  3. RPi 3 gateway problem
4 Posts 3 Posters 1.2k Views 3 Watching
  • F
    F
    feranto63
    wrote on last edited by feranto63
    After using with success RPi and Arduino nano with RF24 modules using RF24 and RF24Network libs I'm trying to use MySensors library but I canno get Arduino nano sensor establish a working connection with RPi gateway.
    Hereafter you may find logs from Arduino sensors and RPi Gateway.
    Could you help me to understand what is wrong in my setup?
    Thank you very much for helping
    Arduino nano sensor log
    3 TSM:INIT
    4 TSF:WUR:MS=0
    11 TSM:INIT:TSP OK
    12 TSM:FPAR
    15 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2022 !TSM:FPAR:NO REPLY
    2024 TSM:FPAR
    2026 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2033 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    2038 TSF:MSG:FPAR OK,ID=0,D=1
    4034 TSM:FPAR:OK
    4035 TSM:ID
    4036 TSM:ID:REQ
    4039 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    6046 TSM:ID
    6047 TSM:ID:REQ
    6049 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    8057 TSM:ID
    8058 TSM:ID:REQ
    8060 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    10070 TSM:ID
    10071 TSM:ID:REQ
    10074 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    12081 !TSM:ID:FAIL
    12082 TSM:FAIL:CNT=1
    12084 TSM:FAIL:PDT
    22087 TSM:FAIL:RE-INIT
    22089 TSM:INIT
    22096 TSM:INIT:TSP OK
    22098 TSM:FPAR
    22100 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    24109 !TSM:FPAR:NO REPLY
    24111 TSM:FPAR
    24113 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    26121 !TSM:FPAR:NO REPLY
    26123 TSM:FPAR
    26125 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    28133 !TSM:FPAR:NO REPLY
    28135 TSM:FPAR
    28137 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    30145 !TSM:FPAR:FAIL
    30146 TSM:FAIL:CNT=2
    30148 TSM:FAIL:PDT
    RPi Gateway log
    mysgw: Starting gateway...
    mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.1
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: TSM:INIT:TSP OK
    mysgw: TSM:INIT:GW MODE
    mysgw: MCO:REG:NOT NEEDED
    mysgw: Listening for connections on 0.0.0.0:5003
    mysgw: MCO:BGN:STP
    mysgw: MCO:BGN:INIT OK,TSP=1
    mysgw: TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:FPAR REQ,ID=255
    mysgw: TSF:CKU:OK,FCTRL
    mysgw: TSF:MSG:GWL OK
    mysgw: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:READ,255-255-0,s=255,c=3,t=3,pt=0,l=0,sg=0:
    mysgw: TSF:MSG:BC
    mysgw: TSF:PNG:SEND,TO=0
    mysgw: TSF:CKU:OK
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:BC
    mysgw: TSF:CKU:OK
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:BC
    mysgw: TSF:CKU:OK
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:BC
    ben999B 1 Reply Last reply
    • F feranto63
      3 TSM:INIT
      4 TSF:WUR:MS=0
      11 TSM:INIT:TSP OK
      12 TSM:FPAR
      2024 TSM:FPAR
      4034 TSM:FPAR:OK
      4035 TSM:ID
      4036 TSM:ID:REQ
      6046 TSM:ID
      6047 TSM:ID:REQ
      8057 TSM:ID
      8058 TSM:ID:REQ
      10070 TSM:ID
      10071 TSM:ID:REQ
      12081 !TSM:ID:FAIL
      12084 TSM:FAIL:PDT
      22089 TSM:INIT
      22098 TSM:FPAR
      24111 TSM:FPAR
      26123 TSM:FPAR
      28135 TSM:FPAR
      30148 TSM:FAIL:PDT
      RPi Gateway log
      mysgw: TSF:LRT:OK
      mysgw: TSM:INIT
      mysgw: TSF:WUR:MS=0
      mysgw: MCO:BGN:STP
      mysgw: TSF:MSG:BC
      mysgw: TSF:MSG:BC
      mysgw: TSF:MSG:BC
      mysgw: TSF:CKU:OK
      mysgw: TSF:MSG:BC
      mysgw: TSF:MSG:BC
      mysgw: TSF:MSG:BC
      mysgw: TSF:CKU:OK
      mysgw: TSF:MSG:BC
      mysgw: TSF:MSG:BC
      mysgw: TSF:MSG:BC
      mysgw: TSF:MSG:BC
      mysgw: TSF:CKU:OK
      mysgw: TSF:MSG:BC
      mysgw: TSF:MSG:BC
      ben999B
      ben999B
      ben999
      Hi @feranto63
      I've had a look at your logs with this tool :
      https://www.mysensors.org/build/parser
      Looks like gateway gets messages from node
      But node doesn't get anything in return
      Do you use "MY_PARENT_NODE_ID" and "MY_NODE_ID" as a config option in your node sketch ?
        It looks like node ID is missing in sketch
        • F
          F
          feranto63
          it seems strange but I solved with recompiling MySensors Gateway with the following configuration options
          ./configure --my-rf24-cs-pin=24 --my-rf24-ce-pin=15 --my-gateway=ethernet
          by magic, everything begins to work (for the first time).
