  3. Domoticz
  4. Send value from Domoticz to MySensor node
10 Posts 4 Posters 6.1k Views 5 Watching
  • moumout31M
    moumout31M
    moumout31
    I've tried to use the Power Meter Pulse example of MySensors website, but I can't initialize the first kwh value with the current meter index.
    Thus, I would like to send the index manually via Domoticz to initialize a variable in the Arduino sketch of the node.
    Do you know how I can set a value in Domoticz and send it to a MySensors node to store it in a variable please ?
    Thanks in advance for your help.
    Baptiste
    • moumout31M moumout31
      Baptiste
      @moumout31 - there are some discussions about this on the forum. Here is one for example: https://forum.mysensors.org/topic/2101/pulse-water-meter
      moumout31M 1 Reply Last reply
      • sundberg84S sundberg84
        moumout31M
        moumout31M
        moumout31
        @sundberg84 Thanks for your help.
        It seems to answer my problem, I will try what is done on this topic.
        • moumout31M
          moumout31M
          moumout31
          I tried to debug my sketch but when I request the last know value from gateway request(CHILD_ID_PMPINIT, V_KWH);, I have no answer from the gateway.
          Contrary to the MySensors example Power Meter Pulse, after several tries, I've created a new Child in order to store the init value of meter and to be able to update it via json.
          You can see the sketch here below.
          Baptiste
          #include "_04_Headers.h"
          #include "Arduino.h"
          #include <SoftwareSerial.h>
          //**********Init MySensors**********
          #define MY_RADIO_RFM69
          #define MY_RF69_IRQ_PIN 3
          #define MY_RF69_IRQ_NUM 1
          // Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
          #if F_CPU == 8000000L
          #define MY_BAUD_RATE 38400
          //**********Init téléinfo**********
          unsigned long loopCounter = 0L;
          unsigned long BASET=0;
          unsigned long BASETt=0; //BASET temporaire
          unsigned long PAPPT=0;
          unsigned long IINSTT=0;
          unsigned long Pcalc=0;
          unsigned long Conso=0;
          int j=1;
          int z=1;
          TeleInfo* myTeleInfo;
          #define CHILD_ID_COMPTEURPV 0
          #define CHILD_ID_COMPTEURPVVA 2
          #define CHILD_ID_COMPTEURPVI 3
          MyMessage kWhPVmsg(CHILD_ID_COMPTEURPV, V_KWH);
          MyMessage WPVmsg(CHILD_ID_COMPTEURPV, V_WATT);
          MyMessage VAPVmsg(CHILD_ID_COMPTEURPVVA, V_VA);
          MyMessage IPVmsg(CHILD_ID_COMPTEURPVI, V_CURRENT);
          unsigned long SENDstartTeleInfo=0;
          //**********Init température**********
          #include <OneWire.h>
          #define CHILD_ID_TEMP 1
          MyMessage TEMPmsg(CHILD_ID_TEMP, V_TEMP);
          unsigned long SENDstartTemp=0;
          const int DS18S20_Pin = 5; //DS18S20 Signal pin on digital 5
          const int DS18B20_ID = 0x28;
          OneWire ds(DS18S20_Pin);  // on digital pin 5
          //***********Init POWER METER PULSE**********
          #define DIGITAL_INPUT_SENSOR 2  // The digital input you attached your light sensor.  (Only 2 and 3 generates interrupt!)
          #define PULSE_FACTOR 1000       // Nummber of blinks per KWH of your meeter
          #define SLEEP_MODE false        // Watt-value can only be reported when sleep mode is false.
          #define MAX_WATT 10000          // Max watt value to report. This filetrs outliers.
          #define CHILD_ID_PMP 4             // Id of the sensor child
          #define CHILD_ID_PMPINIT 5
          unsigned long SEND_FREQUENCY = 20000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
          double ppwh = ((double)PULSE_FACTOR)/1000; // Pulses per watt hour
          bool pcReceived = false;
          volatile unsigned long watt = 0;
          unsigned long oldWatt = 0;
          double oldKwh;
          unsigned long lastSend;
          MyMessage wattMsg(CHILD_ID_PMP,V_WATT);
          MyMessage kwhMsg(CHILD_ID_PMP,V_KWH);
          MyMessage pcMsg(CHILD_ID_PMPINIT,V_KWH);
          void onPulse() {
              if (!SLEEP_MODE) {
                  unsigned long interval = newBlink-lastBlink;
                  if (interval<10000L) { // Sometimes we get interrupt on RISING
                      return;
                  watt = (3600000000.0 /interval) / ppwh;
                  lastBlink = newBlink;
              pulseCount++;
          float getTemp() {
            //Serial.begin(57600);
            //Serial.println(F("\nStarting ..."));
            delay(300);
            // starting TeleInfo capture
            myTeleInfo = new TeleInfo(version);
            // Use the internal pullup to be able to hook up this sketch directly to an energy meter with S0 output
            // If no pullup is used, the reported usage will be too high because of the floating pin
            pinMode(DIGITAL_INPUT_SENSOR,INPUT_PULLUP);
            attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), onPulse, RISING);
            lastSend=millis();
            sendSketchInfo("Tableau electrique", "1.0");
            present(CHILD_ID_COMPTEURPV, S_POWER);
            present(CHILD_ID_COMPTEURPVVA, S_POWER);
            present(CHILD_ID_COMPTEURPVI, S_MULTIMETER);
            present(CHILD_ID_PMP, S_POWER);
            present(CHILD_ID_PMPINIT, S_POWER);
              if (message.type==V_KWH) {
                  Serial.println(pulseCount);
                  pcReceived = true;
          //**********1er cycle de calcul**********
            float temp;
            boolean teleInfoReceived;
            if (j==1) {
              temp = getTemp(); //acquisition température
              temp = getTemp();
              send(TEMPmsg.set(temp,1));
              while(z==1) //tant qu'on n'acquiert pas de téléinfo
                teleInfoReceived = myTeleInfo->readTeleInfo();
                if(teleInfoReceived)
                  BASET=myTeleInfo->BASET;
                  PAPPT=myTeleInfo->PAPPT;
                  IINSTT=myTeleInfo->IINSTT;
                  z=2;
              j=2;
          //**********Téléinfo**********
            // we parse the teleInfo frame
              BASETt=myTeleInfo->BASET;
              if((BASETt>BASET) && (BASETt-BASET<1000) && (BASETt<500000)) {
                BASET=BASETt;
              //Calcul des informations
              //Puissance efficace instantannée en Watt
              Pcalc=IINSTT*(float)230;
              // Envoi des donnees
              if((millis() - SENDstartTeleInfo > 3000))
                SENDstartTeleInfo=millis();
                send(kWhPVmsg.set(BASET/(float)1000,3));
                send(VAPVmsg.set(PAPPT));
                send(IPVmsg.set(IINSTT));
                send(WPVmsg.set(Pcalc));
            //**********Consommation électrique*********
            unsigned long now = millis();
            bool sendTime = now - lastSend > SEND_FREQUENCY;
            if (pcReceived && (SLEEP_MODE || sendTime)) {
                // New watt value has been calculated
                if (!SLEEP_MODE && watt != oldWatt) {
                    // Check that we dont get unresonable large watt value.
                    // could hapen when long wraps or false interrupt triggered
                    if (watt<((unsigned long)MAX_WATT)) {
                        send(wattMsg.set(watt));  // Send watt value to gw
                    Serial.print("Watt:");
                    Serial.println(watt);
                    oldWatt = watt;
                // Pulse cout has changed
                if (pulseCount != oldPulseCount) {
                    send(pcMsg.set(pulseCount));  // Send pulse count value to gw
                    double kwh = ((double)pulseCount/((double)PULSE_FACTOR));
                    oldPulseCount = pulseCount;
                    if (kwh != oldKwh) {
                        send(kwhMsg.set(kwh, 4));  // Send kwh value to gw
                        oldKwh = kwh;
                lastSend = now;
            } else if (sendTime && !pcReceived) {
                // No count received. Try requesting it again
                lastSend=now;
            if (SLEEP_MODE) {
                sleep(SEND_FREQUENCY);
            //**********Température**********
            float temp1 = getTemp(); //acquisition température
            if((millis() - SENDstartTemp > 30000) && (temp1 > (float)5))
                temp=temp1;
                Serial.print("Temperature : ");
                Serial.println(temp);
                SENDstartTemp=millis();
            Baptiste
            int j=1;
            int z=1;
            double oldKwh;
            void onPulse() {
                if (!SLEEP_MODE) {
                        return;
                pulseCount++;
            float getTemp() {
              delay(300);
              lastSend=millis();
                    pcReceived = true;
              float temp;
              if (j==1) {
                temp = getTemp();
                    z=2;
                j=2;
                  BASET=BASETt;
                      oldWatt = watt;
                          oldKwh = kwh;
                  lastSend = now;
                  lastSend=now;
              if (SLEEP_MODE) {
                  temp=temp1;
            moumout31M
            moumout31M
            moumout31
            @moumout31 Nobody knows how to help me please ?
            AWIA 1 Reply Last reply
              AWIA
              AWIA
              AWI
              @moumout31 domoticz only responds to requests for a few types of sensors. KWh is not one of them. You can try to work with V_TEXT.
              • AWIA AWI
                moumout31M
                moumout31M
                moumout31
                @AWI Thanks a lot for yout answer ! I will try this !
                K 1 Reply Last reply
                  K
                  K
                  kimot
                  wrote on last edited by kimot
                  @moumout31
                  I think it is not true, what AWI writes.
                  I try pulse meter example now on RS485 bus, and I am receiving last value from Domoticz when restarting node .
                  When I reset or power off node, it then continues sending form last value.
                  This value it must obtain from domoticz.
                  • K kimot
                    @moumout31
                    AWIA
                    AWIA
                    AWI
                    @kimot the pulse meter uses the V_VAR datatype. This can be written to and requested from Domoticz from the MySensors network. However there is no mechanism in Domoticz to set the value. So yes, a useful method for storing variables, but treated somewhat strange on the Domoticz side.
                    • moumout31M
                      moumout31M
                      moumout31
                      Thanks a lot, it works using V_TEXT instead of V_KWH !
