  2. Bug Reports
  3. Raspberry Gateway 2.1.1 + signing
34 Posts 3 Posters 9.4k Views 4 Watching
  • t3chieT
    t3chieT
    t3chie
    The Gateway code on Raspberry seems to work only when signing is not used.
    Is that something known?
    In addition, I had to explicitly name the architecture and comment out one line in core/MySigningAtsha204Soft.cpp to get the debug signing output working:
    #ifdef linux
    #define __FlashStringHelper char
    // #define MY_SERIALDEVICE.print debug
    My configure options were:
    ./configure --my-gateway=ethernet
    --soc=BCM2836
    --my-transport=nrf24
    --my-rf24-ce-pin=22
    --my-rf24-cs-pin=24
    --my-rf24-irq-pin=15
    --my-rf24-pa-level=RF24_PA_LOW
    --my-leds-err-pin=12
    --my-leds-rx-pin=16
    --my-leds-tx-pin=18
    --my-signing=software
    --my-signing-request-signatures
    --my-signing-request-gw-signatures-from-all
    --my-rf24-encryption-enabled
    --my-rf24-channel=70
    --my-debug=enable
    --my-signing-debug
    Tested with a Raspberry 1 and 2.
    • t3chieT t3chie
      #ifdef linux
      --soc=BCM2836
      --my-rf24-ce-pin=22
      --my-rf24-cs-pin=24
      --my-leds-rx-pin=16
      --my-leds-tx-pin=18
      --my-debug=enable
      --my-signing-debug
      AnticimexA
      AnticimexA
      Anticimex
      @t3chie hi, this is not known (at least to me). I don't have a rPi setup so I have not been able to verify. @marceloaqno do you know what the current status is? If I remember correctly, you tested the latest signing improvements package successfully on rPi, right?
      t3chieT 1 Reply Last reply
      • t3chieT t3chie
        #ifdef linux
        --soc=BCM2836
        --my-rf24-ce-pin=22
        --my-rf24-cs-pin=24
        --my-leds-rx-pin=16
        --my-leds-tx-pin=18
        --my-debug=enable
        --my-signing-debug
        AnticimexA
        AnticimexA
        Anticimex
        @t3chie btw, the option my-signing-request-gw-signatures-from-all is obsolete. It is the default behavior now. At least if you are on latest development branch.
        • AnticimexA Anticimex
          t3chieT
          t3chieT
          t3chie
          @Anticimex I am happy to test whatever you want me to do. I "think" my wiring is correct as it works when signing is not used. I can post debug output from the Gateway for both (signed and unsigned) if that helps.
          Should I give the dev branch a try?
          AnticimexA 1 Reply Last reply
          • t3chieT t3chie
            AnticimexA
            AnticimexA
            Anticimex
            @t3chie ah you are on master? That's interesting because that should work. Yes, please give the devel branch a try. Could be that full signing support for rPi never made it in the latest release.
              t3chieT
              t3chieT
              t3chie
              @Anticimex That is different but still not working. The architecture autodetection works. The signing debug does compile, too. But when I am starting up a node the gateway reports:
              mysgw: Starting gateway...
              mysgw: Protocol version - 2.2.0-beta
              mysgw: MCO:BGN:INIT GW,CP=RNNG-SQX,VER=2.2.0-beta
              mysgw: !SGN:PER:TAMPERED
              mysgw: !SGN:INI:BND FAIL
              mysgw: TSF:LRT:OK
              mysgw: TSM:INIT
              mysgw: TSF:WUR:MS=0
              mysgw: TSM:INIT:TSP OK
              mysgw: TSM:INIT:GW MODE
              mysgw: MCO:REG:NOT NEEDED
              mysgw: Listening for connections on 0.0.0.0:5003
              mysgw: MCO:BGN:STP
              mysgw: MCO:BGN:INIT OK,TSP=1
              mysgw: TSF:MSG:READ,118-205-14,s=1,c=2,t=118,pt=6,l=0,sg=1:
              mysgw: TSF:MSG:REL MSG
              mysgw: !TSF:RTE:14 UNKNOWN
              mysgw: SGN:SGN:118!=0 NUS
              mysgw: !TSF:MSG:SEND,118-0-14-14,s=1,c=2,t=118,pt=6,l=0,sg=1,ft=0,st=NACK:
              mysgw: TSF:MSG:READ,138-29-188,s=181,c=6,t=66,pt=5,l=16,sg=0:3636023473
              mysgw: !TSF:RTE:188 UNKNOWN
              mysgw: SGN:SGN:138!=0 NUS
              mysgw: !TSF:MSG:SEND,138-0-188-188,s=181,c=6,t=66,pt=5,l=16,sg=0,ft=0,st=NACK:3636023473
              mysgw: TSF:MSG:READ,184-237-134,s=214,c=0,t=229,pt=6,l=13,sg=1:5A403EDF050D2265DF00000000
              mysgw: !TSF:MSG:PVER,3=2
              mysgw: TSF:MSG:READ,233-187-65,s=93,c=1,t=52,pt=1,l=1,sg=1:222
              mysgw: !TSF:MSG:PVER,1=2
              mysgw: TSF:MSG:READ,177-160-211,s=159,c=6,t=135,pt=4,l=11,sg=1:-2047481336
              mysgw: !TSF:MSG:PVER,0=2
              mysgw: TSF:MSG:READ,166-111-53,s=187,c=3,t=196,pt=5,l=9,sg=0:204581490
              mysgw: !TSF:RTE:53 UNKNOWN
              mysgw: SGN:SGN:166!=0 NUS
              mysgw: !TSF:MSG:SEND,166-0-53-53,s=187,c=3,t=196,pt=5,l=9,sg=0,ft=0,st=NACK:204581490
              The only node on that radio channel is ID 100 and if I disable signing, the same setup is reporting:
              mysgw: MCO:BGN:INIT GW,CP=RNNG--Q-,VER=2.2.0-beta
              mysgw: TSF:LRT:OK
              mysgw: TSM:INIT
              mysgw: TSF:WUR:MS=0
              mysgw: MCO:BGN:STP
              mysgw: TSF:MSG:READ,100-100-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
              mysgw: TSF:MSG:BC
              mysgw: TSF:MSG:FPAR REQ,ID=100
              mysgw: TSF:CKU:OK,FCTRL
              mysgw: TSF:MSG:GWL OK
              mysgw: TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
              mysgw: TSF:MSG:READ,100-100-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
              mysgw: TSF:MSG:PINGED,ID=100,HP=1
              mysgw: TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
              mysgw: TSF:MSG:READ,100-100-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
              mysgw: TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
              mysgw: TSF:MSG:READ,100-100-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.1.1
              mysgw: TSF:MSG:READ,100-100-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
              mysgw: TSF:MSG:READ,100-100-0,s=255,c=3,t=11,pt=0,l=13,sg=0:Motion Sensor
              mysgw: TSF:MSG:READ,100-100-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
              mysgw: TSF:MSG:READ,100-100-0,s=1,c=0,t=1,pt=0,l=0,sg=0:
              mysgw: TSF:MSG:READ,100-100-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
              mysgw: TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
              • t3chieT t3chie
                mysgw: TSF:LRT:OK
                mysgw: TSM:INIT
                mysgw: TSF:WUR:MS=0
                mysgw: MCO:BGN:STP
                mysgw: TSF:LRT:OK
                mysgw: TSM:INIT
                mysgw: TSF:WUR:MS=0
                mysgw: MCO:BGN:STP
                mysgw: TSF:MSG:BC
                AnticimexA
                AnticimexA
                Anticimex
                @t3chie looks like the personalization has not finished successfully. How do you store the hmac key to the rPi? If you don't use the personalizer sketch you either need to write the checksum yourself or disable the checksum validation. It could be that the method for personalizing on rPi does not calculate and store a checksum. So either that has to change, or the checksum check should be disabled on rPi/Linux.
                  t3chieT
                  t3chieT
                  t3chie
                  @Anticimex Sorry for that - when I changed Pi's I forgot to personalize the GW. But that didn't made it working:
                  mysgw: TSF:LRT:OK
                  mysgw: TSM:INIT
                  mysgw: TSF:WUR:MS=0
                  mysgw: MCO:BGN:STP
                  mysgw: TSF:MSG:READ,223-72-13,s=199,c=4,t=110,pt=5,l=4,sg=0:3736138177
                  mysgw: TSF:MSG:READ,151-70-68,s=120,c=3,t=166,pt=0,l=15,sg=1:?rQ?0??
                  Isn't the Node ID reported changing between random values although it should only see ID 100 ?
                  • t3chieT t3chie
                    mysgw: TSF:LRT:OK
                    mysgw: TSM:INIT
                    mysgw: TSF:WUR:MS=0
                    mysgw: MCO:BGN:STP
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @t3chie it still reports !SGN:PER:TAMPERED so my original question(s) are still valid :)
                      t3chieT
                      t3chieT
                      t3chie
                      @Anticimex I use:
                      ./bin/mysgw --set-soft-hmac-key D94AB9BF54D266CA517C23C870FF7A6...
                      ./bin/mysgw --set-soft-serial-key 2200002200...
                      How can I calculate the checksum or disable it?
                      • t3chieT t3chie
                        @Anticimex I use:
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @t3chie just comment https://github.com/mysensors/MySensors/blob/development/core/MySigningAtsha204Soft.cpp#L127
                        I'm pretty sure the problem is that on Linux, a checksum is never calculated, so I will patch the init function of the software signing backend to ignore that calculation on Linux.
                        I do also note that you seem to get NACKs. I can already now say that those have to go away for signing to work. See here.
                          t3chieT
                          t3chieT
                          t3chie
                          @Anticimex Have tried to comment out line 127, but as you said no joy. I know that the radio I am using is not the best but I am still not sure if the HW is the culprit here.
                          I have put that RF24 module onto a Nano with itead RF Shield and loaded a 2.1.1 Gateway Sketch including signing - that works against the same node I am testing the Pi.
                          I am using the interrupt variant of the Pi cabling - could that be the problem?
                          • t3chieT t3chie
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @t3chie if you read the troubleshooting guide which I linked to, the topmost and most common issue is radio problems and these are not signing related. They are because you have a flaky radio connection (reasons could be many, and there are a ton of threads on the forum that discuss these). You see these when you enable signing because then full size messages are transmitted and not the relatively small messages you typically transmit.
                              t3chieT
                              t3chieT
                              t3chie
                              @Anticimex Well, I have read all troubleshooting material many times and agree that mostly it is HW. This time however it was stupidity on my side!
                              I mixed up signing with encryption on the Pi compile time flags.
                              To summarize:
                              On 2.1.1, the architecture needs to be set and signing works (have not tested encryption yet).
                              On dev, architecture needs to be left alone (not set) and checksum calculation needs to be commented out (line 127 of MySigningAtsha204Soft.cpp).
                              • t3chieT t3chie
                                To summarize:
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @t3chie ah, ok. Yes, those NUS messages indicated that something was really mixed up :)
                                I will file a pull request to fix the checksum issue. Thanks for reporting!
                                • t3chieT t3chie
                                  To summarize:
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @t3chie Could I ask you a big favour to test my PR on your linux gw and node?
                                  https://github.com/mysensors/MySensors/pull/885
                                    t3chieT
                                    t3chieT
                                    t3chie
                                    @Anticimex Sure, can do.
                                    Would you refresh my memory - how can I check out the tree with that pullrequest?
                                    • t3chieT t3chie
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @t3chie thanks!
                                      git checkout -b fallberg-signing development
                                      git pull https://github.com/fallberg/MySensors.git signing
                                        @t3chie thanks!
                                        t3chieT
                                        t3chieT
                                        t3chie
                                        @Anticimex I did:
                                        git clone https://github.com/mysensors/MySensors.git --branch development
                                        cd MySensors
                                        Then compile with:
                                        --my-rf24-ce-pin=22
                                        --my-rf24-cs-pin=24
                                        --my-leds-rx-pin=16
                                        --my-leds-tx-pin=18
                                        --my-rf24-channel=76
                                        --my-debug=enable
                                        --my-signing-debug
                                        Result with one node restarting while others are already running:
                                        mysgw: TSF:MSG:BC
                                        mysgw: TSF:PNG:SEND,TO=0
                                        mysgw: TSF:CKU:OK
                                        mysgw: SGN:SKP:MSG CMD=3,TYPE=8
                                        mysgw: TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=8,pt=1,l=1,sg=1,ft=0,st=OK:0
                                        mysgw: SGN:SKP:MSG CMD=3,TYPE=24
                                        mysgw: SGN:SKP:MSG CMD=3,TYPE=25
                                        mysgw: TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=25,pt=1,l=1,sg=1,ft=0,st=OK:1
                                        mysgw: SGN:SKP:MSG CMD=3,TYPE=15
                                        mysgw: SGN:PRE:SGN REQ,FROM=100
                                        mysgw: !SGN:PRE:WHI NREQ,FROM=100 REJ
                                        mysgw: SGN:PRE:SGN REQ,TO=100
                                        mysgw: SGN:PRE:WHI NREQ,TO=100
                                        mysgw: TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
                                        mysgw: SGN:PRE:XMT,TO=100
                                        mysgw: TSF:MSG:READ,100-100-0,s=255,c=3,t=16,pt=0,l=0,sg=0:
                                        mysgw: SGN:SKP:MSG CMD=3,TYPE=16
                                        mysgw: !SGN:NCE:GEN
                                        mysgw: !SGN:NCE:GEN
                                        mysgw: !SGN:NCE:GEN
                                        mysgw: !SGN:NCE:GEN
                                        mysgw: TSF:MSG:READ,100-100-0,s=1,c=3,t=16,pt=0,l=0,sg=0:
                                        mysgw: !SGN:NCE:GEN
                                        mysgw: SGN:SKP:MSG CMD=3,TYPE=26
                                        mysgw: TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                                        mysgw: SGN:SGN:NCE REQ,TO=100
                                        mysgw: TSF:MSG:READ,100-100-0,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                                        mysgw: SGN:SKP:MSG CMD=3,TYPE=17
                                        mysgw: SGN:NCE:FROM=100
                                        mysgw: SGN:BND:NONCE=4BD28D2B47813291B354D4A856B07E7A6B496CF86FA2FF969D7C2D115FAC09DF
                                        mysgw: SGN:BND:HMAC=07FF305FFEB4D1489C3C9BA63A281890DDD850573B406FB691C09C23DC12DD00
                                        mysgw: SGN:BND:SIG WHI,ID=0
                                        mysgw: SGN:BND:SIG WHI,SERIAL=000000000000000000
                                        mysgw: SGN:SGN:SGN
                                        mysgw: TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=27,pt=1,l=1,sg=1,ft=0,st=OK:1
                                        Looks OK for me, right?
                                        AnticimexA 3 Replies Last reply
                                        • t3chieT t3chie
                                          @Anticimex I did:
                                          cd MySensors
                                          Then compile with:
                                          --my-rf24-ce-pin=22
                                          --my-rf24-cs-pin=24
                                          --my-leds-rx-pin=16
                                          --my-leds-tx-pin=18
                                          --my-debug=enable
                                          --my-signing-debug
                                          mysgw: TSF:MSG:BC
                                          mysgw: TSF:CKU:OK
                                          mysgw: !SGN:NCE:GEN
                                          mysgw: !SGN:NCE:GEN
                                          mysgw: !SGN:NCE:GEN
                                          mysgw: !SGN:NCE:GEN
                                          mysgw: !SGN:NCE:GEN
                                          mysgw: SGN:SGN:SGN
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          @t3chie I think so. There are a few errors in the log though but I am not sure if that is due to other nodes on your network not being configured properly.
