  3. Custom power meter
Custom power meter
31 Posts 15 Posters 33.4k Views 14 Watching
  • M Offline
    M Offline
    maglo18
    wrote on last edited by maglo18
    I created a power meter based on emoncms. My code does not work quite correctly. When I run not everything is fine, but after reboot gets below the value of information and does not update.
    10-12-2014 12:02:57: 0;0;3;0;9;send: 0-0-6-6 s=255,c=3,t=8,pt=1,l=1,st=fail:0
    10-12-2014 12:02:56: 0;0;3;0;9;read: 6-6-255 s=255,c=3,t=7,pt=0,l=0:
    10-12-2014 12:02:36: 0;0;3;0;9;send: 0-0-6-6 s=255,c=3,t=8,pt=1,l=1,st=fail:0
    10-12-2014 12:02:36: 0;0;3;0;9;read: 6-6-255 s=255,c=3,t=7,pt=0,l=0:
    10-12-2014 12:02:16: 0;0;3;0;9;send: 0-0-6-6 s=255,c=3,t=8,pt=1,l=1,st=fail:0
    My sketch:. If i can improve code help me please
    // EmonLibrary examples openenergymonitor.org, Licence GNU GPL V3
    #include "EmonLib.h"             // Include Emon Library
    EnergyMonitor emon1;             // Create an instance
    EnergyMonitor emon2;             // Create an instance
    EnergyMonitor emon3;             // Create an instance
    #define CHILD_ID 0
    #define CHILD_ID2 1
    #define CHILD_ID3 2
    unsigned long lastSend;
    unsigned long SEND_FREQUENCY = 20000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
    MyMessage realPowerMsg(CHILD_ID,V_VAR1);
    MyMessage apparentPowerMsg(CHILD_ID,V_VAR2);
    MyMessage powerFActorMsg(CHILD_ID,V_VAR3);
    MyMessage supplyVoltageMsg(CHILD_ID,V_VAR4);
    MyMessage IrmsMsg(CHILD_[link text](CHILD_ID,V_VAR5);
    MyMessage realPowerMsg2(CHILD_ID2,V_VAR1);
    MyMessage apparentPowerMsg2(CHILD_ID2,V_VAR2);
    MyMessage powerFActorMsg2(CHILD_ID2,V_VAR3);
    MyMessage supplyVoltageMsg2(CHILD_ID2,V_VAR4);
    MyMessage IrmsMsg2(CHILD_ID2,V_VAR5);
    MyMessage realPowerMsg3(CHILD_ID3,V_VAR1);
    MyMessage apparentPowerMsg3(CHILD_ID3,V_VAR2);
    MyMessage powerFActorMsg3(CHILD_ID3,V_VAR3);
    MyMessage supplyVoltageMsg3(CHILD_ID3,V_VAR4);
    MyMessage IrmsMsg3(CHILD_ID3,V_VAR5);
      gw.begin();
      gw.sendSketchInfo("Energy Meter x 3", "2.0");
      gw.present(CHILD_ID, S_POWER);
      gw.present(CHILD_ID2, S_POWER);
      gw.present(CHILD_ID3, S_POWER);
      emon1.voltage(A3, 116.26, 1.7);  // Voltage: input pin, calibration, phase_shift
      emon1.current(A0, 29.1);       // Current: input pin, calibration.
      emon2.voltage(A4, 116.76, 1.7);  // Voltage: input pin, calibration, phase_shift
      emon2.current(A1, 29.1);       // Current: input pin, calibration.
      emon3.voltage(A5, 116.46, 1.7);  // Voltage: input pin, calibration, phase_shift
      emon3.current(A2, 29.1);       // Current: input pin, calibration.
      gw.process();
      unsigned long now = millis();
      emon1.calcVI(20,2000);         // Calculate all. No.of half wavelengths (crossings), time-out
      //emon1.serialprint();           // Print out all variables (realpower, apparent power, Vrms, Irms, power factor)
      emon2.calcVI(20,2000);         // Calculate all. No.of half wavelengths (crossings), time-out
      //emon2.serialprint();           // Print out all variables (realpower, apparent power, Vrms, Irms, power factor)
      emon3.calcVI(20,2000);         // Calculate all. No.of half wavelengths (crossings), time-out
      //emon3.serialprint();           // Print out all variables (realpower, apparent power, Vrms, Irms, power factor)
      bool sendTime = now - lastSend > SEND_FREQUENCY;
      if (sendTime) {
        float realPower       = emon1.realPower;        //extract Real Power into variable
        float apparentPower   = emon1.apparentPower;    //extract Apparent Power into variable
        float powerFactor     = emon1.powerFactor;      //extract Power Factor into Variable
        float supplyVoltage   = emon1.Vrms;             //extract Vrms into Variable
        float Irms            = emon1.Irms;             //extract Irms into Variable
        float realPower2       = emon2.realPower;        //extract Real Power into variable
        float apparentPower2   = emon2.apparentPower;    //extract Apparent Power into variable
        float powerFactor2     = emon2.powerFactor;      //extract Power Factor into Variable
        float supplyVoltage2   = emon2.Vrms;             //extract Vrms into Variable
        float Irms2            = emon2.Irms;             //extract Irms into Variable
        float realPower3       = emon3.realPower;        //extract Real Power into variable
        float apparentPower3   = emon3.apparentPower;    //extract Apparent Power into variable
        float powerFactor3     = emon3.powerFactor;      //extract Power Factor into Variable
        float supplyVoltage3   = emon3.Vrms;             //extract Vrms into Variable
        float Irms3            = emon3.Irms;             //extract Irms into Variable
        gw.send(realPowerMsg.set(realPower,1));
        gw.send(apparentPowerMsg.set(apparentPower,1));
        gw.send(powerFActorMsg.set(powerFactor,1));
        gw.send(supplyVoltageMsg.set(supplyVoltage,1));
        gw.send(IrmsMsg.set(Irms,1));
        gw.send(realPowerMsg2.set(realPower2,1));
        gw.send(apparentPowerMsg2.set(apparentPower2,1));
        gw.send(powerFActorMsg2.set(powerFactor2,1));
        gw.send(supplyVoltageMsg2.set(supplyVoltage2,1));
        gw.send(IrmsMsg2.set(Irms2,1));
        gw.send(realPowerMsg3.set(realPower3,1));
        gw.send(apparentPowerMsg3.set(apparentPower3,1));
        gw.send(powerFActorMsg3.set(powerFactor3,1));
        gw.send(supplyVoltageMsg3.set(supplyVoltage3,1));
        gw.send(IrmsMsg3.set(Irms3,1));
        lastSend = now;
    • G Offline
      G Offline
      gigi
      I have emon energymonitor but trasmission is with RFM12B radio!!!
      Vera lite - mysensors Ethernet gateway - AirWik sensor - Relay Module
      • G Offline
        G Offline
        Gambituk
        Hi, any progress with this? I would be interested in trying to adapt this to my needs. I have just finished setting up the basic arduino sketch from http://openenergymonitor.org/emon/buildingblocks/how-to-build-an-arduino-energy-monitor-measuring-current-only
        and i assume this should just work with the sketch you are working on?
        M 1 Reply Last reply
        • G Gambituk
          M Offline
          M Offline
          maglo18
          My hardware is on photo. I prepare hardware from emoncms site for 3 phases. My sketh working good so far about 3 weeks. My controler is pidome and send values to emoncms on mys NAS.
          B R 2 Replies Last reply
          • M maglo18
            B Offline
            B Offline
            boozz
            @maglo18
            Please put back the plastic cover :-)
            Looks good btw
            Boozz
            • M maglo18
              R Offline
              R Offline
              RJ_Make
              @maglo18 Is that 3 transformers in that box?
              RJ_Make
              • R RJ_Make
                M Offline
                M Offline
                maglo18
                @ServiceXp In the box are 3 transformer, one for each phase to measure the voltage
                G 1 Reply Last reply
                • M maglo18
                  G Offline
                  G Offline
                  gigi
                  wrote on last edited by gigi
                  @maglo18 How to transmit data to emoncms?
                  • M Offline
                    M Offline
                    maglo18
                    I use Pidome server and by automation rule send values to emoncms..
                    • T Offline
                      T Offline
                      tbully
                      I've been looking in to this for quite some time. Here in the US, our residential wiring is usually 220V "split-phase" where we have a neutral/ground connection that allows us to get 120V from either "leg" (not to be confused with phase) to "ground". If you go "leg to leg", you'll get the full 220V of the phase.
                      I've been searching quite a bit and am a little confused so I was hoping that you could expand on your solution a bit. (schematics, part numbers, full sketch) Your efforts look great. I'm wondering how you've integrated in to MySensors (and your controller, Vera?)
                      In my case, I think that I will need to do the following:
                      1. Have two CT's - one for each leg
                      2. Have two transformers to measure each leg to neutral
                      3. Somehow convert the voltage-measurement transformers in to something Arduino can read (0-5V)
                      4. Convert the current induced by the CTs to a voltage that the Arduino can read
                      5. Do the "V*I" math to calculate power, etc.
                      Most US based solutions call for only one transformer/leg-measurement. However, I have seen an imbalance in my utility power. I'm not sure if this is due to underground resistance, faulty utility transformers, etc. But my point is, I think it'd be safer to measure both, do my calculations separately, and then add them accordingly (in software) to get total power consumption.
                      Can you expand a bit on my thoughts? Has anyone in the US been successful in my above approach?
                      • E Offline
                        E Offline
                        epierre
                        @maglo18 why do you need a transformer ? my owl ones work on battery, couldn't that simplpify the sketch ?
                        z-wave - Vera -&gt; Domoticz
                        rfx - Domoticz &lt;- MyDomoAtHome &lt;- Imperihome
                        mysensors -&gt; mysensors-gw -&gt; Domoticz
                        • M Offline
                          M Offline
                          maglo18
                          I use transformer to measure voltage on each from three phases
                          E 1 Reply Last reply
                          • chatainsimC Offline
                            chatainsimC Offline
                            chatainsim
                            @maglo18 how many is your burden resistor ?
                            If found a blog where he talk about of turn in the sensor, do you know how many is it ?
                            http://www.homautomation.org/2013/09/17/current-monitoring-with-non-invasive-sensor-and-arduino/
                            • DidiD Offline
                              DidiD Offline
                              Didi
                              @maglo18
                              please explain how to use one transformer on 3 phases to measure voltage on each
                              if (knowledge == 0) { use BRAIN; use GOOGLE;use SEARCH; } else {make POST;}
                              • M maglo18
                                E Offline
                                E Offline
                                epierre
                                I have at home some OWL CM180i that work on batteries... how can it be applied to the example here ?
                                • M Offline
                                  M Offline
                                  maglo18
                                  I use 3 x transformers One for each phase
                                  • DidiD Offline
                                    DidiD Offline
                                    Didi
                                    Sorry for me it sounds like you use 1 transformer that was confusing me ;-)
                                    • E Offline
                                      E Offline
                                      ewgor
                                      Have anyone integrated this with Openhab? can we find somwhere some Openhab items, rules for this sketch that @maglo18 posted here http://forum.mysensors.org/topic/1464/sct-013-030-current-monitor-sensor?
                                      Thanks for any help!
                                      • G Offline
                                        G Offline
                                        Gambituk
                                        Hi @maglo18 i have been using a current only version of emon for quite some time, i am interested in adding the ac-ac transformer to calculate the apparent power more accurately. Do you have a project page for your build with diagrams and specs? What type of transformers are you using (i can just about read it from picture) and how happy are you with the performance?
                                        Thanks Gambituk
                                        • E Offline
                                          E Offline
                                          ewgor
                                          wrote on last edited by ewgor
                                          Hi All,
                                          Did anyone worked with this sensor SCT-013-000 and Openhab? I would like to ask how can I integrate this with Openhab so to be able to display the apparent power consumption in watts, to display the Kwh starting a certain date lets say starting on 12th this month or from today as for example and to display to total Kwh.
                                          @maglo18 where are you from?
                                          Any help or suggestion will be kindly appreciated.
                                          Thanks All!
