nRF5 action!
@d00616 thx. How do I use the macro? Just put in ISR?
Regarding the bug: if read the docs correctly, all nrf51 have the bug :-(@Toyman said in nRF5 Bluetooth action!:
Yes. Give the event register as parameter.
This bug is listed as PAN#39 and fixed at the end of 2014.
OK, I found that adding:
NRF_UART0->ENABLE=0; //disable UART0brings the current consumption back down to 2.2ua during sleep. :)
Great work. Are you able to build an Pull Request fixing this? This Pull request should also be tested in the condition with a disabled serial port.
If you need help, please ask. I do the reviews.
What is it that I submit? A diff file or something? And I'm guessing I do it through github?
Just re-enabling the UART isn't enough. Nor are the existing UART related instructions after a wake-up, if UART0 was disabled. It seems to require a re-initialization. Another Serial.begin(BAUDRATE) after wake-up does work. However, I should point out that doing that isn't free, as it adds to wake-up time. So, you may wish to add another "level" of sleep, one which saves more energy while sleeping but at the cost of a longer wake-up. Moreover, the energy consumed during the longer wakeup isn't free either, so if the sleeps are very short, you could lose more energy for using it than not. One may, therefore, also want to calculate the breakeven point to provide guidance on when to use which level of sleep.
In short, this is more than a simple fix, and the software architect probably needs to consider the bigger picture in order to craft the best solution.
Guys,
Have you seen this?
Note, that our beloved ebyte is not there, but PTR9618PA is
It's useful. But just knowing the module exists is one thing. Finding a source for it is another.
Guys,
Have you seen this?
so, if I have an intterupt atached to pin 1, what shall i put into ISR?
NRF_RESET_EVENT....;
Sorry for dumb questions, this is completely new to me.@Toyman said in nRF5 Bluetooth action!:
With arduino-nrf5, you can't put nothing into the pin interrupt ISR because the ISR is already defined.
There are no dumb questions, there are bad answers.
There is and document describing the procedure: https://www.mysensors.org/download/contributing
I think this is a good document to start with. If you have trouble, please ask.
@d00616
The solution I'm going with, which serves my present needs, is just to put all serial communications code within "DEBUG" compiler directives. So, if I'm not debugging, the issue just goes away, and there's no added overhead. :)@NeverDie said in nRF5 Bluetooth action!:
@d00616
The solution I'm going with, which serves my present needs, is just to put all serial communications code within "DEBUG" compiler directives. So, if I'm not debugging, the issue just goes away, and there's no added overhead. :)Found a shortcut. Instead of doing all that, which is extra work and looks ugly too, I just disabled the UART0 on the first sleep, and then never re-enabled it. It works.Now my sleep current is just 2.1ua, except for the brief pulses every 100ms where the PPI listens for an incoming packet addressed to it. :) -
I was just checking the nRF51 datasheet, and I don't see much, if any, PPI control available. So, I suppose that's yet another reason for preferring the nRF52....
Nonetheless, I just now measured the sleep current on the cheap nRF51822 that @NCA78 referenced:
https://www.aliexpress.com/item/NRF51822-04-BLE4-0-Wireless-Bluetooth-Module-TTL-Low-Power-Consumption-3-3V-New/32821044213.html?aff_platform=aaf&cpt=1507850033284&sk=e2Vzr3v&aff_trace_key=fa8ec197f200446fbd58fc8679ffb3bd-1507850033284-07709-e2Vzr3v&terminal_id=29bfb7ff18284b7f96acb3c3884390ce
It measures at 5ua, which is higher than the 2.1ua of the nRF52832, but still not bad in absolute terms. I was afraid after the discussion of how some nrf51's had a 1ma bug in the hardware that they would be counted among them. Fortunately, it seems not. :) -
It measures at 5ua, which is higher than the 2.1ua of the nRF52832, but still not bad in absolute terms. I was afraid after the discussion of how some nrf51's had a 1ma bug in the hardware that they would be counted among them. Fortunately, it seems not. :)@NeverDie The nRF51 is done on a different process then then the nRF52. The nRF52 is on average 50% lower power then the nRF51. The picture of the module shows a nRF51822QFAA Hx part which is a 256k flash, 16k Ram part REV 3. You can see all the revision number here: http://infocenter.nordicsemi.com/topic/com.nordic.infocenter.nrf51/dita/nrf51/compatibility_matrix/nRF51822_ic_revision_overview.html?cp=3_0_1
@NeverDie You may wish to check out the nRF51 Reference guide in addition to the datasheet. http://infocenter.nordicsemi.com/pdf/nRF51_RM_v3.0.1.pdf The PPI is located in section 16.
@Jokgi said in nRF5 Bluetooth action!:
Thanks! Doesn't look as though the nRF51822's PPI allows for FORK though, whereas the nRF52832 does.
Guys,
Have you seen this?
@NeverDie actually, I am suprised that many of these modules are available and at the prices lower than Ali.
For example:
http://www.fanstel.com/buy/bt832xe
They claim "BT832XE is the longest range Bluetooth 5 module, 1350 meters between 2 BT832XE with used with ANT060 antenna."
$23, shipped within US
Not bad, ah? -
One must be aware, that the gain of an antenna doesn't come from a magic amplification, but from direction.
Meaning, the higher the gain of an antenna is, the more directional it is.
For a sensor, let's say a window switch, that may end up in every mounting position you might imagine, this is NOT what you want.Neither do you want that for the gateway, that may be in the middle of the house, and should be able to receive transmissions from all directions.
@Uhrheber
It does look like they also have a PA on their module: http://www.fanstel.com/bt832x-bluetooth-5-module/It's a good find, as it looks as though they have a lot to choose from: http://www.fanstel.com/buy/
Also, as compared to the chinese vendors, I think it's more likely that they really did pass FCC, since it's based in the US. The fines to US companies for selling non-compliant stuff are pretty severe (enough to bankrupt a small company), whereas (it seems) the chinese vendors can dodge it. Hence, the joke that "CE" stands for "Chinese Exemption".
