  3. nRF5 action!
nRF5 action!
  • T Toyman
    you can buy it on a breakout for around $2.50
    do you have an example? The lowest I can find is ca. $4 (incl.S&H).
    Don't get me wrong, $4 is more then adequate for 328+24L01 replacement, but $2.5 is even better :-)))
    Nca78N
    Nca78N
    @Toyman said in nRF5 Bluetooth action!:
    Type nrf51822-04 in AliExpress search bar, you will find the cheapest module. Not many pins broken out because it's supposed to be used as a Bluetooth interface, but it's enough for many applications like door sensor, switches, etc etc
    https://www.aliexpress.com/item/NRF51822-04-BLE4-0-Wireless-Bluetooth-Module-TTL-Low-Power-Consumption-3-3V-New/32821044213.html
    T NeverDieN 2 Replies Last reply
    • Nca78N Nca78
      Toyman
      @Nca78 cool, thx
      • T Toyman
        @d00616 absolutely excellent summary, thank you.We definitelly needed some kind of "what do we know so far"
        Is it confirmed that the range and power consumption are on par with 328+24L01 combo? I don't mean any "scientific" proof, but something like "I have placed nrf52 node at the same location in my house as nrf24 node and had no issues"
        I am awaiting components to make "u-current meter" and test current consumption by myself
        NeverDieN
        NeverDieN
        Yes, it's better in both dimensions.
        • JokgiJ Jokgi
          @NeverDie Check out the new nRF52810. It is a stripped down version of the nRF52840.. Not as much memory and the peripherals are lower in count. But it has a Cortex M4 (Not F) and some of the targets are sensors, wearable, beacons, etc. On air compatible with nRF24L series and nRF52 series. Some limitations on BT 5.0 however.
          d00616D
          d00616D
          d00616
          @Jokgi said in nRF5 Bluetooth action!:
          Where are the long range BLE modes? I think long range BLE modes are one of the best features of the 840 series.
          T 1 Reply Last reply
          • d00616D d00616
            Toyman
            @d00616 not supported by 52810
            • Nca78N Nca78
              NeverDieN
              NeverDieN
              #1106
              @Nca78
              I just now posted a small breakout board for it: https://www.openhardware.io/view/483
              • T
                Toyman
                wrote on last edited by Toyman
                #1107
                What's the proper way to deal with interrupts on nrf?
                Many white areas:
                • shall I use "smartsleep()" instead of usual arduino way of attaching interrupts? is it enough?
                • what pins have hardware interrupts? any?
                • what about the macro mentioned in d00016 readme?
                • how to overcome nrf51 bug of 1ma power consumption (code-wise)? Otherwise I see no reason buying nrf51 modules if they consume 1ma while sleeping
                I thoroughly read al the docs before asking!
                NeverDieN d00616D 2 Replies Last reply
                • T Toyman
                  Many white areas:
                  NeverDieN
                  NeverDieN
                  #1108
                  Welcome to the bleeding edge. I'm only aware of the one way, which is how @d00616 does it in his example code above. It seems like this part of the code is still (?) under development. For instance, the HW supports multiple interrupts being active at the same time, whereas the current code seems to support at most one interrupt.
                  • NeverDieN NeverDie
                    Toyman
                    #1109
                    @NeverDie wait, d00616 code is basically an extension of Sandeep's. The Sandeep's code (should) supports 8 interupts for nrf52 and 4 - for nrf51.
                    At least, that's what I conclude from here
                    Assuming it works, the next question is: can I put just ANY pin into attachinterrupt() function or not?
                    • NeverDieN
                      NeverDieN
                      I made this adapter to aid with collecting serial debug output from the last two nRF5 breakout boards:
                      https://www.openhardware.io/view/484/IDC-10-pin-ARM-debug-adapter
                      • T Toyman
                        Many white areas:
                        d00616D
                        d00616D
                        d00616
                        Many white areas:
                        There is an limit in the number of monitored pins but not which pins are monitored.
                        This macro is required on NRF52 to read back event registers in interrupts. This clears the cache.
                        This depends on the nRF51 chip release. The first available chip release has this type of bug. I prefer nRF52 because the chip is much more flexible with better radio characteristics.
                        The flexibility of nRF5 MCUs starts with the interrupt vector in RAM. This allows to add bootloaders without adding latency or you can replace interrupts which are predefined in the arduino-nrf5 software.
                        NeverDieN 1 Reply Last reply
                        • d00616D d00616
                          Many white areas:
                          NeverDieN
                          NeverDieN
                          So, it's a hardware bug then? i.e. nothing can really be done about it for that chip release?
                          d00616D 1 Reply Last reply
                            d00616D
                            d00616D
                            d00616
                            There is a second method via GPIO -> pin sense for interrupt detection. This method requires less power, but you have to detect which pin is changed in software. Simulating a pin change interrupt is more complicated as detecting high or low level. I have started to do some researches and tests, but in my opinion it's to much work to support these outdated chip variants.
                            • NeverDieN
                              NeverDieN
                              Motivated by the above, I just now did some current tests on the nRF52832 and found that:
                              1. Going directly to an RTC sleep after powerup consumes 2.2ua.
                              2. Enabling DCDC doesn't increase that.
                              3. Nor does blinking an LED and then putting that pin into a disconnected state (D0) before sleep.
                              HOWEVER,
                              4. Activating Serial using Serial.begin(..) before sleep causes the current drain during sleep to rise to around 10.8ua. That was surprising to me, because this code in hwSleep(..) seems geared toward turning OFF serial prior to sleep:
                                // Idle serial device
                                NRF_UART0->TASKS_STOPRX = 1;
                                NRF_UART0->TASKS_STOPTX = 1;
                                NRF_UART0->TASKS_SUSPEND = 1;
                              So, I guess more is needed there?
                              • d00616D d00616
                                Toyman
                                @d00616 thx. How do I use the macro? Just put in ISR?
                                Regarding the bug: if read the docs correctly, all nrf51 have the bug :-(
                                  HOWEVER,
                                  Toyman
                                  @NeverDie do you use hwSleep() instead of sleep()?
                                  • T Toyman
                                    NeverDieN
                                    NeverDieN
                                    Yes.
                                    • NeverDieN
                                      NeverDieN
                                      OK, I found that adding:
                                        NRF_UART0->ENABLE=0;  //disable UART0
                                      brings the current consumption back down to 2.2ua during sleep. :)
                                      T d00616D 2 Replies Last reply
                                        Toyman
                                        @NeverDie should it be placed just before hwSleep()?
                                        • T Toyman
                                          NeverDieN
                                          NeverDieN
                                          #1120
                                          It's just a possible preliminary piece of the solution, because you'll need to renable UART0 after waking up from sleep. I haven't tested to see whether Serial.print(..) still works after re-enabling, or whether it needs to be re-initialized. Those are details yet to be sorted.
                                          Or, maybe there's some other way of doing it. At this point, I'm just reporting my finding and tossing it out there as a tantalizing possibility.
