  3. nRF5 action!
nRF5 action!
  • A Alexey Strelnikov
    Hello, I want to build battery powered modules (with sleep). I found on Ebay NRF51822 round module with case (https://www.ebay.com/itm/hello/112650665753) - only $6.50 with shipping. Is this module is good choice? Any pitfalls?
    I planning to use water leak sensor, BME280 (I2C), ds18b20(1-wire), maybe MH-Z19 later.
    I don't have enough experience, I have only used ESP8266 NodeMcu V3 and Arduino before.
    I can see one I2C (for programator and sensors?) and one GPIO as button for water leak (right?) + LED pin. Does this module have more pins? Shall I connect to chip legs to obtain more pins (GPIO) (does I need to connect resistors?) for 1-wire or better use some sort of I2C GPIO expander?
    NeverDieN
    NeverDieN
    @alexey-strelnikov
    Looks nice, but any hardware mods and it probably won't fit the case anymore.
      Nca78N
      Nca78N
      @alexey-strelnikov I have one and there are pads to program it but nothing more, it's not really a "module" but a Bluetooth beacon, the only 2 I/Os available are those from the button and the led, there's a footprint for an accelerometer also but the pads are too tiny to solder any wire.
      If you're planning to use other sensors don't buy that one. It's great as a button sensor but any other use will need soldering to LGA-sized pads...
      • Nca78N
        Nca78N
        I received the "holyiot" modules and they are really, really tiny. 2 attached together are exactly the same size than the 51822-04 module. WL-CSP package is very impressive: small, very thin and with a cool shinny surface.
        This module has inductors for DC/DC mode, and pins .00 and .01 are mapped so it's possible to add low frequency crystal for Bluetooth mode.
        • Nca78N Nca78
          NeverDieN
          NeverDieN
          #1344
          @nca78
          Nice!
          I'll be very interested to know how the range compares. At least so far, in my own comparisons, smaller has meant less range. Not necessarily a deal killer though, as you only need range that's "good enough," and you can compensate with a better antenna on the gateway.
          Nca78N 1 Reply Last reply
          • NeverDieN NeverDie
            @nca78
            Nice!
            Nca78N
            Nca78N
            @neverdie said in nRF5 Bluetooth action!:
            @nca78
            Nice!
            Yes I'll try to test next week to have an idea of the range, if it's "good enough" to be usable at least with a central pa/lna gateway or if it's better to stick with bigger PCB antennas.
            nrf51822-04 is small enough but this one has a better chip and 11 I/Os available, that's precious for a multisensor board.
            • Nca78N Nca78
              @nca78
              Nice!
              NeverDieN
              NeverDieN
              @nca78 said in nRF5 Bluetooth action!:
              nrf51822-04
              What I've noticed is that Rx range was much more compromised with a reduction in size than the Tx range is. Or, to put it differently, Tx range isn't as dramatically compromised. That's potentially good news for a sensor, which may Tx only anyway (i.e. "passive" in the mysensors jargon). But even if it does Rx, your gateway can be much more powerful on its Tx. So, it potentially works out rather nicely, if you know what I mean.
              • nagelcN
                nagelcN
                nagelc
                Just received my Fanstell modules. Yikes! 1.1mm pin pitch didn't look that small in the pictures. Do you solder these by hand? I thought my soldering skills were getting pretty good, but I can see I'm going to have to up my game.
                NeverDieN 1 Reply Last reply
                • nagelcN nagelc
                  NeverDieN
                  NeverDieN
                  @nagelc Yes, I solder it by hand. It's easier than it looks. Just use a narrow tip and maybe extra flux if you need it.
                  • NeverDieN
                    NeverDieN
                    Here's my latest gateway sheild for the Wemos D1 Mini:
                    In the interest of both belt and suspenders, I gave it its own 300ma LDO so that it won't be competing with the Wemos D1 Mini for current. Earlier measurements of this Fanstel ldo-pa nRF52832 shows that it can draw up to 250ma.
                    It's designed to work well with ESP-LINK, which can also be used to remotely reset the nRF52832 if that's ever needed. Presently, I'm using ESP-LINK's built-in MQTT to send MQTT to a Mosquito MQTT broker. This offloads that task from the nRF52832, which just inputs/outputs serial.
                    By the way, I soldered the entire thing using a wide chisel point solder tip, so it turns out you don't really need a narrow solder tip after all. I do use Rosin flux, though, and it does a great job. The only inconvenience is that the excess Rosin flux should be cleaned off afterward, but, meh, I don't find that to be much of a bother.
                    • Nca78N Nca78
                      @nca78
                      Nice!
                      NeverDieN
                      NeverDieN
                      #1350
                      @nca78
                      Nice!
                      Any update?
                      Also, what is the size of the pads? The only info I've found is what appears on the aliexpress website, which only seems to express the distance (center to center) between the pads. I just received some of these modules, so I'd like to maybe do a prototype PCB using my CNC machine. ;)
                      BTW, I notice that the price went up from $3.20/module to $4/module. :( And something tells me it will probably go higher still.
                        @nca78
                        Nice!
                        Any update?
                        Nca78N
                        Nca78N
                        @nca78
                        Nice!
                        Any update?
                        Sorry I was busy with other things. Now my switch seems to work I will quickly finish other atmega projects and make the switch to nrf5x.
                        For pad sizes, I believe from the pictures below it's 1mm width (grid size is obviously 0.5mm)
                        T 1 Reply Last reply
                        • Nca78N Nca78
                          @nca78
                          Nice!
                          Any update?
                          Toyman
                          @nca78 do you move your fantastic Nmodules to nrf5 platform?
                          • T Toyman
                            Nca78N
                            Nca78N
                            @toyman said in nRF5 Bluetooth action!:
                            Probably, and I will switch to MYSX connector too.
                            • NeverDieN
                              NeverDieN
                              I was just about to make a test board using my CNC when out of the blue my CNC died during setup. So, I did this board instead and will have it fabbed:
                                Nca78N
                                Nca78N
                                @neverdie for a test board why are you not using standard headers and mapping all pins available ?
                                • Nca78N Nca78
                                  NeverDieN
                                  NeverDieN
                                  #1356
                                  @nca78 Because originally I was going to do the board on my CNC (that is, before my CNC dropped dead on me), and I wanted to make it as easy as possible for the CNC to succeed. Also, for testing purposes, I'm most interested in how well it sends/receives, and I don't need many pins to test that. Also, soldering this module may be tricky, so I wanted only the minimum number of pins in case soldering it proves to be difficult.
                                  • korttomaK
                                    korttomaK
                                    korttoma
                                    #1357
                                    Just received these tiny NRF51822 devices and would like to turn them in to MySensors 1 button scencontroller.
                                    Where should I start?
                                    1. I guess I will need some kind of USB adapter ti program them. Think I read somewhere about JLink. Would this do?
                                    • Tomas
                                    Nca78N T 2 Replies Last reply
                                    • korttomaK korttoma
                                      Nca78N
                                      Nca78N
                                      @korttoma did you check here ?
                                      https://forum.mysensors.org/topic/6705/mysensors-nrf5-platform
                                      For programming the best solution is probably the NRF52 DK, it's not very expensive (30€) and you avoid all the problems related to license of the fake JLINKs (and bricking of the device if you happen to accept the invitation to update the outdated firmware on it), as it includes official licence for programming all nrf5 chips.
                                      https://www.arrow.com/en/products/nrf52-dk/nordic-semiconductor
                                      • MiKaM
                                        MiKaM
                                        MiKa
                                        Working without problem with mysensors, I use STLink v2 from Aliexpress. LED and Button are mapped on pins 28 and 29 :)
                                        korttomaK MiKaM 2 Replies Last reply
                                        • MiKaM MiKa
                                          korttomaK
                                          korttomaK
                                          korttoma
                                          @mika :+1:
                                          Now I feel stupid ordering the NRF52 DK for 28€. Well atleast I don't need to worry about bricking any devices.
                                          Do you have an example sketch for the device you can share?
                                          Is it possible to somehow monitor the battery status?
                                          • Tomas
