  3. VEML6070 and VEML6075 UV sensors
52 Posts 6 Posters 20.8k Views 5 Watching
  • alexsh1A
    alexsh1A
    alexsh1
    #21
    I finally received VEML6075 and comparing it with VEML6070 side y side
    _____UVI__UVA__UVB
    6070 0.9
    6075 1.2 1036.53 1005.31
    Not sure why there is a difference in UVI
    • korttomaK
      korttomaK
      korttoma
      Did anyone measure the current consumption of these VEML chips?
      I just compared a Sensebender Micro with the VEML6075 to a standalone Sensebender Micro and the standalone one measured 28uA and the one with the VEML6075 measured 740uA.
      I just checked the VEML6075 documentation and typical consumption is 480uA but it should also be possible to shut it down and then it should only draw 800nA.
      I need to check the Lib if there is some function to shut it down and wake it up. Or else I will try to change the setup so I can power the VEML6075 from an output pin so I can turn it completely off.
      • Tomas
      scalzS 1 Reply Last reply
      • korttomaK korttoma
        scalzS
        scalzS
        @korttoma
        if i remember, sleep is not implemented in the veml6075 lib above. I added a sleep function and set the corresponding CONF register. not a big thing ;)
        korttomaK 1 Reply Last reply
        • scalzS scalz
          @korttoma
          korttomaK
          korttomaK
          korttoma
          #24
          @scalz please share your sleep function implementation :D it is quite a "big thing" for a non programmer.
          • Tomas
          • scalzS
            scalzS
            wrote on last edited by scalz
            #25
            @korttoma you can try this, and you'll see it's not a big thing :smile:
            in your .h, in the public section, add this:
            void sleep(bool mode);
            then in the .cpp, add this:
            void VEML6075::sleep(bool mode) {
            	if (mode)
            		this->config |= 1; // Go to sleep
            	else
            		this->config &= 254; // Wake up
            	this->write16(VEML6075_REG_CONF, this->config);
            In your sketch, just do this:
            veml6075.sleep(true); // power down veml6075
            Note: i added this because i noticed it wasn't implemented, but i've not checked the power consumption yet. So if you can tell me if it's ok, please!
            Enjoy ;)
            korttomaK alexsh1A 2 Replies Last reply
            • scalzS scalz
              	if (mode)
              	else
              Enjoy ;)
              korttomaK
              korttomaK
              korttoma
              @scalz thanks for the sleep function! The current consumption is now down to 85uA but the problem is that onece it sleeps I cant get it to wake up.
              Tried with:
              veml6075.sleep(false);
              Tried allso adding a 500ms sleep after the wakeup to give it time to setle.
              But do I need to do something more?
              • Tomas
                Tried with:
                scalzS
                scalzS
                #27
                @korttoma sorry for the copy/paste mistake :) you can try again, i've updated above. maybe someday i'll measure power consuption of a sensebender, weird that you get 28uA for the standalone..
                • scalzS scalz
                  korttomaK
                  korttomaK
                  korttoma
                  #28
                  @scalz seems to be working now :D don´t take my current consumtion figures to sareously since Im using the Micro (nano) ampere meter and I realy have nothing good to calibrate it against.
                  • Tomas
                  • alexsh1A
                    alexsh1A
                    alexsh1
                    I have a strange problem. VEML6070 is showing UV Index 6, which is more or less in line with other online sources. VEML6075 is showing UV index 10.5, which is wrong. I'll double check the sketch once more but cannot understand where this error comes from
                    • korttomaK
                      korttomaK
                      korttoma
                      #30
                      I mounted the Sensebender Micro VEML6075 inside my old broken UVN800 and set it in the roof. Here are graphs of the values I received the last 3 days. Unfortunately I do not have anything to compare with but the values seem reasonable.
                      • Tomas
                      • scalzS scalz
                        	if (mode)
                        	else
                        Enjoy ;)
                        alexsh1A
                        alexsh1A
                        alexsh1
                        @scalz FYG, I am using VEML6075 without sleep and it works now for nearly a year on 2xAA. I am still puzzled though by Index difference 6070 and 6075
                        • korttomaK
                          korttomaK
                          korttoma
                          Yeah, my 6075 device is also still working fine on the 2xAA batteries I put in it a year ago.
                          • Tomas
                          alexsh1A 1 Reply Last reply
                          • alexsh1A
                            alexsh1A
                            alexsh1
                            OK, I think found what the issue is. VEML 6070 is not providing accurate UV Index. Adafruit is stating the following:
                            Note that this is not UV index, its just UV light intensity!
                            This is how it can be converted into sort of UV Index according to the datasheet:
                            RISK_LEVEL convert_to_risk_level(WORD uvs_step)
                            WORD risk_level_mapping_table[4] = {2241, 4482, 5976, 8217};
                            WORD read_uvs_step(void)
                            BYTE lsb, msb;
                            WORD data;
                            VEML6070_read_byte(VEML6070_ADDR_DATA_MSB, &msb);
                            VEML6070_read_byte(VEML6070_ADDR_DATA_LSB, &lsb);
                            data = ((WORD)msb << 8) | (WORD)lsb;
                            return data;
                            LEVEL* UV Index
                            LOW 0-2
                            MODERATE 3-5
                            HIGH 6-7
                            VERY HIGH 8-10
                            EXTREME >=11
                              alexsh1A
                              alexsh1A
                              alexsh1
                              #34
                              @korttoma @scalz FYG I got a new DMM from Dave Jones 121GW and decided to measure a sleep current for VEML6075 and to my surprise:
                              Quickly reading the datasheet I discovered my mistake:
                              • current supply - 480uA
                              • shutdown current - 800nA
                              Therefore, the sensor has to be put to sleep properly.
                              One can modify the existing lib:
                              uint8_t VEML6075::Shutdown() {  //Places device in shutdown low power mode
                              	Config = ReadByte(CONF_CMD, 0); //Update global config value
                              	return WriteConfig(Config | 0x01); //Set shutdown bit
                              uint8_t VEML6075::PowerOn() {  //Turns device on from shutdown mode
                              	return WriteConfig(Config & 0xFE); //Clear shutdown bit
                              Make sure you define #define CONF_CMD 0x00
                              PS Now I understand why I did not change batteries - they are rechargeable. Charing and putting them back made me think that batteries lasted for a long time. :relaxed:
                              • alexsh1A
                                alexsh1A
                                alexsh1
                                I have now three sensor from Vishay - VEML6040, VEML6070 and VEML6075
                                I can confirm all three sensors must be property put down to sleep with battery nodes or you would have the following sleeping currents on nodes with typical mysensors setup and standalone sleeping current of 4uA:
                                VEML6040 - 240uA
                                VEML6070 - 94uA
                                VEML6075 - 622uA
                                Unfortunately, most libraries do not care for properly sleeping/waking up sensors and therefore, one has to do a little tinkering with software to make it work. I am actually thinking about re-writing some libs completely.
                                • A
                                  A
                                  Avamander
                                  Battery issues is one thing, SparkFun's VEML6075 library can't handle direct daylight even (compensated UV readings go negative).
                                  • A Avamander
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @avamander That's impossible - it is designed to handle the direct sunlight. Mine is showing UV Index = 9. Negative UV reading is a software issue - looks like Sparkfun did not write a good lib for it. Did you try a different lib?
                                    • alexsh1A alexsh1
                                      A
                                      A
                                      Avamander
                                      wrote on last edited by Avamander
                                      #38
                                      @alexsh1
                                      Haven't bothered, I'm just logging the raw values and then compensating with software.
                                      • A Avamander
                                        @alexsh1
                                        alexsh1A
                                        alexsh1A
                                        alexsh1
                                        @avamander It definitely works.
                                        My problem for now was just the battery consumption. I have one of these:
                                        https://www.aliexpress.com/item/I2C-Interface-3-3V-Board-Based-on-VEML6075-UVA-UVB-Light-Sensor-Module/32832979057.html?spm=2114.search0104.3.1.5f765e65b6nG8K&ws_ab_test=searchweb0_0,searchweb201602_3_10152_10151_10065_10344_10130_10068_10324_10342_10547_10325_10343_10340_10548_10341_10696_10192_10190_10084_10083_10618_10307_10820_10301_10821_10303_10059_100031_10103_524_10624_10623_10622_10621_10620,searchweb201603_25,ppcSwitch_7&algo_expid=c6a42de3-1e19-435c-af06-c3a9b24d4ca3-0&algo_pvid=c6a42de3-1e19-435c-af06-c3a9b24d4ca3&priceBeautifyAB=0
                                        The problem is that it is dodgy - the sleep consumption never goes below 50uA at 3.2V. According to the datasheet it should be 800nA while sleeping at 1.8V and 25C. Can anyone measure a shutdown current for VEML6085 please?
                                        • alexsh1A alexsh1
                                          A
                                          A
                                          Avamander
                                          @alexsh1 I have the same board, there seems to be a regulator and a few other components on the board, if you remove those, how's the power consumption then?
