  3. [SOLVED] strange problem with millis()
5 Posts 2 Posters 2.0k Views 2 Watching
  • Moshe LivneM
    Moshe LivneM
    Moshe Livne
    It has been a long time but i am back... however, I must have lost it!
    Millis now return 4 digits results and I can find the reason. It might be the update of the libraries the arduino IDE asked me to do. Anyways, here is the code:
    #include <MySensors.h>                       // Mysensor network
      // put your setup code here, to run once:
        unsigned long now;
        Serial.println("entering loop");
        now=millis();
        Serial.print("now=");
        Serial.println((unsigned long)now);
          sleep(5000);
    couldn't be simpler....
    now the result:
    x00
    x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x00x000 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.1
    3 TSM:INIT
    4 TSF:WUR:MS=0
    11 TSM:INIT:TSP OK
    13 TSF:SID:OK,ID=28
    14 TSM:FPAR
    33 TSF:MSG:SEND,28-28-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    272 TSF:MSG:READ,0-0-28,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    277 TSF:MSG:FPAR OK,ID=0,D=1
    2040 TSM:FPAR:OK
    2041 TSM:ID
    2042 TSM:ID:OK
    2044 TSM:UPL
    2046 TSF:MSG:SEND,28-28-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    2054 TSF:MSG:READ,0-0-28,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    2059 TSF:MSG:PONG RECV,HP=1
    2061 TSM:UPL:OK
    2063 TSM:READY:ID=28,PAR=0,DIS=1
    2067 TSF:MSG:SEND,28-28-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    2073 TSF:MSG:READ,0-0-28,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    2080 TSF:MSG:SEND,28-28-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
    2088 TSF:MSG:SEND,28-28-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    2095 TSF:MSG:READ,0-0-28,s=255,c=3,t=6,pt=0,l=1,sg=0:M
    2100 MCO:REG:REQ
    2103 TSF:MSG:SEND,28-28-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    2109 TSF:MSG:READ,0-0-28,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    2114 MCO:PIM:NODE REG=1
    2116 MCO:BGN:STP
    2118 MCO:BGN:INIT OK,TSP=1
    entering loop
    now=2120
    2121 MCO:SLP:MS=5000,SMS=0,I1=255,M1=255,I2=255,M2=255
    2127 MCO:SLP:TPD
    2129 MCO:SLP:WUP=-1
    entering loop
    now=2131
    2131 MCO:SLP:MS=5000,SMS=0,I1=255,M1=255,I2=255,M2=255
    2138 MCO:SLP:TPD
    2140 MCO:SLP:WUP=-1
    entering loop
    now=2142
    2142 MCO:SLP:MS=5000,SMS=0,I1=255,M1=255,I2=255,M2=255
    2148 MCO:SLP:TPD
    I have been staring at this for the last two hours... Any help will be appreciated. I am sure it is something ultra stupid
    Regards,
    Moshe
    AWIA 1 Reply Last reply
    • Moshe LivneM Moshe Livne
          unsigned long now;
          now=millis();
            sleep(5000);
      now the result:
      x00
      3 TSM:INIT
      4 TSF:WUR:MS=0
      11 TSM:INIT:TSP OK
      13 TSF:SID:OK,ID=28
      14 TSM:FPAR
      2040 TSM:FPAR:OK
      2041 TSM:ID
      2042 TSM:ID:OK
      2044 TSM:UPL
      2061 TSM:UPL:OK
      2100 MCO:REG:REQ
      2116 MCO:BGN:STP
      entering loop
      now=2120
      2127 MCO:SLP:TPD
      2129 MCO:SLP:WUP=-1
      entering loop
      now=2131
      2138 MCO:SLP:TPD
      2140 MCO:SLP:WUP=-1
      entering loop
      now=2142
      2148 MCO:SLP:TPD
      Regards,
      Moshe
      AWIA
      AWIA
      AWI
      wrote on last edited by AWI
      @Moshe-Livne :-) Maybe you slept for 2 hours? Try to define now as static or make it global. Now it is initialized every loop ..
      • AWIA AWI
        Moshe LivneM
        Moshe LivneM
        Moshe Livne
        @AWI as it should.... but - it should show a very long number.... not a 4 digit one. and not the same values each time i run the code.
        this is a test code, just to show the problem. in the original code there was static var, etc and the difference was checked.
          AWIA
          AWIA
          AWI
          @Moshe-Livne You are right, I was too quick. :blush:. Another look: sleep() also sleeps the millis() timer. As the value only slowly increases it won't show more digits i the first hours..
          • AWIA AWI
            Moshe LivneM
            Moshe LivneM
            Moshe Livne
            @AWI Darn you are right!!!!! Thanks! Have been dealing with rpi and upwards lately so assumed it has some kind of internal clock.
            Thanks again!
