  3. Non Polarized Capacitor .22 uF rated 400 volt
5 Posts 3 Posters 2.2k Views 1 Watching
  • H
    H
    Hausner
    Does anyone know where I can find some Non Polarized Capacitor .22 uF rated 400 volt?
    I live in Europe, so anything from there would be nice :)
    I'm trying to make some 220v LED lights, as in NO trafo/adaptor for the light, just straight to the wall outlet.
    • daulagariD
      daulagariD
      daulagari
      wrote on last edited by daulagari
      I have been unassembling TV's when I was young and still have quite some high voltage capacitors from that ;-)
      But looking at:
      https://www.conrad.nl/nl/componenten/componenten-passief/condensatoren/keramische-condensatoren.html?filterNominale+spanning~~V=400
      .22 uF = 220 nF = 220.000 pF seems not that easy to get.
      Still, with a bit searching:
      http://www.ebay.com/itm/0-22uf-220nf-275vac-X-type-capacitor-x-2-/300649967406
      • H
        H
        Hausner
        Thank you for pointing me in the right direction.
        Do you think this will do? http://dk.farnell.com/vishay-roederstein/f17724222000/cap-film-pet-220nf-400vac-rad/dp/1612245?ost=0.22uF+400vac
        • axillentA
          axillentA
          axillent
          farnell I think is a best choice for the Europe
          You selection should be fine. What is planned purposive of a capacitor? Do you plan to use capacitive stile LED driver?
          sense and drive
          • H
            H
            Hausner
            The plan is to make some LED lights without the need for a wall plug transformer, as they take up space and are fairly hard to hide away.
            So I'm planning to make some small 220vac->12/5vdc converters with as little components as possible.
            Link to plan: http://www.instructables.com/id/LED-TUBE-LGHT-AC/
