  3. NodeManager
  4. NodeManager: plugin for a rapid development of battery-powered sensors
223 Posts 23 Posters 125.6k Views 26 Watching
  • U user2684
    @mar.conte said in NodeManager: plugin for a rapid development of battery-powered sensors:
    Yes trig again!!!
    Ok, if triggers continuously, please share the logs of the node now that has been fixed so we can have a look.
    mar.conteM
    mar.conteM
    mar.conte
    wrote on last edited by gohan
    #88
    @user2684
    NODE OUTPUT
    40 MCO:BGN:BFR
    REG I=1 P=3 P=1 T=16
    NodeManager v1.4
    INT1 M=3
    INT2 M=255
    59 TSM:INIT
    135 TSF:WUR:MS=0
    153 TSM:INIT:TSP OK
    176 TSM:INIT:STATID=100
    200 TSF:SID:OK,ID=100
    223 TSM:FPAR
    368 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    641 TSF:MSG:READ,0-0-100,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    698 TSF:MSG:FPAR OK,ID=0,D=1
    2445 TSM:FPAR:OK
    2461 TSM:ID
    2476 TSM:ID:OK
    2490 TSM:UPL
    2512 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    2633 TSF:MSG:READ,0-0-100,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    2693 TSF:MSG:PONG RECV,HP=1
    2721 TSM:UPL:OK
    2738 TSM:READY:ID=100,PAR=0,DIS=1
    2785 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    2904 TSF:MSG:READ,0-0-100,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    3018 TSF:MSG:SEND,100-100-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
    3229 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=NACK:0
    5316 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=11,pt=0,l=19,sg=0,ft=1,st=OK:NodeManagerTemplate
    5541 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=NACK:1.0
    RADIO OK
    PRES I=200, T=23
    5715 TSF:MSG:SEND,100-100-0-0,s=200,c=0,t=23,pt=0,l=0,sg=0,ft=1,st=OK:
    PRES I=201, T=30
    5922 !TSF:MSG:SEND,100-100-0-0,s=201,c=0,t=30,pt=0,l=0,sg=0,ft=0,st=NACK:
    BATT V=3.21 P=86
    SEND D=0 I=201 C=0 T=38 S= I=0 F=3.21
    6072 !MCO:SND:NODE NOT REG
    6164 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=1,st=OK:86
    PRES I=1 T=1
    6371 !TSF:MSG:SEND,100-100-0-0,s=1,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=NACK:
    READY
    6445 MCO:REG:REQ
    6531 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
    6619 TSF:MSG:READ,0-0-100,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    6678 MCO:PIM:NODE REG=1
    6705 MCO:BGN:STP
    MY I=100 M=1
    6723 MCO:BGN:INIT OK,TSP=1
    SWITCH I=1 P=3 V=1
    SEND D=0 I=1 C=0 T=16 S= N=1 F=0.00
    6817 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
    SLEEP 3600s
    6897 MCO:SLP:MS=3600000,SMS=1,I1=1,M1=3,I2=255,M2=255
    7104 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=NACK:264
    7684 MCO:SLP:TPD
    7700 MCO:SLP:WUP=1
    WAKE P=3, M=3
    AWAKE
    SWITCH I=1 P=3 V=1
    SEND D=0 I=1 C=1 T=16 S= N=1 F=0.00
    7786 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=1,st=OK:1
    SLEEP 3600s
    7876 MCO:SLP:MS=3600000,SMS=1,I1=1,M1=3,I2=255,M2=255
    8087 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=NACK:1243
    8667 MCO:SLP:TPD
    8683 MCO:SLP:WUP=1
    WAKE P=3, M=3
    AWAKE
    SWITCH I=1 P=3 V=1
    8757 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=1,st=OK:1
    SLEEP 3600s
    8859 MCO:SLP:MS=3600000,SMS=1,I1=1,M1=3,I2=255,M2=255
    8982 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:2226
    9562 MCO:SLP:TPD
    9578 MCO:SLP:WUP=1
    WAKE P=3, M=3
    AWAKE
    SWITCH I=1 P=3 V=1
    9621 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
    SLEEP 3600s
    9754 MCO:SLP:MS=3600000,SMS=1,I1=1,M1=3,I2=255,M2=255
    9961 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=NACK:3121
    10541 MCO:SLP:TPD
    Tanks
    M.C.
    U 1 Reply Last reply
    • mar.conteM mar.conte
      @user2684
      NODE OUTPUT
      40 MCO:BGN:BFR
      NodeManager v1.4
      INT1 M=3
      INT2 M=255
      59 TSM:INIT
      135 TSF:WUR:MS=0
      153 TSM:INIT:TSP OK
      223 TSM:FPAR
      2445 TSM:FPAR:OK
      2461 TSM:ID
      2476 TSM:ID:OK
      2490 TSM:UPL
      2721 TSM:UPL:OK
      RADIO OK
      PRES I=200, T=23
      PRES I=201, T=30
      BATT V=3.21 P=86
      PRES I=1 T=1
      READY
      6445 MCO:REG:REQ
      6705 MCO:BGN:STP
      MY I=100 M=1
      SWITCH I=1 P=3 V=1
      SLEEP 3600s
      7684 MCO:SLP:TPD
      7700 MCO:SLP:WUP=1
      WAKE P=3, M=3
      AWAKE
      SWITCH I=1 P=3 V=1
      SLEEP 3600s
      8667 MCO:SLP:TPD
      8683 MCO:SLP:WUP=1
      WAKE P=3, M=3
      AWAKE
      SWITCH I=1 P=3 V=1
      SLEEP 3600s
      9562 MCO:SLP:TPD
      9578 MCO:SLP:WUP=1
      WAKE P=3, M=3
      AWAKE
      SWITCH I=1 P=3 V=1
      SLEEP 3600s
      10541 MCO:SLP:TPD
      Tanks
      U
      U
      user2684
      @mar.conte ok, this looks better, the node is presenting correctly and I see the sensor triggering continuously. You still have a lot of radio failures while sending but this is another story and it is not related to the issue but keep in mind you are losing a few messages.
      Now, if I look at the digital read of the pin waking up the board (V=):
      SWITCH I=1 P=3 V=1
      This is HIGH so the board correctly wakes up. Since the signal apparently stays high, the board goes in and out of sleep so looks like an expected behavior. The are a couple of functions available to prevent this (setTriggerTime() and setDebounce()) but before giving direction I'd ask you to measure the voltage at pin 3 with a multimeter because it looks like the motion sensor goes HIGH and stay HIGH for a long time. If we know this timeframe, we can adjust the settings accordingly. Btw you should have the same behavior with the example sketch at https://www.mysensors.org/build/motion.
      mar.conteM 2 Replies Last reply
      • U user2684
        SWITCH I=1 P=3 V=1
        mar.conteM
        mar.conteM
        mar.conte
        @user2684
        ok, I will check first the voltage of the pir and even the power of the MCU, it seems to me that the rfm69 module does not communicate with each other (node-gateway), it seems strange because with the sketch of links that you suggested it all works well ! thanks anyway I'll do my tests and let you know soon ...
        M.C.
        • mar.conteM
          mar.conteM
          mar.conte
          wrote on last edited by mar.conte
          #91
          I wanted to know what are the connections to monitor the batteries of my sensor, do I connect the battery V+ to the analog pin A0?
          M.C.
            U
            U
            user2684
            If you are connecting the arduino directly to the battery (e.g. no step-up-down), then you don't need any connection since NodeManager is able to sense and measure the input vcc (and according to my measures it is very accurate). In case instead you need to use the method here https://www.mysensors.org/build/battery, you need the following:
            nodeManager.setBatteryInternalVcc(false);
            nodeManager.setBatteryPin(A0);
            You can even customize the default 0.003363075 voltage per bit with setBatteryVoltsPerBit()
            mar.conteM 1 Reply Last reply
            • U user2684
              mar.conteM
              mar.conteM
              mar.conte
              @user2684
              THEN MY NODE WILL BE CONNECTED TO A BATTERY 3.6 VOLT AA 2600 MAH, SO I DO NOT RIGHT CONNECTIONS? BUT I HAVE TO CHANGE OTHER PARAMETERS TO BEING 3.6?
              TANKS
              M.C.
                @user2684
                TANKS
                U
                U
                user2684
                TANKS
                If directly connected to the battery you don't need any other connection. To set minimum and maximum voltage to have an accurate battery percentage level calculated you need to use e.g.:
                nodeManager.setBatteryMin(2.7);
                nodeManager.setBatteryMax(3.6);
                So the percentage will be calculated between the two values.
                • U user2684
                  TANKS
                  mar.conteM
                  mar.conteM
                  mar.conte
                  @user2684
                  Much easy INFINITE THANKS AND CONGRATULATIONS
                  M.C.
                  • U user2684
                    SWITCH I=1 P=3 V=1
                    mar.conteM
                    mar.conteM
                    mar.conte
                    #96
                    @user2684
                    Solved
                    I solved it by putting settriggertime (5000) setdebounce (50); also solved the supply problems because if power is ftdi with the sensor was always high, with batteries the pir is stable and works well
                    thanks for the support
                    This is my reprap printed house for my project
                    M.C.
                      @user2684
                      Solved
                      U
                      U
                      user2684
                      @mar.conte great to hear it is working now! For anybody else interested in these parameters, setDebounce() will set a debounce interval, e.g. the value of the input is checked after the interval from the wakeup so to avoid false positives, while seTriggerTime() ignore any input after the pir has triggered to avoid the sensor to trigger continuously. Btw, very nice and clean packaging!
                      • mar.conteM
                        mar.conteM
                        mar.conte
                        I have a problem, my node is in sleep for 60 minutes and hourly reads the battery voltage but when you wake the pir is high and in addition to the high volts sends me even then the controller sends me a pir pir movement false; how can I avoid it?
                        M.C.
                        • JonnyDev13J
                          JonnyDev13J
                          JonnyDev13
                          Can I suggest updated sourceforge to say that the code has been moved to github, and leaving little else there? That way it's easier to update everything in the same place. I was browsing on sourceforge for a while and wondering "Why isn't this on github instead?" It wasn't even until I came back and started skimming this thread that I realized it was moved to github.
                            U
                            U
                            user2684
                            So you are saying when the node wakes up not from the pir interrupt at the end of the sleeping cycle to report battery level, is it also reporting a V_TRIPPED with payload 0? Thanks
                            • JonnyDev13J JonnyDev13
                              U
                              U
                              user2684
                              @JonnyDev13 said in NodeManager: plugin for a rapid development of battery-powered sensors:
                              Good advice thanks! I've changed the website link on Sourceforge as well as added a note in the description and redirected the "Support" link.
                              JonnyDev13J 1 Reply Last reply
                              • U user2684
                                mar.conteM
                                mar.conteM
                                mar.conte
                                @user2684
                                Yes of course but payload =1 pir movimento detect
                                M.C.
                                  What's the problem if it reports no motion?
                                  • U user2684
                                    JonnyDev13J
                                    JonnyDev13J
                                    JonnyDev13
                                    @user2684 Looks great!
                                      mar.conteM
                                      mar.conteM
                                      mar.conte
                                      @gohan
                                      The problem is that motion report whenever sleep goes to wake to send me the battery status every 60 minutes ,then every 60 minutes sends me battery status and motion pir
                                      M.C.
                                        Ok, but is it causing any problem?
                                          mar.conteM
                                          mar.conteM
                                          mar.conte
                                          @gohan
                                          Definitely, if I put a pir sensor to monitor a security access I will never know if I had an intrusion if I have a false alarm
                                          M.C.
