  3. Custom power meter
Custom power meter
31 Posts 15 Posters 34.0k Views 14 Watching
    maglo18
    @GambitukI am very happy with performance. I'm logs power every 10s and voltage every 60s. It is sufficient. I built like on this site http://openenergymonitor.org/emon/buildingblocks/measuring-voltage-with-an-acac-power-adapter
    You can use transformer what you like but you must add voltage divider to have voltage max 2,5V on input in arduino if you use arduino 5V
    PS Poland/Warsaw
    E 1 Reply Last reply
    • M maglo18
      PS Poland/Warsaw
      E
      E
      ewgor
      @maglo18 I saw some words in your pictures that looks familiar like faza or analizator :)
      Can you share your latest Arduino sketch or if you have a complete tutorial about this project would be helpful.
      Thanks!
      • J
        J
        jeti
        @maglo18: is the sketch in the first post your latest version? I would also like to do a very similar build and would like to get the best base :)
        thanks!
          maglo18
          This is my last and my final sketch
          #include "EmonLib.h"             // Include Emon Library
          EnergyMonitor emon1;             // Create an instance
          EnergyMonitor emon2;             // Create an instance
          EnergyMonitor emon3;             // Create an instance
          #define CHILD_ID 0
          #define CHILD_ID2 1
          #define CHILD_ID3 2
          unsigned long lastSend;
          unsigned long SEND_FREQUENCY = 10000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
          unsigned long lastSend2;
          unsigned long SEND_FREQUENCY2 = 300000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
          MyMessage realPowerMsg(CHILD_ID,V_VAR1);
          MyMessage apparentPowerMsg(CHILD_ID,V_VAR2);
          MyMessage powerFActorMsg(CHILD_ID,V_VAR3);
          MyMessage supplyVoltageMsg(CHILD_ID,V_VAR4);
          MyMessage IrmsMsg(CHILD_ID,V_VAR5);
          MyMessage realPowerMsg2(CHILD_ID2,V_VAR1);
          MyMessage apparentPowerMsg2(CHILD_ID2,V_VAR2);
          MyMessage powerFActorMsg2(CHILD_ID2,V_VAR3);
          MyMessage supplyVoltageMsg2(CHILD_ID2,V_VAR4);
          MyMessage IrmsMsg2(CHILD_ID2,V_VAR5);
          MyMessage realPowerMsg3(CHILD_ID3,V_VAR1);
          MyMessage apparentPowerMsg3(CHILD_ID3,V_VAR2);
          MyMessage powerFActorMsg3(CHILD_ID3,V_VAR3);
          MyMessage supplyVoltageMsg3(CHILD_ID3,V_VAR4);
          MyMessage IrmsMsg3(CHILD_ID3,V_VAR5);
            gw.begin(NULL, 4, false, 0);
            Serial.begin(115200); // opens serial port, sets data rate to 9600 bps
            gw.sendSketchInfo("Energy Meter x 3v2", "1.2");
            gw.present(CHILD_ID, S_POWER);
            gw.present(CHILD_ID2, S_POWER);
            gw.present(CHILD_ID3, S_POWER);
            emon1.voltage(A3, 116.26, 1.7);  // Voltage: input pin, calibration, phase_shift
            emon1.current(A0, 29.0);       // Current: input pin, calibration.
            emon2.voltage(A4, 116.66, 1.7);  // Voltage: input pin, calibration, phase_shift
            emon2.current(A1, 29.0);       // Current: input pin, calibration.
            emon3.voltage(A5, 115.91, 1.7);  // Voltage: input pin, calibration, phase_shift
            emon3.current(A2, 29.0);       // Current: input pin, calibration.
            gw.process();
            unsigned long now = millis();
            emon1.calcVI(20,2000);         // Calculate all. No.of half wavelengths (crossings), time-out
            //emon1.serialprint();           // Print out all variables (realpower, apparent power, Vrms, Irms, power factor)
            emon2.calcVI(20,2000);         // Calculate all. No.of half wavelengths (crossings), time-out
            //emon2.serialprint();           // Print out all variables (realpower, apparent power, Vrms, Irms, power factor)
            emon3.calcVI(20,2000);         // Calculate all. No.of half wavelengths (crossings), time-out
            //emon3.serialprint();           // Print out all variables (realpower, apparent power, Vrms, Irms, power factor)
            bool sendTime = now - lastSend > SEND_FREQUENCY;
            if (sendTime) {
              float realPower       = emon1.realPower;        //extract Real Power into variable
              float realPower2       = emon2.realPower;        //extract Real Power into variable
              float realPower3       = emon3.realPower;        //extract Real Power into variable
              if(realPower > 0 && realPower < 10000){
              gw.send(realPowerMsg.set(realPower,1));
              if(realPower2 > 0 && realPower2 < 10000){
              gw.send(realPowerMsg2.set(realPower2,1));
              if(realPower3 > 0 && realPower3 < 10000){
              gw.send(realPowerMsg3.set(realPower3,1));
              lastSend = now;
            bool sendTime2 = now - lastSend2 > SEND_FREQUENCY2;
            if(sendTime2){
              float apparentPower   = emon1.apparentPower;    //extract Apparent Power into variable
              float powerFactor     = emon1.powerFactor;      //extract Power Factor into Variable
              float supplyVoltage   = emon1.Vrms;             //extract Vrms into Variable
              float Irms            = emon1.Irms;             //extract Irms into Variable
              float apparentPower2   = emon2.apparentPower;    //extract Apparent Power into variable
              float powerFactor2     = emon2.powerFactor;      //extract Power Factor into Variable
              float supplyVoltage2   = emon2.Vrms;             //extract Vrms into Variable
              float Irms2            = emon2.Irms;             //extract Irms into Variable
              float apparentPower3   = emon3.apparentPower;    //extract Apparent Power into variable
              float powerFactor3     = emon3.powerFactor;      //extract Power Factor into Variable
              float supplyVoltage3   = emon3.Vrms;             //extract Vrms into Variable
              float Irms3            = emon3.Irms;             //extract Irms into Variable
              if(apparentPower > 0 && apparentPower < 10000){
              gw.send(apparentPowerMsg.set(apparentPower,1));
              if(powerFactor > 0 && powerFactor < 10000){
              gw.send(powerFActorMsg.set(powerFactor,1));
              if(supplyVoltage > 0 && supplyVoltage < 1000){
              gw.send(supplyVoltageMsg.set(supplyVoltage,1));
              if(Irms > 0 && Irms < 1000){
              gw.send(IrmsMsg.set(Irms,1));
              if(apparentPower2 > 0 && apparentPower2 < 10000){
              gw.send(apparentPowerMsg2.set(apparentPower2,1));
              if(powerFactor2 > 0 && powerFactor2 < 10000){
              gw.send(powerFActorMsg2.set(powerFactor2,1));
              if(supplyVoltage2 > 0 && supplyVoltage2 < 1000){
              gw.send(supplyVoltageMsg2.set(supplyVoltage2,1));
              if(Irms2 > 0 && Irms2 < 1000){
              gw.send(IrmsMsg2.set(Irms2,1));
              if(apparentPower3 > 0 && apparentPower3 < 10000){
              gw.send(apparentPowerMsg3.set(apparentPower3,1));
              if(powerFactor3 > 0 && powerFactor3 < 10000){
              gw.send(powerFActorMsg3.set(powerFactor3,1));
              if(supplyVoltage3 > 0 && supplyVoltage3 < 1000){
              gw.send(supplyVoltageMsg3.set(supplyVoltage3,1));
              if(Irms3 > 0 && Irms3 < 1000){
              gw.send(IrmsMsg3.set(Irms3,1));
              lastSend2 = now;
          • E
            E
            ewgor
            Thank you for sharing this code.
            I modified your code only for a CT sensor which is connected to A0. The CT is connected to a 40 Watts lamp and this is what i get on Arduino serial monitor:
            sensor started, id 4
            send: 4-4-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
            send: 4-4-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
            send: 4-4-0-0 s=255,c=3,t=11,pt=0,l=18,st=ok:Energy Meter x 3v2
            send: 4-4-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.2
            send: 4-4-0-0 s=0,c=0,t=13,pt=0,l=0,st=ok:
            send: 4-4-0-0 s=0,c=1,t=24,pt=7,l=5,st=ok:0.1
            what is the last value (0.1)? Amps? if i turn off the lamp the i get 0.0!
            In your sketch i see you calculate the real power, power factor, Vrms (volts?) and Irms (Amps?)
            why is displaying in the serial monitor only one value which i assume is Irms?
            I would like to calculate only the power and to export this to openhab but.....i dont know how :(
            • D
              D
              deennoo
              Hi Nice job hère !
              Do you think your sketch can work with this ?
              http://fr.aliexpress.com/item/PEACEFAIR-AC-100A-Electric-power-monitoring-and-communication-module-power-meter-power-energy-Volt-Ammeter/32373508101.html
              nicofly974N 1 Reply Last reply
              • D deennoo
                Hi Nice job hère !
                nicofly974N
                nicofly974N
                nicofly974
                @maglo18
                I have a question about your sensor
                I want to do a similar sensor, with 3 or more Amp meter but just one voltage.
                Is it possible ( or a bad idear) to use transformer for measuring voltage and use as power suply (with regulation 5v and 3,3v) for sensor?
                Thank's
                  maglo18
                  You can use one voltage and use few Amps but only on one phase . If you want to measure Amps on other phases you should add another voltage meter on each phases.
                  You can't to use transformer for power supply because on transformer for measuring is AC voltage and power supply for arduino is DC voltage
                  • nicofly974N
                    nicofly974N
                    nicofly974
                    For precision, I've just one phase at home, but I want few Amps meter for different "sectors" of the house.
                    My question was: Is it a good idea to use the transformer (I've a AC 220V to AC 12v 3VA) for both using: power supply of the sensor (with rectifier bridge and capacity and regulator) and for voltage meter (with divider bridge as you do in your sensor).
                    Or it's a bad idear: Is it possible, in this configuration, to generate a voltage variation when arduino send informations?
                    • staehlerS
                      staehlerS
                      staehler
                      Where do I get the calibration of a SCT-013-000 from. I found this description https://openenergymonitor.org/emon/buildingblocks/ct-and-ac-power-adaptor-installation-and-calibration-theory but unfortunately, I've no idea how to measure the correct calibration.
                      As far as I understand this article, there could be a total error of 19.5% in uncalibrated case.
                      Can anybody help an non-electrician ;-)
                      • Richad HarianjaR
                        Richad HarianjaR
                        Richad Harianja
                        @maglo18
                        Help me please, I have a SCT 013-000 sensor but i do not have python program code. I want to use these sensors to measure electric current power. The sensor is connected with raspberry pi.
