  3. Device to remotely turn a thermostat
7 Posts 4 Posters 8.9k Views 1 Watching
  • CorvlC
    CorvlC
    Corvl
    My house is getting all automated by now , thanks to vera and Z-wave. And now Arduino comes into play !! :-)
    My heating system is also automated , by means of Fibaro relais which turns things (the system itself or pumps) on and off. And radiators have danfoss Z-wave thermostats attached to it.
    But my floorheating ..... that was a different story. It had a special thermostat with a temperature sensor going a device which measures the water in the floorheating system.
    Allready demolished a danfoss Z-wave thermostate , trying to make the tempretaure sensor external , but no joy.
    Huray for Arduino.
    Building the gateway was easy enough, building a servo-actuator with an arduino UNO was also very easy.
    On vera there was an issue with the slider , with the slider the servo only moves 90 degrees. someone helped me changing some code on the sketch:
    fixed it by replacing the line:
    myservo.write(SERVO_MAX + (SERVO_MIN-SERVO_MAX)/100 * val); // sets the servo position 0-180
    by the following 2 lines of code:
        val = map(val, 0, 100, 0, 180); // scale 0%-100% between 0 and 180)
        myservo.write(val);       // sets the servo position 0-180
    Now the servo was moving the full 180 degrees by means of the slider.
    Than came the mechanical part, I had to make quite a bracket to hold the servo. Initially I had a standard 3 kg/cm servo , but it wasn't enough to completely close the valve. I ended up using a big scale servo with 14 kg/cm on 7V. Offcourse the servo is powered by a seperate 7V, max 5A power supply
    Initially the plan was to attach the servo directly to the thermostat , at that time I didn't know the themostat not only turns , but also moves in-and outwards .....
    Plan 2 was to use a timing belt system with 2 sprockets , also this didn't work , because the servo pulled the thermostat towards it
    Plan 3 finally worked , I routed out of trespa a bracket where the servo could go freely in and out , but not turn itself.
    This trespa ( white) attached to the metal bracket. Now the servo can do it's normal thing , turn the lever , but also move in and outward
    Here 2 pictures:
    A succesfull project I must say :-)
    tbowmoT RJ_MakeR 2 Replies Last reply
      Wow, impressive!
      • CorvlC Corvl
        Huray for Arduino.
        Here 2 pictures:
        tbowmoT
        tbowmoT
        tbowmo
        @Corvl
        Nice mechanical build :)
        You could get electrically controled valves instead, for example a Danfoss TWA-A 24V NC, Still have the arduino control it through PWM..
        • CorvlC Corvl
          Huray for Arduino.
          Here 2 pictures:
          RJ_MakeR
          RJ_MakeR
          RJ_Make
          @Corvl Very Nice.
          RJ_Make
          • CorvlC
            CorvlC
            Corvl
            Thanks for the nice words :-)
            @ tbowmo: ......ohhhhhh , didn't know they existed , that would have been even a neater solution ( and probably quicker) , anyway , my system is working now.
            Cor
            • CorvlC
              CorvlC
              Corvl
              wrote on last edited by Corvl
              one more question.
              Controlling the thermostat I have a picture on the GUI and authomation app on my android of a window with curtains..... any possibility I can change this with another Icon, Just to make it a bit more perfect :-)
              thanks,
              Cor
              • CorvlC
                CorvlC
                Corvl
                Answer to myself:
                I use now Imperihome , with that you can use your own icons :-)
