  3. nRF5 action!
nRF5 action!
  • NeverDieN NeverDie
    Just realizing that if I'm going to hand patch the 4 SWD wires onto the board anyway, then I really don't need an SWD block. Consequently, I'm now thinking the Hackaday guy had the right idea with making his entire node the width of a USB connector:
    TerrenceT
    TerrenceT
    Terrence
    @NeverDie >> I'm now thinking the Hackaday guy had the right idea with making his entire node the width of a USB connector:
    Really good idea. Just plug it into your box.
    NeverDieN 1 Reply Last reply
    • TerrenceT Terrence
      NeverDieN
      NeverDieN
      @Terrence
      Yes, and by making the node the width of a USB connector, there's no wasted PCB that you'd get if the PCB were wider.
      TerrenceT 1 Reply Last reply
        @Terrence
        TerrenceT
        TerrenceT
        Terrence
        @NeverDie Event though there seem to be many benefits to going narrow, what about enclosure sizes, where longer may not be as good as a smaller square?
          NeverDieN
          NeverDieN
          #24
          @Terrence said in Minimalist SAMD21 TQFP32 Pro Mini:
          I'll cross that bridge if I come to it. :)
          Meanwhile, what I'm wondering is: just how wide should the PCB be? I tried looking up USB dimensions, but I get conflicting info:
          alt textalt textalt text
          I also tried measuring some with a micrometer. I think it's going to be something around 12mm. My PCB needs to be a minimum of 12.12mm wide in order to avoid pads of the SAMD21 being too close to the edge of the PCB. Is that too wide, or is it within tolerance?
            Maybe you can file the pcb near the usb connector if it is too wide 😀
            • scalzS
              scalzS
              wrote on last edited by scalz
              #26
              i saw this board too, it's nice one ;) and we can see there is nothing for usb... no fuse, no esd protection, and you touch it and play with it when it's plugged.
              I know this works like this, i did it too for proto. i think maybe computers usb ports are perhaps better protected now, but who knows what can happen, so on my side i prefer to have some basic security to not fry my usb ports :grimacing:
              If you're doing a proto, this pcb size should be ok, but if it's for using with a radio, especially RFM, then the radio module is wider than the board. I know it because i made my atsam RFM dongle for serial gw.
              Last advice if i can :), it's a good practice, to route usb datalines in a // way, and like differential lines, meaning they should be almost the same length (with a few % error). That will work sure, without too much care on a small board like that, but still good to know. you should have a tool in your CAD software for this.
              • scalzS scalz
                NeverDieN
                NeverDieN
                #27
                @scalz said in Minimalist SAMD21 TQFP32 Pro Mini:
                Good point. That might make connecting it a bit difficult! I suppose this form factor is a better match for a surface mount NRF24.
                  NeverDieN
                  NeverDieN
                  #28
                  @NeverDie said in Minimalist SAMD21 TQFP32 Pro Mini:
                  I notice that the Hackaday guy's labeling of D- and D+ as pins 28 and 29 conflicts with what Sparkfun has. Sparkfun has those as pins PA24 and PA25 respectively. Is he wrong? I know from direct experience that the Sparkfun board works, so for now I'm going with the Sparkfun pin mapping.
                  I hear that the PIC MCU chips have a switching fabric that allows you to map any logical pin to any physical pin. I wish the Atmel chips had that. Do maybe these ARM chips have some of that as well?
                  • scalzS
                    scalzS
                    #29
                    yes it depends what ARM mcu you use, some have more freedom regarding pin mapping and peripherals, but atsam can do that too. Very useful.
                    There are some rules for atsam how to change the mapping for spi or other periph, versus arduino core files and datasheet. But if you don't want to dig in that, you can just follow a mapping from a board which already exists in Board manager.
                    • NeverDieN
                      NeverDieN
                      I finished the first pass, and it looks as though everything will fit:
                      A bit more work to do, but this is the approximate form it would take.
                        TerrenceT
                        TerrenceT
                        Terrence
                        @NeverDie NRF or RFM?
                          NeverDieN
                          NeverDieN
                          #32
                          Neither. This is just the MCU. If I can get it to run blink, then as a next step I'll add a radio.
                          It's basically a subset of the sparkfun board, but in a different form factor, with a different USB, and all in 2-layer rather than 4-layer. This will be my first ARM board, so I'm just trying to keep it as simple as possible. The razzmatazz can come later.
                          • NeverDieN
                            NeverDieN
                            #33
                            I polished up the USB and re-positioned the headers so they'd fit on a breadboard:
                            The irony is: after having done all that, I can now more clearly see that it's just not a very efficient form factor. I think for future versions I'll make it not so narrow.
                              TerrenceT
                              TerrenceT
                              Terrence
                              @NeverDie It is an interesting exploration. It seems you don't see it until you get there.
                              • NeverDieN
                                NeverDieN
                                I just now sent this to OSH Park:
                                to see whether or not it works. I still don't know how many uH are the value for the one inductor that Sparkfun used though. Any guesses?
                                Nca78N 1 Reply Last reply
                                  Nca78N
                                  Nca78N
                                  I see no inductor on Sparkfun's schematic ? Only a 30 Ohm ferrite bead.
                                  • Nca78N Nca78
                                    NeverDieN
                                    NeverDieN
                                    @Nca78
                                    Thanks! I guessing this part should do the business then: https://www.digikey.com/product-detail/en/wurth-electronics-inc/742792601/732-4659-1-ND/4310409
                                    • NeverDieN
                                      NeverDieN
                                      #38
                                      Argh. For only a little more than what I paid for the Sparkfun SamD21, I couldn't have gotten the same MCU with an RFM69HCW! And it's already on a 2-layer board, not a 4-layer board:
                                      https://www.adafruit.com/product/3176
                                      https://www.amazon.com/Adafruit-Feather-RFM69HCW-Packet-Radio/dp/B01K62LWBC/ref=sr_1_1?ie=UTF8&qid=1497022595&sr=8-1&keywords=Adafruit+Feather+M0+RFM69HCW
                                      <insert facepalm icon> I should have started with that instead, because that's already probably close to what I'll end up with.
                                      • Nca78N
                                        Nca78N
                                        It's a very good price. If you do it yourself you have a 3$ MCU, 3$+ radio, 1$ PCB and a few US$ for other components (like lipo charger). Leaving only 10$ left for assembly but if you do it yourself you need a lot of time even with a stencil.
                                        • NeverDieN
                                          NeverDieN
                                          And believe it or not, the LoRa version can be had for as little as $15.99 each with Prime delivery:
                                          https://www.amazon.com/gp/product/B01LHTU14W/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
                                          Yeah, at that price I think this becomes a buy, not build, decision.
