  3. Sending sleeping time to nodes
6 Posts 4 Posters 1.8k Views 5 Watching
  • D
    D
    dbo
    Is it possible to send a variable from a controller or gateway to the node ? Sometime I want to change a sleeping time of my nodes. Can I do it without uploading new sketch ?
      Maybe using smart sleep you can have the node process an incoming message when it wakes up, then in the message you could send a value and change the sleep time variable.
      • D dbo
        Welcome to the MySensors community @dbo !
        The excellent NodeManager by community member @user2684 supports configuring sleep time from the controller. See https://forum.mysensors.org/topic/6183/nodemanager-plugin-for-a-rapid-development-of-battery-powered-sensors/ and https://github.com/mysensors/NodeManager for more information.
        D 1 Reply Last reply
          D
          D
          dbo
          @mfalkvidd Thanks. This is exactly what i needed.
          • K
            K
            kontrollable
            If you would like to try something simple and you happen to use a serial gateway. You can just write to the USB port of the GW.
            For example like this:
            $ echo -n "1;1;1;0;24;SP=20.0\n" > /dev/ttyUSB0
            See https://www.mysensors.org/download/serial_api_20 for API
            node-id;child-sensor-id;command;ack;type;payload\n
            The sketch for the receiving node need to "receive" V_VAR1 in this case.
            • K kontrollable
              D
              D
              dbo
              @kontrollable said in Sending sleeping time to nodes:
              Thanks, I will try.
