  3. Presentation fails for one sensor but works for another
6 Posts 3 Posters 1.7k Views 3 Watching
  • maghacM
    maghacM
    maghac
    wrote on last edited by maghac
    Hi, I have a node that measures temperature and also reports battery level. For some reason it fails to present the temp sensor properly but is able to present the battery sensor. What could possibly cause this?
    Here is my sketch:
     * Report temperature from attached DS18B20(s) on pin ONE_WIRE_BUS.
     * Sleep SLEEP_TIME (millisecs) between each reading.
     * Also report battery level using the Vcc lib.
    #define MY_OTA_FIRMWARE_FEATURE
    #define MY_NODE_ID AUTO
    #include <Vcc.h>
    #include <OneWire.h>
    #define SLEEP_TIME 600000 // Report every 10 mins
    //#define SLEEP_TIME 60000 // Report every 1 min
    // Battery measurement
    const float VccCorrection = 1.0/1.0;  // Measured Vcc by multimeter divided by reported Vcc
    Vcc vcc(VccCorrection);
    float oldBatteryVolts = 0.0;
    #define BATT_SENSOR_ID 100
    // Initialize battery message
    MyMessage battmsg(BATT_SENSOR_ID,V_VOLTAGE);
    // One wire/temp
    int numSensors=0;
    bool receivedConfig = false;
    bool metric = true;
    MyMessage msg(0,V_TEMP);
    void before()
      sensors.begin();
    void presentation() {
      sendSketchInfo("Temperature Sensor", "1.1");
         Serial.println("Presenting temp sensor");
         present(i, S_TEMP);
      Serial.println("Presenting battery sensor");
      present(BATT_SENSOR_ID, S_MULTIMETER);
      // Check battery first
      float batteryVolts = round(vcc.Read_Volts()*100.0)/100.0;
      if (oldBatteryVolts != batteryVolts) {
        send(battmsg.set(batteryVolts, V_VOLTAGE));
        oldBatteryVolts = batteryVolts;
      sleep(conversionTime);
        float temperature = static_cast<float>(static_cast<int>(sensors.getTempCByIndex(i) * 10.)) / 10.;
        #if COMPARE_TEMP == 1
        #else
          send(msg.setSensor(i).set(temperature,1));
      smartSleep(SLEEP_TIME);
    And here's the serial log when it starts:
    0 MCO:BGN:INIT NODE,CP=RNONA--,VER=2.1.1
    4 MCO:BGN:BFR
    65 TSM:INIT
    65 TSF:WUR:MS=0
    73 TSM:INIT:TSP OK
    75 TSF:SID:OK,ID=233
    77 TSM:FPAR
    114 TSF:MSG:SEND,233-233-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2123 !TSM:FPAR:NO REPLY
    2125 TSM:FPAR
    2162 TSF:MSG:SEND,233-233-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    3092 TSF:MSG:READ,0-0-233,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    3098 TSF:MSG:FPAR OK,ID=0,D=1
    4171 TSM:FPAR:OK
    4171 TSM:ID
    4173 TSM:ID:OK
    4175 TSM:UPL
    4182 TSF:MSG:SEND,233-233-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    4292 TSF:MSG:READ,0-0-233,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    4298 TSF:MSG:PONG RECV,HP=1
    4302 TSM:UPL:OK
    4304 TSM:READY:ID=233,PAR=0,DIS=1
    4311 TSF:MSG:SEND,233-233-0-0,s=255,c=4,t=0,pt=6,l=10,sg=0,ft=0,st=OK:FFFFFFFFFFFFFFFF0300
    4321 TSF:MSG:SEND,233-233-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    4608 TSF:MSG:READ,0-0-233,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    4616 TSF:MSG:SEND,233-233-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
    4626 TSF:MSG:SEND,233-233-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    5048 TSF:MSG:READ,0-0-233,s=255,c=3,t=6,pt=0,l=6,sg=0:Metric
    5056 TSF:MSG:ACK REQ
    5060 TSF:MSG:SEND,233-233-0-0,s=255,c=3,t=6,pt=0,l=6,sg=0,ft=0,st=OK:Metric
    5070 TSF:MSG:SEND,233-233-0-0,s=255,c=3,t=11,pt=0,l=18,sg=0,ft=0,st=OK:Temperature Sensor
    5083 TSF:MSG:SEND,233-233-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1
    5126 !TSF:MSG:SEND,233-233-0-0,s=0,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=NACK:
    5136 TSF:MSG:SEND,233-233-0-0,s=100,c=0,t=30,pt=0,l=0,sg=0,ft=1,st=OK:
    5144 MCO:REG:REQ
    5181 !TSF:MSG:SEND,233-233-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=NACK:2
    5861 TSF:MSG:READ,0-0-233,s=255,c=3,t=6,pt=0,l=6,sg=0:Metric
    7190 TSF:MSG:SEND,233-233-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
    7266 TSF:MSG:READ,0-0-233,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    7272 MCO:PIM:NODE REG=1
    7274 MCO:BGN:STP
    7276 MCO:BGN:INIT OK,TSP=1
    7282 TSF:MSG:SEND,233-233-0-0,s=100,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.30999990
    7292 MCO:SLP:MS=750,SMS=0,I1=255,M1=255,I2=255,M2=255
    7299 MCO:SLP:TPD
    7301 MCO:SLP:WUP=-1
    7333 TSF:MSG:SEND,233-233-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:24.5
    7342 MCO:SLP:MS=600000,SMS=1,I1=255,M1=255,I2=255,M2=255
    7350 TSF:MSG:SEND,233-233-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:74
    7698 TSF:MSG:READ,0-0-233,s=255,c=3,t=6,pt=0,l=1,sg=0:M
    7847 TSF:MSG:READ,0-0-233,s=255,c=3,t=6,pt=0,l=1,sg=0:M
    7858 MCO:SLP:TPD
    As you can see, the presentation for sensor id 0 fails - this is the temp sensor. Sending a value for the same sensor works fine though.
    • maghacM
      maghacM
      maghac
      I worked around it by checking the return value of present() to see if the presentation was successful or not, and retrying if it wasn't.
        bool presented;
           presented = false;
           while (!presented) {
            presented = present(i, S_TEMP);
            if (!presented) {
              Serial.println("Presentation failed - retrying");
              sleep(1000);
        presented = false;
          presented = present(BATT_SENSOR_ID, S_MULTIMETER);
          if (!presented) {
            sleep(1000);
      Here's the log with the above change:
      4 MCO:BGN:BFR
      65 TSM:INIT
      65 TSF:WUR:MS=0
      73 TSM:INIT:TSP OK
      77 TSM:FPAR
      2125 TSM:FPAR
      2967 TSF:MSG:READ,0-0-233,s=255,c=3,t=8,pt=1,l=1,sg=0:0
      2973 TSF:MSG:FPAR OK,ID=0,D=1
      4171 TSM:FPAR:OK
      4171 TSM:ID
      4173 TSM:ID:OK
      4175 TSM:UPL
      4179 TSF:MSG:SEND,233-233-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
      4302 TSM:UPL:OK
      5052 TSF:MSG:READ,0-0-233,s=255,c=3,t=6,pt=0,l=6,sg=0:Metric
      5058 TSF:MSG:ACK REQ
      5064 TSF:MSG:SEND,233-233-0-0,s=255,c=3,t=6,pt=0,l=6,sg=0,ft=0,st=OK:Metric
      5074 TSF:MSG:SEND,233-233-0-0,s=255,c=3,t=11,pt=0,l=18,sg=0,ft=0,st=OK:Temperature Sensor
      5087 TSF:MSG:SEND,233-233-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1
      5130 !TSF:MSG:SEND,233-233-0-0,s=0,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=NACK:
      5138 MCO:SLP:MS=1000,SMS=0,I1=255,M1=255,I2=255,M2=255
      5146 MCO:SLP:TPD
      5148 MCO:SLP:WUP=-1
      5152 TSF:MSG:SEND,233-233-0-0,s=0,c=0,t=6,pt=0,l=0,sg=0,ft=1,st=OK:
      5163 TSF:MSG:SEND,233-233-0-0,s=100,c=0,t=30,pt=0,l=0,sg=0,ft=0,st=OK:
      5171 MCO:REG:REQ
      5175 TSF:MSG:SEND,233-233-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
      5500 TSF:MSG:READ,0-0-233,s=255,c=3,t=27,pt=1,l=1,sg=0:1
      5507 MCO:PIM:NODE REG=1
      5509 MCO:BGN:STP
      5511 MCO:BGN:INIT OK,TSP=1
      5517 TSF:MSG:SEND,233-233-0-0,s=100,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.32999990
      5527 MCO:SLP:MS=750,SMS=0,I1=255,M1=255,I2=255,M2=255
      5533 MCO:SLP:TPD
      5535 MCO:SLP:WUP=-1
      5570 TSF:MSG:SEND,233-233-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:25.5
      5578 MCO:SLP:MS=600000,SMS=1,I1=255,M1=255,I2=255,M2=255
      5586 TSF:MSG:SEND,233-233-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:75
      6096 MCO:SLP:TPD
      YveauxY 1 Reply Last reply
      • xydixX
        xydixX
        xydix
        Do you use some kind of battery booster / step up regulator?
        maghacM 1 Reply Last reply
        • maghacM maghac
            bool presented;
               presented = false;
                if (!presented) {
                  sleep(1000);
            presented = false;
              if (!presented) {
                sleep(1000);
          4 MCO:BGN:BFR
          65 TSM:INIT
          65 TSF:WUR:MS=0
          73 TSM:INIT:TSP OK
          77 TSM:FPAR
          2125 TSM:FPAR
          4171 TSM:FPAR:OK
          4171 TSM:ID
          4173 TSM:ID:OK
          4175 TSM:UPL
          4302 TSM:UPL:OK
          5146 MCO:SLP:TPD
          5148 MCO:SLP:WUP=-1
          5171 MCO:REG:REQ
          5509 MCO:BGN:STP
          5533 MCO:SLP:TPD
          5535 MCO:SLP:WUP=-1
          6096 MCO:SLP:TPD
          YveauxY
          YveauxY
          @maghac I guess you're flooding the gateway with messages during startup.
          Could you give this a try?
               wait(200);     // wait for 200ms between presenting sensors
               present(i, S_TEMP);
          • xydixX xydix
            maghacM
            maghacM
            maghac
            @xydix No, nothing at all, just the radio and a DS18b20, powered by 2xAA batteries.
            • YveauxY Yveaux
                   present(i, S_TEMP);
              maghacM
              maghacM
              maghac
              @Yveaux That's possible. When I apply the workaround above, it works on the second try, which is after a 1000ms delay.
              I'll try your suggestion and see if it helps.
