  2. Enclosures / 3D Printing
  3. Enclosure/Bumper for Easy/Newbie PCB
23 Posts 9 Posters 27.0k Views 8 Watching
  • barduinoB
    barduinoB
    barduino
    I'm not sure this is the best place to put this but here goes.
    Here are some files to create a 3D printed box or bumper for the popular Easy PCV by @sundberg84
    The STL file
    0_1490735357002_EasyBoard_Base.stl
    the SketchUp
    0_1490735391058_GarageDoorMonitor.zip
    0_1490735416778_upload-e52ac367-d89b-4cc9-b79f-bf89ef60ed13
    Have fun
    sundberg84S C M 3 Replies Last reply
    • barduinoB barduino
      The STL file
      the SketchUp
      Have fun
      @barduino - Nice work!!
      Is it ok if I link to this box from the EasyPcb?
      barduinoB 1 Reply Last reply
      • sundberg84S sundberg84
        barduinoB
        barduinoB
        barduino
        @sundberg84 , absolutely, please do!
        Cheers
        • S
          Samuel235
          What is your method of fixing the lid to the base? Or am i missing something as i haven't opened the included files yet?
          MySensors 2.1.1
          • S Samuel235
            barduinoB
            barduinoB
            barduino
            Hi @Samuel235 ,
            It just snaps in. The lid sits on the first lip of the base. It's actually quite tight.
            S dbemowskD 2 Replies Last reply
              Hi @Samuel235 ,
              Samuel235
              @barduino - So its based on the printed having been set up to as such results are produced and that the tolerances allow it to be tightly too then.
              MySensors 2.1.1
              • S Samuel235
                barduinoB
                barduinoB
                barduino
                Hi @Samuel235 ,
                And it works fine, whatever the calibration error is, it's consistent.
                The base
                0_1490909222169_upload-cd8607af-cc5a-4aa7-9e5b-760b70a0c054
                The cover
                0_1490909239113_upload-71b58885-999b-4909-88e3-bf6b7bad9df5
                So in reality, the finished part size might not be exactly that, but whatever the difference is, it is propagated to both parts. This probably wouldn't be true if I printed the parts separately in different printers.
                Anyway, we're talking about tenths of millimeters.
                3D printer generically are very precise.
                Cheers
                  The STL file
                  the SketchUp
                  Have fun
                  C
                  C
                  chorob
                  @barduino Awesome project! The links for downloading the files are not functional anymore. Can you repost?
                  Thanks!
                    Hi @Samuel235 ,
                    dbemowskD
                    dbemowskD
                    @barduino It doesn't look like there would be much holding it in place. Here is one I did for a wall mounted temp/humidity sensor.
                    0_1504382476430_upload-ac6edd42-aad6-4565-bcd9-8fc30e737f51
                    https://www.thingiverse.com/thing:2186286
                    • C chorob
                      Thanks!
                      @chorob The links are broken if I click them normally, but if I open the link in a new window or right-click and select "save as" they work. I'll try to figure out why that happens.
                      Nca78N 1 Reply Last reply
                        Nca78N
                        Nca78N
                        @mfalkvidd said in Enclosure/Bumper for Easy/Newbie PCB:
                        This is a forum problem, you need to open links in new window for them to open (Ctrl key works also).
                        C 1 Reply Last reply
                        • Nca78N Nca78
                          C
                          C
                          chorob
                          @Nca78 That kind of worked. It downloaded the STL file as a .bin file. Had to manually change the extension from .bin to .stl. It loaded but it is just the base part and does not include the main enclosure. Thanks! Chris
                            The STL file
                            the SketchUp
                            Have fun
                            mhkid
                            wrote on last edited by mhkid
                            @barduino - Am I not understanding something because the .stl seems to be just the base and the not the cover. I borrowed a friends 3D printer so I am new to using one, it definitely could be my error on this. :-)
                            dbemowskD 1 Reply Last reply
                            • M mhkid
                              dbemowskD
                              dbemowskD
                              @mhkid What are you planning to use the box for? I have the one that I posted above out on thingiverse. I have the OpenSCAD file so you can customize things if you want, but if you are okay with just a vented enclosure that accepts a 2xAA battery case, then just grab the latest V3 .stl files.
                              M 1 Reply Last reply
                              • dbemowskD dbemowsk
                                mhkid
                                @dbemowsk I saw yours and it looks great. I want to have one without the vents and have it more enclosed. I supposed I could modify yours and not have the vents but like I said I'm new to the 3D printing. What software do you use to create / modify the designs?
                                • M mhkid
                                  dbemowskD
                                  dbemowskD
                                  @mhkid I just uploaded an .stl file of the cover with no vents. Look on the thingiverse page again for "sensor_wall_box_no_vents_V3.stl"
                                  • M mhkid
                                    dbemowskD
                                    dbemowskD
                                    @mhkid The software is OpenSCAD and can be found at www.openscad.org. I have all of the OpenSCAD files on the thingiverse page. OpenSCAD files look much like a structured programming language, and works in much the same way. I have configuration variables in there to change some of the design fairly easily. If you want to give it a go, I can give you some pointers on how to use the file.
                                      mhkid
                                      @dbemowsk I'll go take a look at it, thank you. I also see the version you have that doesn't have vents so I'll try one and see how works for me first.
                                      • M mhkid
                                        dbemowskD
                                        dbemowskD
                                        @mhkid Just a note, There is a relief on one side of the inside of the case. That side is where the nRF24 radio goes.
                                        0_1508703324333_upload-75514247-b423-4eb5-94f4-422b58f4abc3
                                        Unlike barduino's case, mine mounts with screws. I use 2mm x 5mm screws, but I think 2mm x 6mm or 8mm would work better. I worked with what I had on hand though. I would stick with 2mm diameter though.
                                        • E
                                          E
                                          evb
                                          wrote on last edited by evb
                                          For people searching the complete stl files of the box and the cover.
                                          I exported them again from the sketchup file.
                                          Hmm, how to upload files here? Only images are allowed by the server?
                                          I've uploaded them to my thingiverse place: https://www.thingiverse.com/thing:4694746
                                          Anyway, I will describe it too
                                          • download the sketchup zip file from the first post
                                          • dezip it and get the skp file
                                          • get an account on the Sketchup online website (free version)
                                          • open the sketchup file
                                          • export to stl via the menu at the left
                                          If you want the two parts apart, delete one of them in the sketchup designer and export the other. Don't save!!!
                                          Do undo and delete the other part. Export now the remaining part.
