  3. Problem with DHT11 sensor
6 Posts 2 Posters 6.9k Views 2 Watching
  • lozzer65L Offline
    lozzer65L Offline
    lozzer65
    Hi
    Purchased a few DHT11's off ebay. I Know they work as when I test them with this code from exmples, below they work. When I test with the mysensor code they do not. Can someone help me out with the changes required. I think it is to do with the library being used.
    Example code
    #include <SimpleDHT.h>
    // for DHT11,
    //      VCC: 5V or 3V
    //      GND: GND
    //      DATA: 2
    int pinDHT11 = 3;
    SimpleDHT11 dht11;
      Serial.begin(115200);
      // start working...
      Serial.println("=================================");
      Serial.println("Sample DHT11...");
      // read without samples.
      byte temperature = 0;
      byte humidity = 0;
      if (dht11.read(pinDHT11, &temperature, &humidity, NULL)) {
        Serial.print("Read DHT11 failed.");
        return;
      Serial.print("Sample OK: ");
      Serial.print((int)temperature); Serial.print(" *C, ");
      Serial.print((int)humidity); Serial.println(" %");
      // DHT11 sampling rate is 1HZ.
      delay(1000);
     * Version 1.0: Henrik EKblad
    // Enable debug prints
    //#define MY_RS485
    #include <DHT.h>
    #define DHT_DATA_PIN 3
    #define SENSOR_TEMP_OFFSET 0
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    DHT dht;
      sendSketchInfo("TemperatureAndHumidity", "1.1");
      present(CHILD_ID_HUM, S_HUM);
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        Serial.println(temperature);
      } else {
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
      } else {
        nNoUpdatesHum++;
    sleep(UPDATE_INTERVAL);
    • lozzer65L lozzer65
      Hi
      Example code
      // for DHT11,
      //      VCC: 5V or 3V
      //      GND: GND
      //      DATA: 2
      int pinDHT11 = 3;
      SimpleDHT11 dht11;
        // start working...
        byte humidity = 0;
          return;
        delay(1000);
      //#define MY_RS485
      #include <DHT.h>
      float lastTemp;
      float lastHum;
      bool metric = true;
      DHT dht;
          if (!metric) {
          nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
        } else {
          nNoUpdatesTemp++;
          lastHum = humidity;
          nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
        } else {
          nNoUpdatesHum++;
      @lozzer65 "not working" really doesn't give us much information, so helping you is a bit hard. Could you describe in what way it is not working?
      • lozzer65L Offline
        lozzer65L Offline
        lozzer65
        Thanks for the rely. Yes sorry for the sketchy info.
        When using the mysensors sketch and looking at the serial info, no values from the sensor were being reported. At first I thought it maybe the sensors being faulty. So I thought I would just test the sensors on their own to make sure it was not hardware. When using the example sketch the sensors outputs temp and humidity, but not on the mysensors sketch.
        Thanks for your help, Laurie
          @lozzer65 thanks for clarifying. Bu "no values", do you mean it prints just
          T:
          Is the node connecting with the gateway? Is there any other output that could give a clue to what is happening?
          • lozzer65L Offline
            lozzer65L Offline
            lozzer65
            Instead of showing values it showed nan.
            The node was connecting to the gateway, but no sensor values were available to send.
            On the example sketch the sensor showed values without issue.
              @lozzer65 that's very strange. Are you sure the sketch above is what was uploaded to the Arduino?
              This code
              should guarantee that nan is never printed.
              12.2k
