  3. 💬 jModule2
💬 jModule2
contest2017mysensors
11 Posts 8 Posters 2.7k Views 8 Watching
  • openhardware.ioO Offline
    openhardware.io
    https://www.openhardware.io/view/332/jModule2
    • C Offline
      C Offline
      chsw
      This looks like a really nice board. Will there be any links (as for the original jmodule) to make it easier to buy the pcb?
      • K Offline
        K Offline
        kontrollable
        Wow, impressive work! Really nice instructions. I think I will try this.
        • julissesJ Offline
          julissesJ Offline
          julisses
          wrote on last edited by julisses
          @chsw The "by link" I think will be soon. The latest revision of the project waits for verification by manufacturers (I do not know why it took so long, the project is available for a moth ago).
          • NeverDieN Offline
            NeverDieN Offline
            Looks nice! As the TL;DR, briefly what is the difference between JModule2 and the prior JModule?
            • julissesJ Offline
              julissesJ Offline
              julisses
              @NeverDie The differences:
              • 2 build options
              • no SMD elements (AMS1117 replaced by LE33 - TO92 package)
              • smaller size: the jModule and the jBoard
              • I/O pins in a one row
              • P Offline
                P Offline
                prozzerg
                I tried ordering this from Itead. They rejected it, because a missing drill file. I thought that the automatic order through the "buy" button on openhardware.io had failed so I uploaded a new gerber archive (from the download archive) but got the same response, that it was missing the drill file. Is the drilling included in some other file that Itead doesn't check? Otherwise a separate txt/dri file would be nice to have, so the order can go through.
                NeverDieN 1 Reply Last reply
                • P prozzerg
                  NeverDieN Offline
                  NeverDieN Offline
                  @prozzerg
                  Most likely they would accept the .brd file by itself as sufficient.
                  • M Offline
                    M Offline
                    marcusakamg7
                    I tried to purchase this board and they said they need the drill size.
                    Quote “ we find the file is empty when open the it by cam350. so it is better to send us the drilling layer which show the size of the hole .”
                    • A Offline
                      A Offline
                      Andrew Currie
                      I just tried to buy the jBoard2 from PCBWay via OpenHardware and PCBWay say I need to "upload the Gerber RS-274X file". They could not use the auto-order files or the jBoard2.brd/jBoard2.sch files. Is the new Gerber file available or can I convert the existing files to the new format?
                      A 1 Reply Last reply
                      • A Andrew Currie
                        A Offline
                        A Offline
                        Andrew Currie
                        @Andrew-Currie Downloaded KiCad and used it to import jBoard2.brd and output .gbr files via Plots plus the .drl file. Checked using GerbView and uploaded to PCBWay. Hopefully this will now work...
