  3. nRF5 action!
nRF5 action!
  • M Mike_Lemo
    @mtiutiu And when you want to program an independent chip with the ST link V2 do you just chose "generic nrf52"?
    Also how is it possible to connect between through two NRF52s in slave master config?
    Is it possible to take advantage of the NFC functionality with that programming environment?
    mtiutiuM
    mtiutiuM
    mtiutiu
    wrote on last edited by mtiutiu
    #261
    @Mike_Lemo
    I used generic and no soft device as Mysensors doesn't use soft devices. I don't know about master-slave, didn't used such a configuration.
    You need to create another variant for other pin definitions as this is the way arduino framework works as far as I know.
    Never used NFC so I can't give you hints on that, sorry.
    • NeverDieN
      NeverDieN
      Looks as though these guys came up with a fairly easy way to develop using actual bluetooth low energy: http://mklec.com/project-kits/kd-circuits/bluetooth-low-energy-board-anaren-A20737-module
      Unfortunately, I don't believe it runs on the nRF5 though.
      • NeverDieN NeverDie
        Looks as though the nRF52832 sparkfun board has more of a conventional trace antenna:
        though isn't it somewhat odd that it appears to also be directly connected to the ground plane(?), or at least a copper pour. Is that normal? This was one of the images produced by sending their .BRD file to oshpark, so that I could get a look at the antenna.
        NeverDieN
        NeverDieN
        More good news! I was able to program a Sparkfun nrf52832 board using the DK, and its range is better than the Adafruit nRF52832 Feather and also better than an nRF24L01+.
        So, my provisional conclusion is to avoid chip antennas, such as Adafruit is using, if better range is desired.
        Also, this now gives me a "known good" platform, namely the Sparkfun nRF52832 board, to order PCB's for and try to see if I can successfully solder on any of the bonus nRF52832 chips I received with my two DK's.
        • NeverDieN
          NeverDieN
          #264
          Apparently you can now run micropython on an nRF52832 board:
          https://www.youtube.com/watch?v=50ImTDRREnU
          It's still early days, but it sounds like fun. For one thing, since it's a dynamic language, OTA updates should be easy!
          TerrenceT 1 Reply Last reply
            TerrenceT
            TerrenceT
            Terrence
            @NeverDie Wow, that it really good news. I was following Tony's videos on mpy on the ESP chips, but had not checked back lately.
            • Nca78N Nca78
              @NeverDie yes noticed their shop only 2 days ago and feeling frustrated now :D
              For shipment delay I wouldn't be surprised if they shipped the same way with free option and it would just be a different way to state the delay on the 2 websites...
              NeverDieN
              NeverDieN
              #266
              @Nca78 said in nRF5 Bluetooth action!:
              You were right: I received both the ebay and the aliexpress packages today. Even for e-packet, that's pretty fast shipping! In fact, they arrived before any of the other items I ordered from other vendors. So, at least that part went well.
              • NeverDieN
                NeverDieN
                Does the E73-2G4M04S require anything extra in order to be programmed?
                Today I tried programming it the same way that I have successfully with both the adafruit and the Sparkfun nRF52832 boards using the DK, but the DK keeps complaining that the E73-2G4M04S may not be connected.
                Nca78N 1 Reply Last reply
                  Nca78N
                  Nca78N
                  @NeverDie if I remember well in the datasheet they say you have to put the softdevice on it first.
                  scalzS 1 Reply Last reply
                  • NeverDieN
                    NeverDieN
                    Yeah, here's what it says:
                    1. The module embedded with ARM MCU. For program downloading, please use the J-LINK downloader, any other serial port or JTAG、ISP、ICP are
                      unavailable to download.
                    2. There’s two parts to download the program. Because the protocol stack
                      of NORDIC is not programmed yet, so users need to use the official nRFgo
                      studio of NORDIC to program the protocol stack first, then program the hex of application code. Or, to program the protocol stack of NORDIC first and
                      download via the IAR or KEIL.
                    Seems odd, but I'll give it a try.
                    • NeverDieN
                      NeverDieN
                      It's not clear whether the DK can/should be used for this part of it, as it's unclear (at least to me) whether it will end up altering the target chip or the DK. I'm just not sure. So, to do at least this ambiguous part of it, I'll first check whether or not the nRFgo studio software will work with one of the other programmers I've collected (not the DK). That may take a while...
                      mtiutiuM JokgiJ 2 Replies Last reply
                        mtiutiuM
                        mtiutiuM
                        mtiutiu
                        #271
                        @NeverDie
                        Why don't you try to program it with a st-link programmer and arduino ide with sandeepmistry nrf5 core installed? I bought that module(E73-2G4M04S) too and I want to know how this part goes. Thanks.
                        • Nca78N Nca78
                          scalzS
                          scalzS
                          wrote on last edited by scalz
                          #272
                          @NeverDie
                          you need to do this if you're using ble, it's the nordic stack running ble etc behind the scene.
                          For using nrf52 with MySensors, you don't need to do this. Also, MySensors & the softdevice can't run at the same time for the moment afaik.
                          this module should work like others module, by following nrf52 datasheet.
                          looking at their datasheet, you maybe could add (i don't know if it's already onboard):
                          • 100pf on DEC2
                          • 0.1uf on DEC1 (but they have no DEC1 1) it's already onboard, 2) there is a typo error on their datasheet ?? as DEC5 doesn't exist on nrf52)
                          • decoupling power
                          then it's just a matter of swd programming (3v,gnd,DIO,CLK)
                          You can take a look at nordic datasheet, or adafruit howtos are nice too.
                          NeverDieN 1 Reply Last reply
                          • scalzS scalz
                            @NeverDie
                            • 100pf on DEC2
                            • decoupling power
                            NeverDieN
                            NeverDieN
                            #273
                            @scalz said in nRF5 Bluetooth action!:
                            Great catch! Based in part on proximity to the DEC1 pins in the Ebyte datasheet, I'm guessing you've nailed it and that "DEC5" is actually DEC1.
                            Here's Nordic's pinout:
                            For other readers'convenience, here is a link (courtesy of NCA78) to Ebyte's datasheet:
                            https://forum.mysensors.org/assets/uploads/files/1499826952956-e73-2g4m04s_datasheet_en_v1.1.pdf
                            Besides, as you point out, there is no actual DEC5 according to the Nordic pinout, so what else could "DEC5" be?
                            I've just now emailed the seller to ask this question, but for now I'll assume you've nailed it. Great work!
                            • NeverDieN
                              NeverDieN
                              #274
                              Seems as though we're somewhat shooting in the dark, though, without a schematic of what Ebyte actually did on the module. For instance, I had assumed that all this (plus whatever else is needed) had already been implemented on the Ebyte module. Relative to the Nordic nRF52832 chip size, the Ebyte moduile is already a pretty big module!
                                Mike_Lemo
                                I'm tring to blink an led on a PCB I made not realy knowing how to program the IC before other than connection the SWD pins.
                                I've followed the startup guide at github flashed the soft device probably successful using the ST link V2(while flashing the soft device it blinked the on board st link V2 led and at the end the blue led on my PCB stopped being on.)
                                So I've got an RGB led connected to my PCB to pins:
                                #define RGBL_RED_PIN P0.16
                                #define RGBL_GREEN_PIN P0.15
                                #define RGBL_BLUE_PIN P0.17
                                now for a test to see if I got it right I want to blink each of them how would I do it?
                                What is the arduino pin mapping?
                                  NeverDieN
                                  NeverDieN
                                  #276
                                  On the other hand, I suppose if Ebyte had already decoupled DEC1 and DEC2 with caps on their module, there'd be no point in exposing those pins. So, I guess by inference, they must not already be decoupled. Is that the idea?
                                  • M Mike_Lemo
                                    NeverDieN
                                    NeverDieN
                                    #277
                                    @Mike_Lemo said in nRF5 Bluetooth action!:
                                    Isn't the arduino mapping generally handled by the boards.txt file? Which board that you're using are you telling the compiler that it is? i.e. which board under the board manager in the Arduino IDE are you selecting?
                                    M 2 Replies Last reply
                                      Mike_Lemo
                                      Actually never mind I got it just removed the P0. and put the number for example if I want to flash P0.16 I do 16 and it works!!
                                      Feels so good to understand that I can now finish my big project now all I have to figure out it how to use NFC and connect it to another NRF52832 device!
                                      Here's a demo:
                                      https://www.youtube.com/watch?v=hCMKsORq2sM&feature=youtu.be
                                        Mike_Lemo
                                        @NeverDie
                                        Oh yeah and forgot to mention I used the generic NRF52 settings.
                                        d00616D 1 Reply Last reply
                                        • NeverDieN
                                          NeverDieN
                                          #280
                                          Aha! I just now noticed that on the silk screen for the actual module itself, it does indeed say DEC1, not DEC5, in what would otherwise be the DEC5 location. So, that settles it. "DEC5" really is DEC1, and "DEC5" is just a typo in the datasheet. :)
