  3. Mosfet with Ceech board
6 Posts 3 Posters 2.5k Views 4 Watching
  • JodailleJ
    JodailleJ
    Jodaille
    wrote on last edited by Jodaille
    I would like to use the mosfet of the Ceech board: ATmega328p board w/ NRF24l01+ socket LTC4079
    In the doc is indicated that it is wired do digital 3.
    I have modified the "blink without delay" sketch
    const int MOSFET = 3;
    int loadState = LOW;
    unsigned long previousMillis = 0;
    const long interval = 2000;
      // put your setup code here, to run once:
      pinMode(MOSFET, OUTPUT);
      digitalWrite(MOSFET, HIGH);
      Serial.begin(9600);
      if (currentMillis - previousMillis >= interval) {
        // save the last time you blinked the LED
        previousMillis = currentMillis;
        // if the LED is off turn it on and vice-versa:
        if (loadState == LOW) {
          loadState = HIGH;
        } else {
          loadState = 0;
        // set the LED with the ledState of the variable:
        digitalWrite(MOSFET, loadState);
        Serial.print("state: ");Serial.println(loadState);
    I don't understand how it works, I have tried to measure continuity with a voltmeter, I have tried to wire a led between vcc, cuting the gnd with the mosfet without success.
    Does anyone would be explain how I can use it ?
    Ceech board with led
    I would like to make an electrical barrier to protect my beehive from vespa velutina using a mosquito racket :
    Racket
    vespa velutina
    YveauxY 1 Reply Last reply
    • JodailleJ Jodaille
        Serial.begin(9600);
            loadState = HIGH;
          } else {
            loadState = 0;
      Racket
      vespa velutina
      YveauxY
      YveauxY
      @Jodaille without looking at schematics I'd say you will kill/have killed the led if you don't put a current limiting resistor (few hundred ohms) in series with it.
      • rvendrameR
        rvendrameR
        rvendrame
        You need to connect the LED (+resistor) like this:
        • Positive: Vcc Pin
        • Negative: The pin with the orange/brown wire in your picture.
          the mosfet onboard is N-channel, so it will switch the negative (GND) line.
        ESP8266 GW + mySensors 2.3.2
        Alexa / Google Home
        • JodailleJ
          JodailleJ
          Jodaille
          Hello @Yveaux, hello @rvendrame: thank you.
          the led is still alive :-)
          With the sketch , I can see the led blinking if it is wired between gnd and d3.
          @rvendrame I should miss something because the led stay off with your instructions.
          Maybe @ceech will see this my SOS :-)
          rvendrameR 1 Reply Last reply
            rvendrameR
            rvendrameR
            rvendrame
            @Jodaille , it works for me, when wiring the led between Vcc and the non-named pin where you put that orange (or brown?) wire. There is where I found the MOSFET N-channel drain is connected.
            Alexa / Google Home
            JodailleJ 1 Reply Last reply
            • rvendrameR rvendrame
              JodailleJ
              JodailleJ
              Jodaille
              Thank you @rvendrame ,
              it works, I attach a Ceech's schema, using D4 instead of D3 :-)
