    Do anyone use a wear-leveling trick ?
    I've quickly searched for code over google, but hasn't tried anything yet.
    YveauxY 1 Reply Last reply
    • N napo7
      Hi there !
      YveauxY
      YveauxY
      @napo7 yup. I wrote an EEprom wear leveling library a while ago. Didn't publish it yet though...
      I'll have a look if I can have it go public.
      • scalzS
        scalzS
        wrote on last edited by scalz
        • you could use a circular buffer for this http://www.atmel.com/images/doc2526.pdf . I'm sure there are already libs for this.
        • when it's not enough, it's maybe better to use a better mem,
        • change strategy :)
        • N
          N
          napo7
          wrote on last edited by napo7
          Quick thought :
          At least, if the old value is the same as the new value, don't write it !
          I'm sure we can avoid a big amount of updates in case of the controller resend the same value...
          I did thought of a kind of circular buffer , but it's too late for my brain to find a working solution :joy:
          Reading the atmel doc will surely be easier !
            We're using eeprom_update_byte which only updates if the value differs.
            • N
              N
              napo7
              Great !
              Now I have to implement a circular buffer and the solution will be perfect !
              Edit : This reading is interresting : http://hackaday.com/2011/05/16/destroying-an-arduinos-eeprom/
              The user did a test to wear out EEPROM, and did managed to get more than 1M writes before it started to fail !
