  3. Serial Gateway crash and reloads
18 Posts 5 Posters 4.4k Views 4 Watching
  • martinsM Offline
    martinsM Offline
    martins
    Why would this message cause the gateway to crash and reloads ? All it does is send a text field to the gateway and requesting an ack:
    0;255;3;0;9;TSF:MSG:READ,10-10-0,s=9,c=1,t=47,pt=0,l=8,sg=0:c350fd4b
    0;255;3;0;9;TSF:MSG:ACK REQ
    0;255;3;0;9;!TSF:MSG:SEND,0-0-10-10,s=9,c=1,t=47,pt=0,l=8,sg=0,ft=0,st=NACK:c350fd4b
    0;255;3;0;9;MCO:BGN:INIT GW,CP=RRNGA--,VER=2.1.1
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSF:WUR:MS=0
    0;255;3;0;9;TSM:INIT:TSP OK
    0;255;3;0;9;TSM:INIT:GW MODE
    0;255;0;0;18;2.1.1
    0;255;3;0;11;MySensors Serial Gateway
    0;255;3;0;12;2.0.0
    0;255;3;0;9;MCO:BGN:STP
    0;255;3;0;9;TSF:MSG:READ,10-10-0,s=8,c=1,t=16,pt=2,l=2,sg=0:1
    10;8;1;0;16;1
    0;255;3;0;9;TSF:MSG:READ,10-10-0,s=8,c=1,t=16,pt=2,l=2,sg=0:0
    10;8;1;0;16;0
    0;255;0;0;18;2.1.1
    0;255;3;0;12;2.0.0
    0;255;3;0;9;TSF:MSG:READ,10-10-0,s=255,c=3,t=22,pt=5,l=4,sg=0:60250
    10;255;3;0;22;60250
    Any suggestions on how to fix this is appreciated.
    Regards,
    Martin
    • martinsM martins
      0;255;0;0;18;2.1.1
      0;255;3;0;12;2.0.0
      10;8;1;0;16;1
      10;8;1;0;16;0
      0;255;0;0;18;2.1.1
      0;255;3;0;12;2.0.0
      10;255;3;0;22;60250
      Regards,
      Martin
      @martins how is the node powered? Have you checked the troubleshooting chart at https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help/ ?
      • martinsM Offline
        martinsM Offline
        martins
        Powered by a raspberry pi 3 of its 3.3 v. Couple of mockmysensors running of this serial gateway as well asva door sensor without any problem. However as soon as this rfid sensor sends a s_info back containing text and request an ack the gateway reboots. If I remove the sendmsg it runs fine. This text however contains the rfid_ui key and is required to log which card triggered the event.
          Do you have a capacitor on the 3.3V? Maybe the rpi can't supply enough power when transmitting.
          • martinsM Offline
            martinsM Offline
            martins
            I comment out one msg.set from the sensor and that fix the problem. I really don't think this is power related. And this is the gateway guys. It is only powering an arduino mini pro and a rfm69.
            • martinsM Offline
              martinsM Offline
              martins
              Even connected directly via usb to the ide I get the same symptom.
                wrote on last edited by gohan
                Post your code and some more details on your hardware used. Btw, have you tried to swap the arduino in the gateway?
                • martinsM Offline
                  martinsM Offline
                  martins
                  This works perfect without the gateway reloading:
                  void granted (int setDelay) {
                    value = 1;
                    send(msg.set(value==HIGH ? 1 : 0));
                    delay(setDelay);
                    value = 0;
                    #ifdef MY_DEBUG
                      Serial.print("UID sent to Controller: ");
                      Serial.println(uid_rfid_str);
                  // Send to gateway the UID to keep log of who entered
                  //  send(TEXTMsg.set(uid_rfid), false);
                  However as soon as I uncomment this it reloads:
                   send(TEXTMsg.set(uid_rfid), true);
                  Some more code:
                  MyMessage TEXTMsg(CHILD_ID_TXT,V_TEXT);  // Send UID of RFID tag
                  void presentation() {
                    sendSketchInfo("RFID Gate", "1.0");
                    present(CHILD_ID, S_DOOR);
                    sendSketchInfo("RFID UID", "0.0.1");
                    present(CHILD_ID_TXT, S_INFO, "RFID UID", true);
                  • martinsM Offline
                    martinsM Offline
                    martins
                    Changed the arduino pro mini. Same effect. As soon as this is executed the serial gateway restarts send(TEXTMsg.set(uid_rfid), true);
                    Output on serial gateway:
                    Gateway restart:cry:
                    0;255;0;0;18;2.1.1
                    0;255;3;0;12;2.0.0
                    • martinsM Offline
                      martinsM Offline
                      martins
                      Narrowed it down a bit more. As soon as I change the true (req ack) to false the gateway don't crash anymore. So my question now is why would a ack req cause the gateway to crash ?
                        send(TEXTMsg.set(uid_rfid), false);```
                        What Arduino ide version are you using? And what avr boards definitions?
                        PS I corrected the code tags in your previous post as you didn't put them on separate lines and they were not working correctly
                        • martinsM Offline
                          martinsM Offline
                          martins
                          IDE 1.8.1
                          0_1489826183494_upload-88d0d7f0-c39a-47e1-aa30-6f49a3310a96
                          Y 1 Reply Last reply
                          • martinsM martins
                            IDE 1.8.1
                            Y Offline
                            Y Offline
                            @martins the 3v3 from rpi can only supply very low currents iirr. This could cause issues as soon as you start using the radio (sending messages).
                            Could you try powering from a different, beefier power supply to rule out the supply?
                            gohanG 1 Reply Last reply
                            • Y Yveaux
                              @Yveaux he said he connected directly the USB to computer but still gets reboots. Maybe downgrading avr boards to 1.6.11 or earlier?
                                Y Offline
                                Y Offline
                                @gohan I couldn't tell if he switched power supply. USB is 5v, his pro mini 3v3, so where does the 3v3 come from?
                                martinsM 1 Reply Last reply
                                • Y Yveaux
                                  martinsM Offline
                                  martinsM Offline
                                  martins
                                  wrote on last edited by martins
                                  @Yveaux
                                  Y J 2 Replies Last reply
                                  • martinsM martins
                                    @Yveaux
                                    Y Offline
                                    Y Offline
                                    @martins Ok, clear. I have an almost identical board that only delivers 5V to the target.
                                    • martinsM martins
                                      @Yveaux
                                      J Offline
                                      J Offline
                                      Jan Gatzke
                                      @martins Did you ever find a solution for this? I am facing similar problems with the serial gateway: https://forum.mysensors.org/topic/6684/serial-gateway-restarting/13
                                      12.2k
