  3. NRF24L01 & HLK-pm01
NRF24L01 & HLK-pm01
4 Posts 3 Posters 1.3k Views 3 Watching
  • A Offline
    A Offline
    alb12
    I have made a PCB for a relay with nrf24L01, attiny and HLK-PM01.
    If I feed the pcb with the arduino, with 3v or 5v I have no problem, the relay switches but when the PCB feed whith the electric outlet the relay don't switch always.
    I don't know what, maybe the radio signal of nrf24 dont received.
    Have you an idea?
    Thank you
    • A alb12
      Have you an idea?
      Thank you
      Welcome to the MySensors community @alb12
      The quickest way to see what is happening is to activate serial debug. The debug output will show what happens.
      See https://www.mysensors.org/build/debug#enabling-debug-and-monitoring-the-logs for more detailed information.
      • A Offline
        A Offline
        alb12
        Yes but I use an Attiny84 so I can't use the serial debug
        • rozpruwaczR Offline
          rozpruwaczR Offline
          rozpruwacz
          Use debugging LED :)
