  3. Current Sensing?
Current Sensing?
111 Posts 12 Posters 65.4k Views 10 Watching
    I am about to order some LM393 light sensor modules to test them out, but the real challenge will be to remove the photodiode, add a little cable and find a way to stick it to the pulsing LED
    Samuel235
    @gohan I already have some designs in my head. I don't think this would be that hard to make from scratch to be honest. I'm aiming to make it look exactly like what we have been looking at with: https://shop.openenergymonitor.com/optical-utility-meter-led-pulse-sensor/
    MySensors 2.1.1
    • S
      Samuel235
      Is everyone's power meter omitting a RED LED flashing, or do some countries have different colours?
      MySensors 2.1.1
      YveauxY 1 Reply Last reply
      • S Samuel235
        YveauxY
        YveauxY
        @Samuel235 yellowish here
        S 1 Reply Last reply
        • YveauxY Yveaux
          Samuel235
          @Yveaux - You're still in the rough area of 600nM wavelength, so we're all good for you :)
          MySensors 2.1.1
          • S Samuel235
            YveauxY
            YveauxY
            @Samuel235 Great! Surprise me ;-)
            • YveauxY Yveaux
              Samuel235
              @Yveaux I'm attempting to 😉
              Rough designs have been started.
              MySensors 2.1.1
              • scalzS
                scalzS
                too hard to resist, so first draft freshly printed
                S gohanG 2 Replies Last reply
                • scalzS scalz
                  Samuel235
                  @scalz - I hate being a student and having no time. Beat me to it! Do you have the circuitry sorted?
                  What 3D modelling software do you use? Fusion, solidworks?
                  Also, what size have you made that, what size PCB would it accept?
                  MySensors 2.1.1
                  • scalzS scalz
                    @scalz
                    It may be a good idea to make an housing for the phototransistor that is basically an led, so you can have pcb externally in the same box with the Arduino.
                      @scalz
                      Samuel235
                      @gohan - While it would be possible, its not allowing much surface to attach to the meter. My soloution will be out by tonight i hope. I'm proposing we attach this module to the meter and connect into another board that is attached to the side of the meter that is the heart of the module (a atmega328 board). The designs and schematic anyway, we can then ponder over what my designs call and we can improve before production and release to openhardware.io
                      MySensors 2.1.1
                      gohanG 1 Reply Last reply
                      • S
                        Samuel235
                        From my initial bit of research, the product that we were talking about from OpenEnergyMonitor doesn't seem to be optimized for detecting a blinking LED. It works, but is not optimized for best result. If the pulse started becoming relatively quick for any reason then this would start to saturate and the LDR will not return to its normal status quick enough. I'm designing using a compactor and photodiode to get around this issue. Schematics are nearly done and will attempt to get this PCB small as possible for either my own 3d printable model to stick onto the meter or @scalz.
                        Could you possibly share that model at all @scalz? Obviously, depending on what engine you have used to create this that is :)
                        MySensors 2.1.1
                        • sundberg84S
                          #52
                          I dont know it its worth anything, but here is my solution for a energymonitor (pulse counter)
                          https://www.byggahus.se/forum/attachment.php?attachmentid=156953&d=1445108667
                          https://www.byggahus.se/forum/attachment.php?attachmentid=156955&d=1445109103
                          https://www.byggahus.se/forum/attachment.php?attachmentid=208900&d=1486415706
                          And to asnwer your question above, I use this for my hole house, and are going to build a portable current sensing monitor which i can move around and measure different outlets.
                          • sundberg84S sundberg84
                            Samuel235
                            @sundberg84 - An interested little throw together!
                            I really like the idea of that portable current sensor to move around. Please do publish those designs, that is something that could be of use to some!
                            MySensors 2.1.1
                            • S Samuel235
                              @Samuel235
                              Of course it would need a bigger surface than an led diameter, but could be smaller in volume.
                                @Samuel235
                                Samuel235
                                #55
                                @gohan The trouble is though, as i mentioned just in the post regarding the product from OpenEnergyMonitor, a photo transistor is not the best/optimal way to go about this. As the LM393 module is built, it is the correct method. Using a photodiode and a comparator. No one seems to be doing that, and this is exactly what i'm doing right now. I'm pretty confident we can get this to a size that would satisfy your suggestions, we shall see.
                                Edit: Typo.
                                MySensors 2.1.1
                                • scalzS
                                  scalzS
                                  wrote on last edited by scalz
                                  #56
                                  Beep beep lol
                                  I'm joking. That was really quick to do. The box is same size 22mm. I'm not sure to see the point of making it smaller as it needs holding points.
                                  I've used solidworks.
                                  Yep I've done the pcb too. Ultra low power, a few parts. But I need to test the circuit (maybe at lunch) as I'm not planning to use comp nor amp. Again I did it because it was quick and because I can :)
                                  • scalzS scalz
                                    Beep beep lol
                                    Samuel235
                                    #57
                                    @scalz - I might as well just leave it to you >.<
                                    Nice, solidworks is what i'm using at the moment too. Fancy sharing the files or is it just a quick rough idea that you're not sticking with?
                                    Would be nice to compare the two designs together for the circuit. I might see about getting a board produced at my Uni on the routing machine. Lets both make our versions and would be nice to compare them side by side. (I'm thinking about sending you one of mine once its produced, and you're welcome to scrutinise it to help me improve)
                                    Out of interest, i'm looking at either 3.5mm audio jack or RJ45 (RJ45 looks to be a slightly cheaper route) to connect back to the 'arduino' box. What are you thinking of doing for connectivity?
                                    MySensors 2.1.1
                                    • scalzS
                                      scalzS
                                      #58
                                      It took me less an hour for the box+pcb..i wouldn't have invest more time as i've lot of others stuff to do.
                                      For the connector, I let the user choosing as I'm not really planning to design a dedicated pcb for the mcu side. Because there are already lot of boards and it just need one signal. Or I have multiple custom dev board with usb connection too etc. I was mainly interested in doing a low power sensor with a good digital level. Now I need to check my little idea..
                                      • scalzS scalz
                                        Samuel235
                                        @scalz - Perfect, okay. Well i will sort something out with the MCU side in mine then. I might go down the route of custom board, but then again, it may be easier for the user to just use a arduino maybe, just that the connection of the sensor would be a little 'temp' if i don't do a custom board maybe. Not sure yet. Will get the sensor product sorted first.
                                        MySensors 2.1.1
                                        • S Samuel235
                                          Edit: Typo.
                                          wrote on last edited by gohan
                                          #60
                                          @Samuel235
                                          Sorry, I meant photodiode, I messed up the name. I am planning to use the module as shown in photos posted by sundberg
