  3. Domoticz
  4. Gateway migration
Gateway migration
8 Posts 4 Posters 3.5k Views 4 Watching
  • mmaura66M Offline
    mmaura66M Offline
    mmaura66
    I have started with Domoticz and usb serial gateway. But now i want to go to raspberry wired gateway to use MYSController and OTA update.
    Do you know how i can switch gateway without loosing my domoticz configuration ?
    My goal is to have the same node from old gateway to the new in domoticz, may be with sql ?
    Thanks.
    • mmaura66M mmaura66
      Thanks.
      @mmaura66 Domoticz has a backup feature (Settings->Backup/restore). Use that on the old Domoticz installation and restore on the new Domoticz installation.
      • mmaura66M Offline
        mmaura66M Offline
        mmaura66
        Domoticz are not moving, only the connected gateway from "MySensors Gateway USB" to "MySensors Gateway with LAN interface".
        I want to migrate nodes in same way. The problem is i don't want to remake all script, configuration with the new node references.
        What is the migration logic to do that ?
        Thank you.
          Thank you.
          @mmaura66 I have no idea unfortunately, that's way too advanced for me :)
            I think the problem would be the Index of each sensor that would be different. If you could find a way to edit the DB maybe it could be an option
            • B Offline
              B Offline
              betonishard
              wrote on last edited by betonishard
              I switched from the serial gateway to the lan gateway. I solved this in domoticz by updating the serial one with the LAN. Worked immediately without re-adding whatsoever. Maybe lucky?
              mmaura66M 1 Reply Last reply
                Well actually it makes sense since it allows to change one hw with any type available. Nice find but I never had the chance to make that change
                • B betonishard
                  mmaura66M Offline
                  mmaura66M Offline
                  mmaura66
                  @betonishard said in Gateway migration:
                  i will try and return feedback, thank you
                  12.1k
