  3. Help: Some explanation requested regarding NACK
26 Posts 5 Posters 7.0k Views 4 Watching
  • O Omemanti
    Thnx for the help so far, Ill let it rest for a while, Im thinking of rebuilding the whole thing..
    K
    K
    kiesel
    @Omemanti
    Where you able to solve this? I am also experiencing a lot of NACKs in my rfm69 network (868mhz)
    O 1 Reply Last reply
    • K kiesel
      @Omemanti
      O
      O
      Omemanti
      @kiesel said in Help: Some explanation requested regarding NACK:
      Nope, not that I can remember.
      BTW: I ditched the rfm69 and moved over to the NRF52.
      R 1 Reply Last reply
      • O Omemanti
        R
        R
        ricmail85
        @Omemanti
        I had exactly the same issue with Rfm69 and latest version of mysensors. The only solution I found is to use the 2.2.0 version. With this everything works perfectly.
        I don't know why with latest releases the messages are NACK even if they actually reach the gateway.
        K 1 Reply Last reply
        • R ricmail85
          @Omemanti
          K
          K
          kiesel
          @ricmail85 I solved my problem by soldering a cable to the reset pin of the chip and the (in my case) raspberry pi. This or the dupont wires I used were glitchy :D
          • K kiesel
            R
            R
            ricmail85
            @kiesel thanks for reporting! I've also a Raspberry gateway but I left the Rfm69 reset pin unconnected. How did you connect it?
            • R ricmail85
              K
              K
              kiesel
              wrote on last edited by kiesel
              #26
              @ricmail85 sorry for the late reply. I soldered it to a free pin on the pi and reconfigured the gateway.
              Use this as part of your configure
              --extra-cxxflags="-DMY_RFM69_RST_PIN=29"
              If you connected to pi pin 29.
