  3. NodeManager
  4. SensorMotion to send both tripped and not tripped
39 Posts 6 Posters 12.0k Views 4 Watching
  • U Offline
    U Offline
    user2684
    This post is deleted!
    • U user2684
      @mar.conte great to hear it is working now! For anybody else interested in these parameters, setDebounce() will set a debounce interval, e.g. the value of the input is checked after the interval from the wakeup so to avoid false positives, while seTriggerTime() ignore any input after the pir has triggered to avoid the sensor to trigger continuously. Btw, very nice and clean packaging!
      T Offline
      T Offline
      tubby
      @user2684 said in NodeManager: plugin for a rapid development of battery-powered sensors:
      Just wanted to say first of, this node manager is great for someone like me who has been playing around with my sensors but really struggling to get past the basic example sketches.
      I've been trying to put together a motion sensor using an AM312 PIR.
      but I'm having problems like others with the sensor always remaining tripped.
      I've read through all the documentation but I'm having troubles figuring out how and where to add the extra sensor parameters.
      do these go in the config.h sketch? if so how and where?
      or do I change them in the NodeManager.h
      sorry for such a basic question but I'm not really good with arduino or coding and have read your instructions over and over but I cant figure out how to add these parameters to my sketch.
      Any help would be appreciated.
      mar.conteM 1 Reply Last reply
      • T tubby
        mar.conteM Offline
        mar.conteM Offline
        mar.conte
        @tubby
        Hi, i try with parallax pir setdebounce(50) and its very stable no trigger false positive and each our send level battery, i test this for many daysvand its good by
        M.C.
        T 1 Reply Last reply
        • mar.conteM mar.conte
          @tubby
          T Offline
          T Offline
          tubby
          @mar.conte thanks for the reply.
          I've read that adding the debounce helps, but I just don't know how to add it to the sketch.
          I'm arduino/coding illiterate I manage to bluff my way through most things but this one has me stuffed.
          Where and how do I add debounce to my sketch?
          • T tubby
            mar.conteM Offline
            mar.conteM Offline
            mar.conte
            wrote on last edited by mar.conte
            @tubby
            Like this
            NodeManager nodeManager;
            SensorSwitch swiTch(1,3);
            // before
            void before() {
              // setup the serial port baud rate
              Serial.begin(MY_BAUD_RATE);
               * Register below your sensors
            swiTch.setDebounce(50);
            swiTch.setTriggerTime(4000);
              nodeManager.setSleep(SLEEP,60,MINUTES);
              nodeManager.registerSensor(SENSOR_MOTION,3);``````
            M.C.
            • U Offline
              U Offline
              user2684
              I have a couple of AM312 sensors around here and they are working ok without any debounce or trigger time, I guess I've been just lucky :) The only issue I had has been a lot of false positives when placed outside and the light changing (e.g. the sun shines over them) but I think this is somehow expected.
              @mar.conte in your example you are creating a switch object, adjusting its settings but then NOT using it since when yo call register sensor it will create and register a new object :)
              Either you call register sensor and then retrive the object in this way:
              sensor_id = nodeManager.registerSensor(SENSOR_MOTION,3);
              SensorMotion* sensorMotion = ((SensorMotion*)nodeManager.getSensor(sensor_id));
              sensorMotion->setDebounce(50);
              sensorMotion->setTriggerTime(4000);
              Or you create your own sensor, adjust the settings and register it by passing the object's instance but then you also need to setup the interrupt manually so I'd recommend the option just above. In your example (if this is what you are using) you basically have a standard sensor with neither debounce nor triggertime set :)
              • U user2684
                T Offline
                T Offline
                tubby
                I appreciate the help.
                Ive tried adding your code to my sketch but I get this error.
                Arduino: 1.8.1 (Windows 10), Board: "Arduino Nano, ATmega328"
                In file included from C:\Users\Daniel\Documents\NodeManager_testing_motion\NodeManager_testing_motion.ino:24:0:
                sketch\NodeManager.h:388:26: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
                     char* _description = "";
                sketch\NodeManager.h:400:28: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
                     char * _value_string = "";
                sketch\NodeManager.h:403:33: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
                     char * _last_value_string = "";
                C:\Users\Daniel\Documents\NodeManager_testing_motion\NodeManager_testing_motion.ino: In function 'void before()':
                NodeManager_testing_motion:36: error: 'sensor_id' was not declared in this scope
                exit status 1
                option enabled in File -> Preferences.
                'sensor_id' was not declared in this scope..
                Is the error that stops it from compiling, I always get the other errors when compiling but the sensor still works, tested on dht sensor (but this may be the problem)
                I'm guessing i'm missing something in the sketch.
                I'm really sorry for the pathetic questions.
                With this basic sketch:
                NodeManager is intended to take care on your behalf of all those common tasks a MySensors node has to accomplish, speeding up the development cycle of your projects.
                NodeManager includes the following main components:
                - Sleep manager: allows managing automatically the complexity behind battery-powered sensors spending most of their time sleeping
                - Power manager: allows powering on your sensors only while the node is awake
                - Battery manager: provides common functionalities to read and report the battery level
                - Remote configuration: allows configuring remotely the node without the need to have physical access to it
                - Built-in personalities: for the most common sensors, provide embedded code so to allow their configuration with a single line
                Documentation available on: https://github.com/mysensors/NodeManager
                // load user settings
                #include "config.h"
                // include supporting libraries
                #ifdef MY_GATEWAY_ESP8266
                  #include <ESP8266WiFi.h>
                // load MySensors library
                // load NodeManager library
                #include "NodeManager.h"
                // create a NodeManager instance
                // before
                void before() {
                  nodeManager.setSleep(SLEEP,1,MINUTES);
                   * Register above your sensors
                  nodeManager.before();
                // presentation
                void presentation() {
                  // call NodeManager presentation routine
                  nodeManager.presentation();
                // setup
                  // call NodeManager setup routine
                  nodeManager.setup();
                // loop
                  // call NodeManager loop routine
                  nodeManager.loop();
                // receive
                  // call NodeManager receive routine
                  nodeManager.receive(message);
                // receiveTime
                void receiveTime(unsigned long ts) {
                  // call NodeManager receiveTime routine
                  nodeManager.receiveTime(ts);
                I get this node log on serial:
                3 MCO:BGN:BFR
                REG I=1 P=2 P=1 T=16
                NodeManager v1.5
                INT1 M=255
                INT2 M=3
                6 TSM:INIT
                10 TSF:WUR:MS=0
                17 TSM:INIT:TSP OK
                19 TSF:SID:OK,ID=1
                21 TSM:FPAR
                57 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                1125 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                1130 !TSF:MSG:PONG RECV,INACTIVE
                2064 !TSM:FPAR:NO REPLY
                2066 TSM:FPAR
                2102 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                2120 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                2125 TSF:MSG:FPAR OK,ID=0,D=1
                3100 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                4110 TSM:FPAR:OK
                4111 TSM:ID
                4112 TSM:ID:OK
                4114 TSM:UPL
                4117 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                6124 TSM:UPL
                6126 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                6458 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                6463 TSF:MSG:PONG RECV,HP=1
                6465 TSM:UPL:OK
                6467 TSM:READY:ID=1,PAR=0,DIS=1
                6471 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                6478 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                6483 !TSF:MSG:PONG RECV,INACTIVE
                6490 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                6497 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
                6505 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                RADIO OK
                8513 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=11,sg=0,ft=0,st=OK:NodeManager
                8522 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
                PRES I=200, T=23
                8563 !TSF:MSG:SEND,1-1-0-0,s=200,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=NACK:
                PRES I=201, T=30
                8605 !TSF:MSG:SEND,1-1-0-0,s=201,c=0,t=30,pt=0,l=0,sg=0,ft=1,st=NACK:
                BATT V=4.57 P=100
                SEND D=0 I=201 C=0 T=38 S= I=0 F=4.57
                8683 !MCO:SND:NODE NOT REG
                8725 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=2,st=NACK:100
                PRES I=1 T=1
                8767 !TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=1,pt=0,l=0,sg=0,ft=3,st=NACK:
                READY
                8773 MCO:REG:REQ
                8811 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=4,st=NACK:2
                10818 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=5,st=OK:2
                12825 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                13209 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                13214 MCO:PIM:NODE REG=1
                13216 MCO:BGN:STP
                MY I=1 M=1
                13218 MCO:BGN:INIT OK,TSP=1
                SLEEP 60s
                13222 MCO:SLP:MS=60000,SMS=1,I1=255,M1=255,I2=0,M2=3
                13230 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:12
                13236 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                13241 MCO:PIM:NODE REG=1
                13736 MCO:SLP:TPD
                13737 MCO:SLP:WUP=-2
                AWAKE
                SLEEP 60s
                13741 MCO:SLP:MS=60000,SMS=1,I1=255,M1=255,I2=0,M2=3
                13748 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:530
                14254 MCO:SLP:TPD
                14255 MCO:SLP:WUP=-2
                AWAKE
                SLEEP 60s
                14258 MCO:SLP:MS=60000,SMS=1,I1=255,M1=255,I2=0,M2=3
                14265 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:1047
                14772 MCO:SLP:TPD
                14773 MCO:SLP:WUP=-2
                AWAKE
                SLEEP 60s
                14776 MCO:SLP:MS=60000,SMS=1,I1=255,M1=255,I2=0,M2=3
                14783 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:1565
                15290 MCO:SLP:TPD
                15291 MCO:SLP:WUP=-2
                AWAKE
                SLEEP 60s
                15294 MCO:SLP:MS=60000,SMS=1,I1=255,M1=255,I2=0,M2=3
                15337 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=NACK:2083
                15843 MCO:SLP:TPD
                15844 MCO:SLP:WUP=-2
                AWAKE
                SLEEP 60s
                15847 MCO:SLP:MS=60000,SMS=1,I1=255,M1=255,I2=0,M2=3
                15890 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=1,st=NACK:2636
                16396 MCO:SLP:TPD
                16397 MCO:SLP:WUP=-2
                AWAKE
                SLEEP 60s
                16400 MCO:SLP:MS=60000,SMS=1,I1=255,M1=255,I2=0,M2=3
                16443 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=2,st=NACK:3189
                16949 MCO:SLP:TPD
                16950 MCO:SLP:WUP=-2
                AWAKE
                SLEEP 60s
                16953 MCO:SLP:MS=60000,SMS=1,I1=255,M1=255,I2=0,M2=3
                16960 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=3,st=OK:3742
                17467 MCO:SLP:TPD
                17468 MCO:SLP:WUP=-2
                AWAKE
                SLEEP 60s
                17471 MCO:SLP:MS=60000,SMS=1,I1=255,M1=255,I2=0,M2=3
                17478 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:4260
                17985 MCO:SLP:TPD
                17986 MCO:SLP:WUP=-2
                AWAKE
                SLEEP 60s
                17989 MCO:SLP:MS=60000,SMS=1,I1=255,M1=255,I2=0,M2=3
                17996 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:4778
                18503 MCO:SLP:TPD
                18504 MCO:SLP:WUP=-2
                AWAKE
                BATT V=4.61 P=100
                SEND D=0 I=201 C=0 T=38 S= I=0 F=4.61
                18615 !TSF:MSG:SEND,1-1-0-0,s=201,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=NACK:4.61
                18658 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=1,st=NACK:100
                SLEEP 60s
                18665 MCO:SLP:MS=60000,SMS=1,I1=255,M1=255,I2=0,M2=3
                18707 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=2,st=NACK:5454
                19214 MCO:SLP:TPD
                19215 MCO:SLP:WUP=-2
                AWAKE
                SLEEP 60s
                19218 MCO:SLP:MS=60000,SMS=1,I1=255,M1=255,I2=0,M2=3
                19261 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=3,st=NACK:6007
                19767 MCO:SLP:TPD
                19768 MCO:SLP:WUP=-2
                AWAKE
                SLEEP 60s
                19771 MCO:SLP:MS=60000,SMS=1,I1=255,M1=255,I2=0,M2=3
                19814 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=4,st=NACK:6560
                20320 MCO:SLP:TPD
                20321 MCO:SLP:WUP=-2
                AWAKE
                SLEEP 60s
                I know I'm loosing a lot of communication but, I'm just trying to test at the moment.
                Oh and I don't have any sensors connected to this node at the moment, so there is no PIR sending pin high.
                the voltage between ground and pin 2 is 0.28v
                I'm really struggling with this.
                If I run the mysensors example it works as expected.
                any help would be much appreciated
                U 1 Reply Last reply
                • T tubby
                  exit status 1
                  #include "config.h"
                  // before
                  void before() {
                  // presentation
                  // setup
                  // loop
                    nodeManager.loop();
                  // receive
                  // receiveTime
                  3 MCO:BGN:BFR
                  NodeManager v1.5
                  INT1 M=255
                  INT2 M=3
                  6 TSM:INIT
                  10 TSF:WUR:MS=0
                  17 TSM:INIT:TSP OK
                  19 TSF:SID:OK,ID=1
                  21 TSM:FPAR
                  2066 TSM:FPAR
                  4110 TSM:FPAR:OK
                  4111 TSM:ID
                  4112 TSM:ID:OK
                  4114 TSM:UPL
                  6124 TSM:UPL
                  6465 TSM:UPL:OK
                  RADIO OK
                  PRES I=200, T=23
                  PRES I=201, T=30
                  BATT V=4.57 P=100
                  PRES I=1 T=1
                  READY
                  8773 MCO:REG:REQ
                  13216 MCO:BGN:STP
                  MY I=1 M=1
                  SLEEP 60s
                  13736 MCO:SLP:TPD
                  AWAKE
                  SLEEP 60s
                  14254 MCO:SLP:TPD
                  AWAKE
                  SLEEP 60s
                  14772 MCO:SLP:TPD
                  AWAKE
                  SLEEP 60s
                  15290 MCO:SLP:TPD
                  AWAKE
                  SLEEP 60s
                  15843 MCO:SLP:TPD
                  AWAKE
                  SLEEP 60s
                  16396 MCO:SLP:TPD
                  AWAKE
                  SLEEP 60s
                  16949 MCO:SLP:TPD
                  AWAKE
                  SLEEP 60s
                  17467 MCO:SLP:TPD
                  AWAKE
                  SLEEP 60s
                  17985 MCO:SLP:TPD
                  AWAKE
                  SLEEP 60s
                  18503 MCO:SLP:TPD
                  AWAKE
                  BATT V=4.61 P=100
                  SLEEP 60s
                  19214 MCO:SLP:TPD
                  AWAKE
                  SLEEP 60s
                  19767 MCO:SLP:TPD
                  AWAKE
                  SLEEP 60s
                  20320 MCO:SLP:TPD
                  AWAKE
                  SLEEP 60s
                  U Offline
                  U Offline
                  user2684
                  @tubby said in NodeManager: plugin for a rapid development of battery-powered sensors:
                  sorry my bad, I should have tested the code before pasting it here :-(
                  That sensor_id = nodeManager.registerSensor(SENSOR_MOTION,3); should be a int sensor_id = nodeManager.registerSensor(SENSOR_MOTION,3);
                  I forgot an int.
                  • U user2684
                    I forgot an int.
                    T Offline
                    T Offline
                    tubby
                    @user2684 thanks mate.
                    Ill try that tommorrow.
                    Really wish I know how to code, but I just don't know where to start.
                    • T Offline
                      T Offline
                      tubby
                      Thanks guys got it running.
                      after a lot of stuffing around
                      the problem I'm having now is the controller always say that its tipped (Using home assistant)
                      It looks to me that the node doesn't send an off trip, only an on.
                      here is my node output
                      3 MCO:BGN:BFR
                      REG I=1 P=3 P=1 T=16
                      NodeManager v1.5
                      INT1 M=3
                      INT2 M=255
                      6 TSM:INIT
                      10 TSF:WUR:MS=0
                      17 TSM:INIT:TSP OK
                      19 TSF:SID:OK,ID=1
                      21 TSM:FPAR
                      2066 TSM:FPAR
                      2928 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                      2933 TSF:MSG:FPAR OK,ID=0,D=1
                      4110 TSM:FPAR:OK
                      4111 TSM:ID
                      4112 TSM:ID:OK
                      4114 TSM:UPL
                      4126 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                      4131 TSF:MSG:PONG RECV,HP=1
                      4134 TSM:UPL:OK
                      4135 TSM:READY:ID=1,PAR=0,DIS=1
                      4141 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                      4147 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                      4154 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
                      4163 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                      4802 TSF:MSG:READ,0-0-1,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                      RADIO OK
                      4809 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=11,sg=0,ft=0,st=OK:NodeManager
                      4818 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
                      PRES I=200, T=23
                      4827 TSF:MSG:SEND,1-1-0-0,s=200,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=OK:
                      PRES I=201, T=30
                      4835 TSF:MSG:SEND,1-1-0-0,s=201,c=0,t=30,pt=0,l=0,sg=0,ft=0,st=OK:
                      BATT V=4.57 P=100
                      4912 !MCO:SND:NODE NOT REG
                      4920 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:100
                      PRES I=1 T=1
                      4928 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                      READY
                      4934 MCO:REG:REQ
                      4937 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                      4951 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                      4956 MCO:PIM:NODE REG=1
                      4958 MCO:BGN:STP
                      MY I=1 M=1
                      4960 MCO:BGN:INIT OK,TSP=1
                      SWITCH I=1 P=3 V=1
                      SEND D=0 I=1 C=0 T=16 S= I=1 F=0.00
                      4966 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
                      SLEEP 60s
                      4973 MCO:SLP:MS=60000,SMS=1,I1=1,M1=3,I2=255,M2=255
                      4980 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:21
                      5487 MCO:SLP:TPD
                      5488 MCO:SLP:WUP=1
                      WAKE P=3, M=3
                      AWAKE
                      SWITCH I=1 P=3 V=1
                      SEND D=0 I=1 C=1 T=16 S= I=1 F=0.00
                      5493 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
                      SLEEP 60s
                      5502 MCO:SLP:MS=60000,SMS=1,I1=1,M1=3,I2=255,M2=255
                      5510 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:551
                      6017 MCO:SLP:TPD
                      6018 MCO:SLP:WUP=1
                      WAKE P=3, M=3
                      AWAKE
                      SWITCH I=1 P=3 V=1
                      6023 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
                      SLEEP 60s
                      6032 MCO:SLP:MS=60000,SMS=1,I1=1,M1=3,I2=255,M2=255
                      6039 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:1080
                      6546 MCO:SLP:TPD
                      6547 MCO:SLP:WUP=1
                      WAKE P=3, M=3
                      AWAKE
                      SWITCH I=1 P=3 V=1
                      6552 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
                      SLEEP 60s
                      6561 MCO:SLP:MS=60000,SMS=1,I1=1,M1=3,I2=255,M2=255
                      6568 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:1609
                      7076 MCO:SLP:TPD
                      7077 MCO:SLP:WUP=1
                      WAKE P=3, M=3
                      AWAKE
                      SWITCH I=1 P=3 V=1
                      7083 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
                      SLEEP 60s
                      7092 MCO:SLP:MS=60000,SMS=1,I1=1,M1=3,I2=255,M2=255
                      7099 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:2140
                      7606 MCO:SLP:TPD
                      7607 MCO:SLP:WUP=1
                      WAKE P=3, M=3
                      AWAKE
                      SWITCH I=1 P=3 V=1
                      7612 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
                      SLEEP 60s
                      7621 MCO:SLP:MS=60000,SMS=1,I1=1,M1=3,I2=255,M2=255
                      7628 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:2669
                      8135 MCO:SLP:TPD
                      8136 MCO:SLP:WUP=1
                      WAKE P=3, M=3
                      AWAKE
                      SWITCH I=1 P=3 V=1
                      8141 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
                      SLEEP 60s
                      8151 MCO:SLP:MS=60000,SMS=1,I1=1,M1=3,I2=255,M2=255
                      8158 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:3199
                      8665 MCO:SLP:TPD
                      8666 MCO:SLP:WUP=1
                      WAKE P=3, M=3
                      AWAKE
                      SWITCH I=1 P=3 V=1
                      8671 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
                      SLEEP 60s
                      is this correct? Looks to me that the node sends a (1) when tripped but not a (0) when motion stops.
                      This makes my controller think that there is constant motion
                      • T tubby
                        3 MCO:BGN:BFR
                        NodeManager v1.5
                        INT1 M=3
                        INT2 M=255
                        6 TSM:INIT
                        10 TSF:WUR:MS=0
                        17 TSM:INIT:TSP OK
                        19 TSF:SID:OK,ID=1
                        21 TSM:FPAR
                        2066 TSM:FPAR
                        4110 TSM:FPAR:OK
                        4111 TSM:ID
                        4112 TSM:ID:OK
                        4114 TSM:UPL
                        4134 TSM:UPL:OK
                        RADIO OK
                        PRES I=200, T=23
                        PRES I=201, T=30
                        BATT V=4.57 P=100
                        PRES I=1 T=1
                        READY
                        4934 MCO:REG:REQ
                        4958 MCO:BGN:STP
                        MY I=1 M=1
                        SWITCH I=1 P=3 V=1
                        SLEEP 60s
                        5487 MCO:SLP:TPD
                        5488 MCO:SLP:WUP=1
                        WAKE P=3, M=3
                        AWAKE
                        SWITCH I=1 P=3 V=1
                        SLEEP 60s
                        6017 MCO:SLP:TPD
                        6018 MCO:SLP:WUP=1
                        WAKE P=3, M=3
                        AWAKE
                        SWITCH I=1 P=3 V=1
                        SLEEP 60s
                        6546 MCO:SLP:TPD
                        6547 MCO:SLP:WUP=1
                        WAKE P=3, M=3
                        AWAKE
                        SWITCH I=1 P=3 V=1
                        SLEEP 60s
                        7076 MCO:SLP:TPD
                        7077 MCO:SLP:WUP=1
                        WAKE P=3, M=3
                        AWAKE
                        SWITCH I=1 P=3 V=1
                        SLEEP 60s
                        7606 MCO:SLP:TPD
                        7607 MCO:SLP:WUP=1
                        WAKE P=3, M=3
                        AWAKE
                        SWITCH I=1 P=3 V=1
                        SLEEP 60s
                        8135 MCO:SLP:TPD
                        8136 MCO:SLP:WUP=1
                        WAKE P=3, M=3
                        AWAKE
                        SWITCH I=1 P=3 V=1
                        SLEEP 60s
                        8665 MCO:SLP:TPD
                        8666 MCO:SLP:WUP=1
                        WAKE P=3, M=3
                        AWAKE
                        SWITCH I=1 P=3 V=1
                        SLEEP 60s
                        U Offline
                        U Offline
                        user2684
                        @tubby SENSOR_MOTION reacts on RISING only so you will not get the low tripped. Try adding the following:
                        sensorMotion->setInitial(LOW);
                        sensorMotion->setMode(CHANGE);
                        This should send a message on both RISING and FALLING.
                        • U user2684
                          T Offline
                          T Offline
                          tubby
                          @user2684 I really appreciate the help.
                          and now I'm able to use all the extra inbuilt features of the code, now that i know how to add them to the sketch.
                          And I hate to be a pain but I cant seem to get this damn motion sensor to work properly.
                          I've tried the examples you have given me, I've played around with every possible thing I can think/read.
                          But for the life of me cant get it to send a (0) for non tripped.
                          I assume the (CHANGE) interrupt option should be sending a msg on a motion detect ie: (1)
                          and then when the pin goes low it should send a (0), but it seem that the node has already gone to sleep and the changed state is not being recorded.
                          What else could I try?
                          • T tubby
                            U Offline
                            U Offline
                            user2684
                            Correct, when mode is set to CHANGE, the node wakes up with both RISING (0 to 1) or FALLING (1 to 0) interrupts and regardless of the value previously sent, the pin's value is read again and a new message sent back to the gw. The only situation I think this would not work is when the node is NOT sleeping since the interrupt is configured only before entering a sleeping cycle. So if you have a 1 and then immediately a 0, the node has not entered the sleep cycle so the interrupt is lost. For how long does the pin stays to 1 after triggering the motion? Thanks
                            T gohanG 2 Replies Last reply
                            • U user2684
                              T Offline
                              T Offline
                              tubby
                              @user2684 exactly what I thought about the (change) .
                              I have a test rig setup at the moment and I have been pulling the pin high and low manually with a jumper wire.
                              I've held the pin high for up to 30 seconds.
                              The node sends a high value. Than the sleep msg.
                              Up to 30 seconds latter I disconnect the high and connect to low but nothing happens, the node just sleeps either till the amount in the timer or if the pin is pulled high again.
                              I imagine this is the sort of behaviour you would see with a (rising) state
                              • U user2684
                                @user2684 It is an issue I discussed some time ago and a solution was to set a shorter sleep time when the pin was high so it could report the pin low within a reasonable amount of time and then sleep normally.
                                  T Offline
                                  T Offline
                                  tubby
                                  @gohan How would I implement that?
                                  I only see options for overall sleep time, none that allow me different sleep time for only when the pin is high.
                                  I'm sorry for all these questions, I feel like an idiot, but I'm so close to getting all the sensors that I need on one board. That I would have no hope of configuring without node manager.
                                  One hurdle left...
                                    one way would be to use the sleep time as a variable that you can change it to 5000 when the pin goes high and back to the original value when pin goes low with a normal IF statement
                                    • U Offline
                                      U Offline
                                      user2684
                                      @gohan I may have probably missed this one sorry. Did you just shorten the debounce time? My guess @tubby is that you are sleeping for too long after the tripped message. When you say sensorMotion->setTriggerTime(4000);, the node will do nothing for 4 seconds after the "on" message. If the "off" happens during those 4 seconds, the event will be lost. Try lowering this down a bit or compare it with the time it takes for the signal to be restored to low. Thanks
                                      • U Offline
                                        U Offline
                                        user2684
                                        Hi, I finally got a chance to run some more tests but I see the expected behavior even if here looks like different people are experiencing the opposite.
                                        This is my sketch:
                                        nodeManager.setSleep(SLEEP, 30, MINUTES);
                                          int sensorPIR_Id = nodeManager.registerSensor(SENSOR_MOTION,3);
                                          SensorMotion* sensorMotion = (SensorMotion*)nodeManager.getSensor(sensorPIR_Id);
                                        And those are my logs:
                                        WAKE P=3, M=1
                                        AWAKE
                                        SWITCH I=1 P=3 V=1
                                        SLEEP 1800s
                                        WAKE P=3, M=1
                                        AWAKE
                                        SWITCH I=1 P=3 V=0
                                        SEND D=0 I=1 C=1 T=16 S= I=0 F=0.00
                                        SLEEP 1800s
                                        As you can see as motion is detected a 1 is reported (and the board goes to sleep), after a couple of seconds the board wakes up to report the 0.
                                        I'm not using debounce or trigger time here which instead may have an impact (both debounce and trigger time puts the board to sleep and if the signal changes during it, the interrupt will be lost).
                                        Let me know if I'm doing something different.
                                        • Sergio RiusS Offline
                                          Sergio Rius
                                          In fact, what I experience is something different. Sensor detects movement so wakes, but it still wakes every 3sec until low threshold is sent back from the pir:
                                          WAKE P=3, M=3
                                          AWAKE
                                          ON P=5
                                          SWITCH I=1 P=3 V=1
                                          OFF P=5
                                          SLEEP 60
                                          WAKE P=3, M=3
                                          AWAKE
                                          ON P=5
                                          SWITCH I=1 P=3 V=1
                                          OFF P=5
                                          SLEEP 60
                                          WAKE P=3, M=3
                                          AWAKE
                                          ON P=5
                                          SWITCH I=1 P=3 V=1
                                          OFF P=5
                                          SLEEP 60
                                          WAKE P=3, M=3
                                          AWAKE
                                          ON P=5
                                          SWITCH I=1 P=3 V=1
                                          OFF P=5
                                          SLEEP 60
                                          WAKE P=3, M=3
                                          AWAKE
                                          ON P=5
                                          SWITCH I=1 P=3 V=1
                                          OFF P=5
                                          SLEEP 60
                                          WAKE P=3, M=3
                                          AWAKE
                                          BATT V=3.12 P=73
                                          SEND D=0 I=201 C=0 T=38 S= I=0 F=3.12
                                          ON P=5
                                          SWITCH I=1 P=3 V=0
                                          OFF P=5
                                          SLEEP 60
                                          So I don't know if the "low" is triggering or simply it stops querying when the value is low.
