  3. RGB LED strip
RGB LED strip
70 Posts 22 Posters 44.1k Views 27 Watching
  • maghacM maghac
    I built a RGB LED strip controllable via mysensor, based on a 12V RGB LED strip and three IRF540 MOSFETs. The arduino is a 5V pro mini clone that I feed with 12V on the RAW pin.
    I followed the guide on https://learn.adafruit.com/rgb-led-strips/usage for wiring the MOSFETS and the LED strip. I used the Newbie PCB by @sundberg84 for holding the arduino and the radio, but put the MOSFETs on a separate prototyping board (maybe next time I'll try to solder them to the prototyping area of the Newbie PCB).
    I implemented a fading feature in the sketch, so it can fade slowly between colors or on/off. The speed is controlled by sending a V_VAR1 message with the speed (typical value could be around 200-300 for a nice effect). Speed = 0 means fading is off.
    Here is the code:
     * LED STRIP sketch for Mysensors
     * 1.0
     *   Based on the example sketch in mysensors
     * 1.1
     *   fadespeed parameter (send as V_VAR1 message)
     *   HomeAssistant compatible (send status to ack)
    #define MY_OTA_FIRMWARE_FEATURE
    #define MY_NODE_ID AUTO
    #define CHILD_ID_LIGHT 1
    #define SN "LED Strip"
    #define SV "1.1"
    MyMessage lightMsg(CHILD_ID_LIGHT, V_LIGHT);
    MyMessage rgbMsg(CHILD_ID_LIGHT, V_RGB);
    MyMessage dimmerMsg(CHILD_ID_LIGHT, V_DIMMER);
    byte red = 255;
    byte green = 255;
    byte blue = 255;
    byte r0 = 255;
    byte g0 = 255;
    byte b0 = 255;
    char rgbstring[] = "ffffff";
    int on_off_status = 0;
    int dimmerlevel = 100;
    int fadespeed = 0;
    #define REDPIN 6
    #define GREENPIN 5
    #define BLUEPIN 3
      // Fix the PWM timer. Without this the LEDs will flicker.
      TCCR0A = _BV(COM0A1) | _BV(COM0B1) | _BV(WGM00);
      // Output pins
      pinMode(REDPIN, OUTPUT);
      pinMode(GREENPIN, OUTPUT);
      pinMode(BLUEPIN, OUTPUT);
    	sendSketchInfo(SN, SV);
    	present(CHILD_ID_LIGHT, S_RGB_LIGHT);
      static bool first_message_sent = false;
      if ( first_message_sent == false ) {
        Serial.println( "Sending initial state..." );
        set_hw_status();
        send_status();
        first_message_sent = true;
      int val;
    	if (message.type == V_RGB) {
    		Serial.println( "V_RGB command: " );
        Serial.println(message.data);
        long number = (long) strtol( message.data, NULL, 16);
        // Save old value
        strcpy(rgbstring, message.data);
        // Split it up into r, g, b values
        red = number >> 16;
        green = number >> 8 & 0xFF;
        blue = number & 0xFF;
        send_status();
        set_hw_status();
    	} else if (message.type == V_LIGHT || message.type == V_STATUS) {
        Serial.println( "V_LIGHT command: " );
        val = atoi(message.data);
        if (val == 0 or val == 1) {
          on_off_status = val;
          send_status();
          set_hw_status();
      } else if (message.type == V_DIMMER || message.type == V_PERCENTAGE) {
        Serial.print( "V_DIMMER command: " );
        if (val >= 0 and val <=100) {
          dimmerlevel = val;
          send_status();
          set_hw_status();
      } else if (message.type == V_VAR1 ) {
        Serial.print( "V_VAR1 command: " );
        if (val >= 0 and val <= 2000) {
          fadespeed = val;
    	} else {
    		Serial.println( "Invalid command received..." );
    		return;
    void set_rgb(int r, int g, int b) {
      analogWrite(REDPIN, r);
      analogWrite(GREENPIN, g);
      analogWrite(BLUEPIN, b);
    void set_hw_status() {
      int r = on_off_status * (int)(red * dimmerlevel/100.0);
      int g = on_off_status * (int)(green * dimmerlevel/100.0);
      int b = on_off_status * (int)(blue * dimmerlevel/100.0);
      if (fadespeed >0) {
        float dr = (r - r0) / float(fadespeed);
        float db = (b - b0) / float(fadespeed);
        float dg = (g - g0) / float(fadespeed);
        for (int x = 0;  x < fadespeed; x++) {
          set_rgb(r0 + dr*x, g0 + dg*x, b0 + db*x);
          delay(100);
      set_rgb(r, g, b);
      r0 = r;
      b0 = b;
      g0 = g;
    void send_status() {
      send(rgbMsg.set(rgbstring));
      send(lightMsg.set(on_off_status));
      send(dimmerMsg.set(dimmerlevel));
    I have a MQTT gateway and I can turn the strip on, set the color to pink and fade speed to 500 by the following commands:
    mosquitto_pub -t mysensors-in/240/1/1/0/40 -m ff6060
    mosquitto_pub -t mysensors-in/240/1/1/0/24 -m 500
    mosquitto_pub -t mysensors-in/240/1/1/0/2 -m 1
    A couple of pics:
    DrJeffD
    DrJeffD
    DrJeff
    @maghac What board is that?
    maghacM 1 Reply Last reply
    • DrJeffD DrJeff
      maghacM
      maghacM
      maghac
      @DrJeff That's the Newbie PCB by @sundberg84 (https://www.mysensors.org/hardware/newbie-pcb)
      DrJeffD 1 Reply Last reply
      • maghacM maghac
        DrJeffD
        DrJeffD
        DrJeff
        @maghac Wow! I guess I haven't been around here for a while.
        • DrJeffD
          DrJeffD
          DrJeff
          @maghac Oh yes by the way the code above works great just added some code for Motion sensor and Now I have a much better light.
           * 1.0
           * 1.1
           * 1.2
           *   OTA support
           * 1.3
           *   Power-on self test
           * 1.4
           *   Bug fix
           * 1.5
           *   Other default values
           * 1.6
           *   Repeater feature
           * 1.7
           *   Multitasking. Alarm, Relax and normal modes.
          #define MY_REPEATER_FEATURE
          #define MY_NODE_ID 31
          // added all the motion stuff DrJeff September 10, 2017
          #define MOTION_1 3   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
          #define MOTION_ID 90   // Id of the sensor child
          uint8_t lastMotion_1 = 0;
          unsigned long previousMillis1 = 0;
          unsigned long motionDelay1 = 10000; // interval at which to keep motion sensor trippped (milliseconds).  Used to prevent too frequent updates to Vera.
          #define SV "1.7"
          MyMessage motion(MOTION_ID, V_TRIPPED);
          int current_r = 255;
          int current_g = 255;
          int current_b = 255;
          int target_r = 255;
          int target_g = 255;
          int target_b = 255;
          int save_r;
          int save_g;
          int save_b;
          float delta_r = 0.0;
          float delta_g = 0.0;
          float delta_b = 0.0;
          int fadespeed = 20;
          unsigned long last_update = 0;
          int tick_length = 10;
          int fade_step = 0;
          int program_timer;
          int program_cycle;
          #define REDPIN 6
          #define GREENPIN 4
          #define BLUEPIN 5
          #define LIGHT_NORMAL 0
          #define LIGHT_FADING 1
          #define PROGRAM_NORMAL 0
          #define PROGRAM_ALARM 1
          #define PROGRAM_RELAX 2
          int light_mode = LIGHT_NORMAL;
          int program_mode = PROGRAM_NORMAL;
          #define RELAX_SPEED 50
          #define MAX_CYCLES_RELAX 7
          const int program_param_RELAX[MAX_CYCLES_RELAX][3] = {
            {255, 32, 0},
            {255, 32, 16},
            {255, 16, 32},
            {255, 128, 0},
            {255, 32, 00},
            {255, 32, 32},
            {255, 0, 32}
            // Output pins
            pinMode(MOTION_1, INPUT);
            present(MOTION_ID, S_MOTION);
          void selftest() {
            on_off_status = 1;
            current_r = 255;
            current_g = 0;
            current_b = 0;
            set_hw_status();
            wait(100);
            current_r = 0;
            current_g = 255;
            set_hw_status();
            wait(100);
            current_g = 0;
            current_b = 255;
            set_hw_status();
            wait(100);
            current_r = 255;
            current_g = 255;
            set_hw_status();
            wait(100);
            on_off_status = 0;
              selftest();
              set_hw_status();
              send_status(1, 1, 1);
              // added all the motion stuff DrJeff September 10, 2017//loop for motion
           if(currentMillis - previousMillis1 > motionDelay1)
              uint8_t motionDetect1 = digitalRead(MOTION_1);
              if(motionDetect1 != lastMotion_1)
                Serial.print("Motion 1 = ");
                Serial.println(motionDetect1);
                //  gw.send(motionStatus_1.set(motionDetect1 ? "1" : "0")); // Send tripped value to gw
                send(motion.set(motionDetect1));
                if(motionDetect1 == 1)
                  previousMillis1 = currentMillis;  //"Tripped" delay
                else
                  previousMillis1 = currentMillis - motionDelay1 + 1000; //"Not tripped" delay for 1 second to stop rapid "not tripped" and "tripped" updates to Vera
                lastMotion_1 = motionDetect1;
          //end of motion loop
            unsigned long now = millis();
            if (now - last_update > tick_length) {
              last_update = now;
              if (light_mode == LIGHT_FADING) {
                calc_fade();
              if (program_mode > PROGRAM_NORMAL) {
                handle_program();
            set_hw_status();
            int val;
              Serial.print( "V_RGB: " );
              // Save old value
              int r = number >> 16;
              int g = number >> 8 & 0xFF;
              int b = number & 0xFF;
              init_fade(fadespeed, r, g, b);
              send_status(0, 0, 1);
              Serial.print( "V_LIGHT: " );
                send_status(1, 0, 0);
              Serial.print( "V_DIMMER: " );
                dimmerlevel = val;
                send_status(0, 1, 0);
              Serial.print( "V_VAR1: " );
                fadespeed = val;
            } else if (message.type == V_VAR2 ) {
              Serial.print( "V_VAR2: " );
              if (val == PROGRAM_NORMAL) {
                stop_program();
              } else if (val == PROGRAM_ALARM || val == PROGRAM_RELAX) {
                init_program(val);
            } else {
              return;
          void init_program(int program) {
            program_mode = program;
            program_cycle = 0;
            save_rgb();
            if (program == PROGRAM_ALARM) {
              current_r = 255;
              current_g = 255;
              current_b = 255;
              program_timer = 50;
            } else if (program == PROGRAM_RELAX) {
              program_timer = 300;
                        program_param_RELAX[program_cycle][0],
                        program_param_RELAX[program_cycle][1],
                        program_param_RELAX[program_cycle][2]);
          void handle_program() {
            program_timer--;
            if (program_mode == PROGRAM_ALARM) {
              if (program_timer == 0) {
                program_timer = 50;
                if (program_cycle == 0) {
                  program_cycle = 1;
                  current_r = 0;
                  current_g = 0;
                  current_b = 0;
                } else {
                  program_cycle = 0;
                  current_r = 255;
                  current_g = 255;
                  current_b = 255;
            } else if (program_mode == PROGRAM_RELAX) {
              if (light_mode == LIGHT_NORMAL) {
                program_cycle = (program_cycle+1) % MAX_CYCLES_RELAX;
                Serial.print("Next cycle step ");
                Serial.println(program_cycle);
                init_fade(fadespeed * RELAX_SPEED,
          void stop_program() {
            restore_rgb();
          void save_rgb() {
            save_r = current_r;
            save_g = current_g;
            save_b = current_b;
          void restore_rgb() {
            current_r = save_r;
            current_g = save_g;
            current_b = save_b;
          void init_fade(int t, int r, int g, int b) {
            Serial.print( "Init fade" );
            light_mode = LIGHT_FADING;
            target_r = r;
            target_g = g;
            target_b = b;
            fade_step = t;
            delta_r = (target_r - current_r) / float(fade_step);
            delta_g = (target_g - current_g) / float(fade_step);
            delta_b = (target_b - current_b) / float(fade_step);
          void calc_fade() {
            if (fade_step > 0) {
              fade_step--;
              current_r = target_r - delta_r * fade_step;
              current_g = target_g - delta_g * fade_step;
              current_b = target_b - delta_b * fade_step;
            } else {
              Serial.println( "Normal mode" );
            int r = on_off_status * (int)(current_r * dimmerlevel/100.0);
            int g = on_off_status * (int)(current_g * dimmerlevel/100.0);
            int b = on_off_status * (int)(current_b * dimmerlevel/100.0);
            set_rgb(r, g, b);
          void send_status(int send_on_off_status, int send_dimmerlevel, int send_rgbstring) {
            if (send_rgbstring) send(rgbMsg.set(rgbstring));
            if (send_on_off_status) send(lightMsg.set(on_off_status));
            if (send_dimmerlevel) send(dimmerMsg.set(dimmerlevel));
          • mickM
            mickM
            mick
            Hey @maghac - just wondering how you got the 12V to your fitting? have you got a transformer in the ceiling above ? Regards, mick
            • mickM mick
              maghacM
              maghacM
              maghac
              @mick No, I have a separate 12V cable and a transformer from a regular wall outlet.
              mickM 1 Reply Last reply
              • maghacM maghac
                mickM
                mickM
                mick
                @maghac Thanks for the reply, mate. The light looks great mounted up - very impressed!
                • mickM mick
                  maghacM
                  maghacM
                  maghac
                  @mick said in RGB LED strip:
                  Thanks! The "relax" program is actually quite nice since it changes colours so slowly so it takes a while before you notice it. A great way to impress your dinner guests :)
                  • X
                    X
                    xypzo
                    I dont know what went wrong, but RED is just always on. Yesterday in the breadboard it was ok. Today in the breadboard red was on. So i thought lets just solder it... Now I soldered it to a pcb, RED on all the time. This must be a ground issue, but where do i look?
                    It is even red when just all the connections are off, 12v to raw and strip, then connect ground to arduino, BOOM red comes on...
                    • X xypzo
                      maghacM
                      maghacM
                      maghac
                      @xypzo Double check your connections, perhaps you're connecting to the wrong pin on the arduino? If you swap red and green, what happens then?
                      X 1 Reply Last reply
                      • maghacM maghac
                        X
                        X
                        xypzo
                        @maghac said in RGB LED strip:
                        Then green keeps on, so it should be a pin 6 problem, but i can't find it. Maybe I try a 10kohm resistor between gate and ground... Or IRFZ instead of IRLZ transistors.
                        BTW, bought a LD362A ufo which works great with my controller, but i still want to win this battle!
                        • X xypzo
                          maghacM
                          maghacM
                          maghac
                          @xypzo said in RGB LED strip:
                          You could try to use a different pin. Can't remember off the top of my head which pins are PWM capable though.
                          I've had a couple of cheap arduino clones where some of the pins were not correctly soldered.
                          • maghacM maghac
                            X
                            X
                            xypzo
                            @maghac The stupid thing, is that the day before, same setup, no red lights stayed on. It happened overnight!!! Maybe the mice did it! :')
                            • X xypzo
                              maghacM
                              maghacM
                              maghac
                              @xypzo Gremlins! :)
                              • X
                                X
                                xypzo
                                what DID happen the day before, was that when i added more WHITE, at around 60% white the whole unit stopped responding to any inputs, it would just freeze in that color, until i removed the 12v power supply. Also strange! :)
                                • bgunnarbB
                                  bgunnarbB
                                  bgunnarb
                                  Hi!
                                  I'm doing some further development based on the sketch by @maghac and @DrJeff above and I have found two potential bugs that could create some unexpected behaviour.
                                  The first is that if you have #DEFINE RELAX_SPEED 50 in the sketch and then set fadespeed (V_VAR1) to anything greater than 650 or so, you will get an overflow when you call the function init_fade (t, r, g, b ) since t is defined as int in init_fade.
                                  fadespeed can be set between 0 and 2000 in the sketch. So then the resulting fadespeed could be anything, even negative.
                                  Also in this function there is a potential risk of a "divide by zero" crash since the input variable t is used as fade_step to divide in order to get the size of each step in the fade cycle.
                                    target_r = r;
                                    target_g = g;
                                    target_b = b;
                                    fade_step = t;
                                  It might be that this function is never called with fadestep = t = 0 but since this is a value allowed in the input check of V_VAR1 nasty things may happen.
                                  Part from this I am impressed by the sketch. Once I have debugged my own additions I will post the project here.
                                  I have never been so busy since I retired!
                                  • bgunnarbB bgunnarb
                                    Hi!
                                      target_r = r;
                                      target_g = g;
                                      target_b = b;
                                      fade_step = t;
                                    maghacM
                                    maghacM
                                    maghac
                                    @bgunnarb Thanks. As program space is limited, I chose not to put too much effort in input data validation, instead relying on the controller to not submit incorrect values. Maybe a quick range check would not waste so many bytes though.
                                    Right now I am however experiencing some strange behavior - I can turn the the lamp on and off and I can dim it, but I cannot change the color of the strip. Also, the RELAX program does not work but the ALARM program works fine. So there are some other bugs that need to be ironed out :)
                                    • M moskovskiy82
                                      After some investigating it wasn't a timer issue but a range issue with a node (it was hard to figure out). So went ahead and built another node with your code. But being lazy - just bought an rgb strip drive from aliexpress (too much soldering of mosfets for me).
                                      It uses some RGBdriver.h library https://github.com/letsgoING/Libraries/tree/master/LEDStripDriver
                                      fe
                                      All i had to change was
                                        Driver.begin();
                                        Driver.SetColor(r, g, b);
                                        Driver.end();
                                      And it worked. Except that fading/RELAX don't work out for me. Instead just get a flashing of white light. So i thought you might know some other parts must be adjusted as my arduino knowledge is not there yer
                                      maghacM
                                      maghacM
                                      maghac
                                      @moskovskiy82 said in RGB LED strip:
                                      That's the alarm program you are seeing. Perhaps it doesn't decode the incoming messages properly - I'll have to take a second look at the code.
                                        moskovskiy82
                                        Thanks. Will await eagerly for v1.8 as it seems this is the only great RGB code left for mysensors
                                        • micahM
                                          micahM
                                          micah
                                          @maghac Great project.
                                          I've made something similar, Arduino Pro Mini 5v, 5m LED strip (non-addressable), nrf24L01+ and MOSTFETs
                                          I know it took me awhile to find code examples, so I figured I would share my code incase it helps anyone else.
                                          I use Domoticz as a controller. This code talks to:
                                          • Switch - to control turning my color cycle fade effect on
                                          • Dimmer - to control the speed of the color cycle fade effect
                                          • RGB switch - to control having only a single color turned on and the brightness of the string.
                                          Much of my code is standard stuff, using FastLED analogue, but I'm particularly proud of the brightness part, since I bashed my head against the keyboard several times trying to figure it out
                                          //## INCLUDES ##
                                          #define MY_NODE_ID 20
                                          #include <FastLED.h>
                                          #define cID_RGB_SELECTOR 0
                                          #define cID_CYCLE_EFFECT 1
                                          #define cID_CYCLE_EFFECT_SPEED 2
                                          #define PIN_RED   5
                                          #define PIN_GREEN 6
                                          #define PIN_BLUE  3
                                          //## VARIABLES ##
                                          // MySensors
                                          #define MySensors_SketchName      "RGB LED Strip"
                                          #define MySensors_SketchVersion   "v0.3"
                                          MyMessage MySensors_MSG_Last_Color(cID_RGB_SELECTOR,V_VAR1);
                                          MyMessage MySensors_MSG_RGB_Selector(cID_RGB_SELECTOR, V_LIGHT);
                                          MyMessage MySeonsors_MSG_CYCLE_EFFECT(cID_CYCLE_EFFECT, V_LIGHT);
                                          MyMessage MySensors_MSG_CYCLE_EFFECT_SPEED(cID_CYCLE_EFFECT_SPEED, V_DIMMER);
                                          bool MySensors_RequestACK = false;
                                          // Single color
                                          int Solid_RGB_Active=0;
                                          char Solid_RGB_Color[] = "000000";
                                          uint16_t Solid_RGB_Brightness = 0xFF;
                                          // Cycle effect
                                          int Cycle_Effect_Active=0;
                                          unsigned long Cycle_Effect_pMillis = 0;
                                          long Cycle_Effect_Speed = 20;
                                          static uint8_t Cycle_Effect_Current_Hue;
                                          // Supporting
                                          bool Status_Change = false;
                                          bool Print_Debug = false;
                                          // ## Primary flow control
                                            Serial.begin(115200);
                                            while (!Serial) ;
                                            Serial.print("compiled: ");Serial.print(__DATE__);Serial.println(__TIME__);
                                            pinMode(PIN_RED,   OUTPUT);
                                            pinMode(PIN_GREEN, OUTPUT);
                                            pinMode(PIN_BLUE,  OUTPUT);
                                            Event_ColorTestBars();
                                            request(cID_RGB_SELECTOR, V_VAR1);
                                            request(cID_RGB_SELECTOR, V_LIGHT);
                                            request(cID_CYCLE_EFFECT, V_LIGHT);
                                            request(cID_CYCLE_EFFECT_SPEED, V_DIMMER);
                                            if (Cycle_Effect_Active == 1){
                                              Event_RunCycleEffect(currentMillis);
                                            } else if (Status_Change){
                                                #ifdef MY_DEBUG
                                                  if (Print_Debug) {Serial.println("STATUS CHANGE");}
                                              if (Solid_RGB_Active == 0){
                                                Event_SetLEDColors( CRGB::Black );
                                              }else if (Solid_RGB_Active == 1){
                                                CHSV colorHSV = rgb2hsv_approximate(str2CRGB(Solid_RGB_Color));
                                                Event_SetLEDColors(CHSV(colorHSV.h, colorHSV.s, Solid_RGB_Brightness));
                                          // ## MySensors Methods
                                          void presentation()  {
                                            sendSketchInfo(MySensors_SketchName, MySensors_SketchVersion);
                                            present(cID_RGB_SELECTOR, S_RGB_LIGHT, "RGB Color Selector", MySensors_RequestACK);
                                            present(cID_CYCLE_EFFECT, S_LIGHT, "RGB Cycle Effect", MySensors_RequestACK);
                                            present(cID_CYCLE_EFFECT_SPEED, S_DIMMER, "RGB Cycle Effect Speed", MySensors_RequestACK);
                                          void receive(const MyMessage &message){
                                            #ifdef MY_DEBUG
                                              if (message.isAck()){
                                                Serial.println("Got ack from gateway");
                                            if (message.type == V_LIGHT){
                                              #ifdef MY_DEBUG
                                                if (Print_Debug) {Serial.println("message v_light");}
                                              int current_Light_State = message.getString()[0] == '1';// Incoming on/off command sent from controller ("1" or "0")
                                              if (message.sensor==cID_CYCLE_EFFECT){// is Cycle Message
                                                if (current_Light_State==1){//turn cycle on
                                                  Event_LightCycle(true, true, false);
                                                  Event_SolidColor(false, false, true);
                                                } else {//turn cycle off
                                                  Event_LightCycle(false, true, false);
                                              } else if (message.sensor==cID_RGB_SELECTOR){// is RGB Message
                                                if (current_Light_State==1){//turn RGB on
                                                  Event_SolidColor(true, true, false);
                                                  Event_LightCycle(false, false, true);
                                                } else {//turn RGB off
                                                  Event_SolidColor(false, true, false);
                                              } else {
                                                #ifdef MY_DEBUG
                                                  Serial.print("UNKNOWN Light - Message:");
                                                  Serial.print(message.getString());
                                                  Serial.print(" - Sensor:");
                                                  Serial.println(message.sensor);
                                            } else if (message.type == V_RGB){
                                              #ifdef MY_DEBUG
                                                if (Print_Debug) {Serial.println("message v_rgb");}
                                              String szMessage=message.getString();
                                              strcpy(Solid_RGB_Color, getValue(szMessage,'&',0).c_str());
                                              Solid_RGB_Active = 1;
                                            }else if (message.type == V_DIMMER) {// if DIMMER type, adjust brightness
                                              #ifdef MY_DEBUG
                                                if (Print_Debug) {Serial.println("message v_dimmer");}
                                              if (message.sensor==cID_RGB_SELECTOR){// is single Message
                                                if (Solid_RGB_Active==1){//turn RGB on
                                                Solid_RGB_Brightness = map(message.getLong(), 0, 100, 0, 255);
                                                CRGB colorRGB = str2CRGB(Solid_RGB_Color);
                                                CHSV colorHSV = rgb2hsv_approximate(colorRGB);
                                                colorHSV = CHSV(colorHSV.h, colorHSV.s, Solid_RGB_Brightness);
                                                Event_SetLEDColors(colorHSV);
                                                #ifdef MY_DEBUG
                                                  if (Print_Debug) {
                                                    Serial.print("colorHSV.h:");
                                                    Serial.println(colorHSV.h);
                                                    Serial.print("colorHSV.s:");
                                                    Serial.println(colorHSV.s);
                                                    Serial.print("colorHSV.v:");
                                                    Serial.println(colorHSV.v);
                                                Event_SendLastColor();
                                              } else if (message.sensor==cID_CYCLE_EFFECT_SPEED){// is Speed dimmer Message
                                                Cycle_Effect_Speed = map(message.getLong(), 0, 100, 1, 202);
                                                #ifdef MY_DEBUG
                                                  if (Print_Debug) {
                                                    Serial.print("Cycle_Effect_Speed: ");
                                                    Serial.println(Cycle_Effect_Speed);
                                            }else if (message.type == V_STATUS) {           // if on/off type, toggle brightness
                                              #ifdef MY_DEBUG
                                                if (Print_Debug) {Serial.println("message v_status");}
                                              Solid_RGB_Active = message.getInt();
                                              Cycle_Effect_Active = 0;
                                                if (Print_Debug) {Serial.println("Strip OFF");}
                                              }else{
                                                if (Print_Debug) {Serial.println("Strip ON");}
                                                Event_SetLEDColors(strtol(Solid_RGB_Color, NULL, 16));
                                              //Event_SendLastColor();
                                            }else if (message.type==V_VAR1) {            // color status
                                              #ifdef MY_DEBUG
                                                if (Print_Debug) {
                                                  Serial.println("message v_var1");
                                                  Serial.println(szMessage);
                                            Status_Change = true;
                                          // ## Events
                                          void Event_LightCycle(bool t, bool s, bool u) {
                                            Cycle_Effect_Active = (t) ? 1 : 0;
                                            if (u){
                                              send(MySeonsors_MSG_CYCLE_EFFECT.set(Cycle_Effect_Active),MySensors_RequestACK);
                                          void Event_SolidColor(bool t, bool s, bool u) {
                                            Solid_RGB_Active = (t) ? 1 : 0;
                                            if (u){
                                              send(MySensors_MSG_RGB_Selector.set(Solid_RGB_Active),MySensors_RequestACK);
                                          void Event_SetLEDColors( const CRGB& rgb){
                                            analogWrite(PIN_RED,   rgb.r );
                                            analogWrite(PIN_GREEN, rgb.g );
                                            analogWrite(PIN_BLUE,  rgb.b );
                                          void Event_SendLastColor(){
                                            String current_status=Solid_RGB_Color+String("&")+String(Solid_RGB_Brightness)+String("&")+String(Solid_RGB_Active);
                                            send(MySensors_MSG_Last_Color.set(current_status.c_str()),MySensors_RequestACK);
                                          void Event_RunCycleEffect(unsigned long theMills){
                                            if (theMills - Cycle_Effect_pMillis >= Cycle_Effect_Speed){
                                              Cycle_Effect_pMillis = theMills;
                                              Cycle_Effect_Current_Hue = Cycle_Effect_Current_Hue + 1;
                                              Event_SetLEDColors( CHSV( Cycle_Effect_Current_Hue, 255, 255) );
                                          void Event_ColorTestBars(){// Event_ColorTestBars: flashes Red, then Green, then Blue, then Black. Helpful for diagnosing if you've mis-wired which is which.
                                            Event_SetLEDColors( CRGB::Red );   delay(500);
                                            Event_SetLEDColors( CRGB::Green ); delay(500);
                                            Event_SetLEDColors( CRGB::Blue );  delay(500);
                                            Event_SetLEDColors( CRGB::Black ); delay(500);
                                          // ## Helper Functions
                                          String getValue(String data, char separator, int index){
                                           int found = 0;
                                            int strIndex[] = {0, -1};
                                            int maxIndex = data.length()-1;
                                            for(int i=0; i<=maxIndex && found<=index; i++){
                                              if(data.charAt(i)==separator || i==maxIndex){
                                                found++;
                                                strIndex[0] = strIndex[1]+1;
                                                strIndex[1] = (i == maxIndex) ? i+1 : i;
                                            return found>index ? data.substring(strIndex[0], strIndex[1]) : "";
                                          int x2i(char *s) {
                                            int x = 0;
                                            for(;;) {
                                              char c = *s;
                                              if (c >= '0' && c <= '9') {
                                                x *= 16;
                                                x += c - '0';
                                              }else if (c >= 'A' && c <= 'F') {
                                                x *= 16;
                                                x += (c - 'A') + 10;
                                              }else {
                                                break;
                                              s++;
                                            return x;
                                          char* str2char(String command){
                                              if(command.length()!=0){
                                                  char *p = const_cast<char*>(command.c_str());
                                                  return p;
                                          CRGB str2CRGB(String s){
                                            String r = str2char(s.substring(0,2));
                                            String g = str2char(s.substring(2,4));
                                            String b = str2char(s.substring(4,6));
                                            uint8_t red = x2i(r.c_str());
                                            uint8_t green = x2i(g.c_str());
                                            uint8_t blue = x2i(b.c_str());
                                            #ifdef MY_DEBUG
                                              if (Print_Debug) {
                                                Serial.print("r:");
                                                Serial.println(r);
                                                Serial.print("g:");
                                                Serial.println(g);
                                                Serial.print("b:");
                                                Serial.println(b);
                                                Serial.print("red:");
                                                Serial.println(red);
                                                Serial.print("green:");
                                                Serial.println(green);
                                                Serial.print("blue:");
                                                Serial.println(blue);
                                            CRGB colorRGB = CRGB(red, green, blue);
                                            return colorRGB;
                                          Hopefully this proves useful to someone :)
