  3. nRF5 action!
nRF5 action!
  • NeverDieN
    NeverDieN
    #1301
    Well, it could be within the bounds of measurement error, but it appears that dropping I2c and SPI has reduced the drain to 2.6ua.
    d00616D 1 Reply Last reply
    • NeverDieN NeverDie
      d00616D
      d00616D
      d00616
      Is I2C or SPI used somewhere in your code?
      NeverDieN 1 Reply Last reply
      • d00616D d00616
        NeverDieN
        NeverDieN
        Not in the current test code that I'm running.
          d00616D
          d00616D
          d00616
          Interesting. The SPI is rated with <1µA idle current. TWI has no idle current in the datasheet.
          • d00616D d00616
            NeverDieN
            NeverDieN
            #1305
            @d00616 Well, I suppose that's consistent with what I'm seeing, isn't it? i.e. not much effect.
            • NeverDieN
              NeverDieN
              #1306
              So far, UARTE is the biggest offender. Turning off and disabling that saves a lot of current.
              • NeverDieN
                NeverDieN
                #1307
                So, here is code which works! Many thanks to @d00616 and others for their helpful comments above.
                To keep from distracting, I stripped out the radio code, but you can easily insert your favorite brand of that.
                Basically, the sketch blinks an LED very briefly once every 5 seconds. Between blinks, it sleeps. However, if a leak is detected (which is equivalent to a button push), it wakes up immediately and blinks a lot. It runs on both nRF52832 and nRF51822. The sleep current is ~2.6ua on an nRF52832. To get sleep current that low, it is using the Low Power Comparator (LPCOMP) to watch for a change on the leak detector pin while the CPU sleeps.
                I haven't yet measured the sleep current consumption on an nRF51822, but I expect it would be something comparable.
                //This sketch is applicable to Coincell Multisensor nRF51822, version 10
                #define MY_CORE_ONLY
                #define IS_NRF51  //true iff the target is an nRF51.  If an nRF52, then comment this line out!
                #define I2C_INTERRUPT_PIN 3
                #define LEAK_DETECTION_PIN 2
                #include <nrf.h>
                volatile bool button_pressed=false;
                void blinkityBlink(uint8_t pulses, uint8_t repetitions) {
                  for (int x=0;x<repetitions;x++) {
                    for (int i=0;i<pulses;i++) {
                      digitalWrite(LED_BUILTIN,HIGH);
                      wait(20);
                      digitalWrite(LED_BUILTIN,LOW);
                      wait(100);
                      wait(500);
                void disableNfc() {  //only applied to nRF52
                #ifndef IS_NRF51
                  //Make pins 9 and 10 usable as GPIO pins.
                  NRF_NFCT->TASKS_DISABLE=1;  //disable NFC
                  NRF_NVMC->CONFIG=1;  // Write enable the UICR
                  NRF_UICR->NFCPINS=0; //Make pins 9 and 10 usable as GPIO pins.
                  NRF_NVMC->CONFIG=0;  // Put the UICR back into read-only mode.
                void turnOffRadio() {
                  NRF_RADIO->TASKS_DISABLE=1;
                  while (!(NRF_RADIO->EVENTS_DISABLED)) {}  //until radio is confirmed disabled
                void turnOffUarte0() {
                #ifndef IS_NRF51
                  NRF_UARTE0->TASKS_STOPRX = 1;
                  NRF_UARTE0->TASKS_STOPTX = 1;
                  NRF_UARTE0->TASKS_SUSPEND = 1;
                  NRF_UARTE0->ENABLE=0;  //disable UART0
                  while (NRF_UARTE0->ENABLE!=0) {};  //wait until UART0 is confirmed disabled.
                #ifdef IS_NRF51
                  NRF_UART0->TASKS_STOPRX = 1;
                  NRF_UART0->TASKS_STOPTX = 1;
                  NRF_UART0->TASKS_SUSPEND = 1;
                  NRF_UART0->ENABLE=0;  //disable UART0
                  while (NRF_UART0->ENABLE!=0) {};  //wait until UART0 is confirmed disabled.
                void turnOffAdc() {
                #ifndef IS_NRF51
                  if (NRF_SAADC->ENABLE) { //if enabled, then disable the SAADC
                    NRF_SAADC->TASKS_STOP=1;
                    while (NRF_SAADC->EVENTS_STOPPED) {} //wait until stopping of SAADC is confirmed
                    NRF_SAADC->ENABLE=0;  //disable the SAADC
                    while (NRF_SAADC->ENABLE) {} //wait until the disable is confirmed
                void turnOffHighFrequencyClock() {
                    NRF_CLOCK->TASKS_HFCLKSTOP = 1;
                    while ((NRF_CLOCK->HFCLKSTAT) & 0x0100) {}  //wait as long as HF clock is still running.
                void mySleepPrepare()
                  turnOffHighFrequencyClock();
                  turnOffRadio();
                  turnOffUarte0();
                void activateLpComp() {
                  //NRF_LPCOMP->PSEL=1; // monitor AIN1 (pin P0.03 on nRF52832 test board).
                  //while (!(NRF_LPCOMP->PSEL==1)) {} //wait until confirmed
                  NRF_LPCOMP->PSEL=3; // monitor AIN3 (pin P0.02 on nRF51822 for coincell_multisensor_v10)
                  while (!(NRF_LPCOMP->PSEL==3)) {} //wait until confirmed
                  NRF_LPCOMP->REFSEL=1;  // choose 1/4 VDD as the reference voltage
                  while (!(NRF_LPCOMP->REFSEL==1)) {} //wait until confirmed
                  NRF_LPCOMP->ANADETECT=1;  //detect UP events.
                  while (NRF_LPCOMP->ANADETECT!=1) {} //wait until confirmed
                  NRF_LPCOMP->INTENSET=B0100;  //Enable interrupt for UP event
                  while (!(NRF_LPCOMP->INTENSET==B0100)) {} //wait until confirmed
                  NRF_LPCOMP->ENABLE=1;  //Enable LPCOMP
                  while (!(NRF_LPCOMP->ENABLE==1)) {} //wait until confirmed
                  NRF_LPCOMP->TASKS_START=1;  //start the LPCOMP
                  while (!(NRF_LPCOMP->EVENTS_READY)) {}  //wait until ready
                  NVIC_SetPriority(LPCOMP_IRQn, 15);
                  NVIC_ClearPendingIRQ(LPCOMP_IRQn);
                  NVIC_EnableIRQ(LPCOMP_IRQn);
                void suspendLpComp() { //suspend getting more interrupts from LPCOMP before the first interrupt can be handled
                  if ((NRF_LPCOMP->ENABLE) && (NRF_LPCOMP->EVENTS_READY)) {  //if LPCOMP is enabled
                    NRF_LPCOMP->INTENCLR=B0100;  //disable interrupt from LPCOMP
                    while (NRF_LPCOMP->INTENCLR==B0100) {} //wait until confirmed
                void resumeLpComp() { //suspend getting interrupts from LPCOMP
                  hwInit();
                  hwPinMode(LED_BUILTIN,OUTPUT_D0H1);
                  disableNfc();
                  turnOffAdc();
                  activateLpComp();
                  blinkityBlink(2,1);  //Signify end of setup with two quick pulses.
                  mySleepPrepare();
                  sleep(5000);  //sleep for 5 seconds.
                  mySleepPrepare();  //An ounce of prevention: Turn-off HF clock, etc, ASAP to save power, just in case the library's sleep() routine resumed them.
                  if (button_pressed) {   //if a leak is detected
                    suspendLpComp(); //suspend LPCOMP to prevent multiple interrupts
                    blinkityBlink(10,3);  //blink a lot to show that a leak was detected.
                    button_pressed=false;  //Clear the semaphore
                    NRF_LPCOMP->EVENTS_UP=0;  //Clear the semaphore
                    resumeLpComp();  //operations of LPCOMP were suspended after detecting the LPCOMP iterrupt
                  else {
                    blinkityBlink(1,1);  //otherwise, just one short blink to indicate the wakeup was scheduled by the RTC
                // * Reset events and read back on nRF52
                //* http://infocenter.nordicsemi.com/pdf/nRF52_Series_Migration_v1.0.pdf
                #if __CORTEX_M == 0x04
                #define NRF5_RESET_EVENT(event)                                                 \
                        event = 0;        \
                        (void)event
                #else
                #define NRF5_RESET_EVENT(event) event = 0
                // This must be in one line
                extern "C" { void LPCOMP_IRQHandler(void) {button_pressed=true; NRF5_RESET_EVENT(NRF_LPCOMP->EVENTS_UP); NRF_LPCOMP->EVENTS_UP=0; MY_HW_RTC->CC[0]=(MY_HW_RTC->COUNTER+2);}}
                AnticimexA 1 Reply Last reply
                  #include <nrf.h>
                        wait(20);
                        wait(100);
                        wait(500);
                  #ifndef IS_NRF51
                  #ifndef IS_NRF51
                  #ifdef IS_NRF51
                  void turnOffAdc() {
                  #ifndef IS_NRF51
                    turnOffRadio();
                    turnOffUarte0();
                    hwInit();
                    disableNfc();
                    turnOffAdc();
                    activateLpComp();
                    mySleepPrepare();
                    else {
                          event = 0;        \
                          (void)event
                  #else
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @NeverDie Nice stuff! Perhaps you could file a PR and include it as a example in the repo?
                  • NeverDieN
                    NeverDieN
                    #1309
                    Here's the hardware I developed it on:
                    For the nRF52832 (on the right), I literally used a button push to simulate a leak detection. However, for the nRF51822 (on the left), I did use the leak detection pins. I've tried putting it on a flooded surface and, indeed, it does detect water. By that I mean a water leak is enough to wake it up from sleep and trigger a detection event.
                    • NeverDieN
                      NeverDieN
                      #1310
                      I just now measured the sleep current on the nRF51822 (above), and it is 3.9ua. So, higher than the nRF52822. Go figure.
                      BTW, I'm using a uCurrent Gold paired to a Fluke 87V for my current measurements, so I think my measurements are probably reasonably accurate (and repeatable by anyone else with similar equipment).
                      • AnticimexA Anticimex
                        NeverDieN
                        NeverDieN
                        #1311
                        @Anticimex said in nRF5 Bluetooth action!:
                        I think instead of that I'll bake it into an improved demo script for the multisensor node and post it there. So, instead of waking up every 5 seconds to blink an LED, it will instead wake-up every 5 minutes to take a temperature/humidity reading and report it back wirelessly to the gateway. Meanwhile, if it happens to detect a water leak, it will report that the instant it is detected. That will be the practical upshot of the above script, which is a boilerplate for how to quickly respond to interrupts while sleeping and yet still remain miserly with respect to battery consumption.
                        Or, better yet, I'll do it for the PIR demo code, since it doesn't yet have demo code. Same basic idea.
                          NeverDieN
                          NeverDieN
                          #1312
                          I posted an enhanced version of it here as the demo sketch--it includes proper MySensors radio code as well: https://www.openhardware.io/view/499/10-years-wireless-PIR-Sensor-on-just-one-set-of-3-AAs#tabs-source
                          • T
                            Toyman
                            Need your help, guys. I am trying to reprogram a smart socket based on nrf51 module. The schematic is:
                            I successfully did it using conventional BT Arduino core (Sandeep's) and I was able to switch the relay on/off.
                            However, when I tried to use Mysensors ESB5 implementation, the relay just switches On briefly and then immediately Off.
                            I believe this is because the pin doesn't supply enough current for the transistor to saturate (3.3v/1k=3.3ma).
                            Questions:
                            a ) shall I use hwPinMode(PIN, OUTPUT_S0H1)? if yes,
                            b ) why in non-MySensors sketch a simple pinMode(PIN, OUTPUT) worked?
                            Does MuSensors implementation overrides Sandeep's definitions so the pin supplies less current?
                            • T Toyman
                              Questions:
                              NeverDieN
                              NeverDieN
                              #1314
                              @Toyman I don't know the answers, but section 20.4.1 GPIO Electrical Specification from the datasheet might give you some insight. What I notice from it is that there's quite a spread between the min and max driver current rating, with no real explanation as to why. So, for that reason, if your target currents are higher than the minimum ratings, perhaps you're better off using an nRF5 pin to control a load switch, which in turn should easily handle your desired currents?
                              T 1 Reply Last reply
                                Toyman
                                The schematic is given. I just don't understand why it worked with BLE core and why it doesn't with d0016's.
                                I always thought Mysensors is an extension of vanilla nrf5 arduino core.
                                • T Toyman
                                  d00616D
                                  d00616D
                                  d00616
                                  wrote on last edited by d00616
                                  #1316
                                  @Toyman said in nRF5 Bluetooth action!:
                                  You have to remove the SoftDevice. The EEPROM Emulation, included in MySensors, is incompatible and the radio and RTC interrupt is blocked by the SoftDevice. The system call to disable the SoftDevice is not available in the Arduino port. Here is some example to erase the MCU.
                                  • d00616D d00616
                                    Toyman
                                    @d00616 everything is working EXCEPT relay control.
                                    So the node is recognized in Domoticz, I can switch it on and off, but the relay just doesn't switch on permanently when I send HIGH to the pin. It switches on and almost immediately off.
                                    • T Toyman
                                      d00616D
                                      d00616D
                                      d00616
                                      With the extended output mode, you are on the safe side, but I think this isn't the problem. Maybe domoticz sends the off command or there is something in the sketch logic. Please try to switch on the port outside the MySensors logic like in setup() or by the button.
                                      Your design has connected a button to P0.00 and an transistor to P0.01. These pins are for the 32kHz clock. Please check, that you have to choosen the RC oscillator as LFCKL source.
                                      • NeverDieN
                                        NeverDieN
                                        #1319
                                        I received a battery clip designed to hold two CR2032's in series, but I was surprised to find how much wider it is than a single cell holder:
                                        Why? And, is that how they all are?
                                        So, at this point, I either need to increase the PCB diameter again, or else go square and hang this clip diagonally.
                                        You may ask, why do this at all? One of the reasons is that the AM612 PIR requires a minimum of 2.7v, and a single CR2032 doesn't leave much headroom, especially given the dippy discharge nature of coincells. I figure two CR2032's in series with a voltage regulator should, in theory, manage the issue a lot better. Indeed, with that in mind, I already have PCB's with the pads for a voltage regulator on them, but I didn't expect the battery clip to be so big.
                                        T 2 Replies Last reply
                                          Toyman
                                          @neverdie said in nRF5 Bluetooth action!:
                                          else go square
                                          if you ask me, go this way given the BT module itself is already beyond the circular footprint
