  2. Bug Reports
  3. Raspberry Gateway 2.1.1 + signing
34 Posts 3 Posters 9.4k Views 4 Watching
  • AnticimexA Anticimex
    @t3chie hi, this is not known (at least to me). I don't have a rPi setup so I have not been able to verify. @marceloaqno do you know what the current status is? If I remember correctly, you tested the latest signing improvements package successfully on rPi, right?
    t3chieT
    t3chieT
    t3chie
    @Anticimex I am happy to test whatever you want me to do. I "think" my wiring is correct as it works when signing is not used. I can post debug output from the Gateway for both (signed and unsigned) if that helps.
    Should I give the dev branch a try?
    AnticimexA 1 Reply Last reply
    • t3chieT t3chie
      AnticimexA
      AnticimexA
      Anticimex
      @t3chie ah you are on master? That's interesting because that should work. Yes, please give the devel branch a try. Could be that full signing support for rPi never made it in the latest release.
      t3chieT 1 Reply Last reply
        t3chieT
        t3chieT
        t3chie
        @Anticimex That is different but still not working. The architecture autodetection works. The signing debug does compile, too. But when I am starting up a node the gateway reports:
        mysgw: Starting gateway...
        mysgw: MCO:BGN:INIT GW,CP=RNNG-SQX,VER=2.2.0-beta
        mysgw: !SGN:PER:TAMPERED
        mysgw: !SGN:INI:BND FAIL
        mysgw: TSF:LRT:OK
        mysgw: TSM:INIT
        mysgw: TSF:WUR:MS=0
        mysgw: TSM:INIT:TSP OK
        mysgw: TSM:INIT:GW MODE
        mysgw: MCO:REG:NOT NEEDED
        mysgw: MCO:BGN:STP
        mysgw: MCO:BGN:INIT OK,TSP=1
        mysgw: TSF:MSG:READ,118-205-14,s=1,c=2,t=118,pt=6,l=0,sg=1:
        mysgw: TSF:MSG:REL MSG
        mysgw: !TSF:RTE:14 UNKNOWN
        mysgw: SGN:SGN:118!=0 NUS
        mysgw: !TSF:MSG:SEND,118-0-14-14,s=1,c=2,t=118,pt=6,l=0,sg=1,ft=0,st=NACK:
        mysgw: TSF:MSG:READ,138-29-188,s=181,c=6,t=66,pt=5,l=16,sg=0:3636023473
        mysgw: !TSF:RTE:188 UNKNOWN
        mysgw: SGN:SGN:138!=0 NUS
        mysgw: !TSF:MSG:SEND,138-0-188-188,s=181,c=6,t=66,pt=5,l=16,sg=0,ft=0,st=NACK:3636023473
        mysgw: TSF:MSG:READ,184-237-134,s=214,c=0,t=229,pt=6,l=13,sg=1:5A403EDF050D2265DF00000000
        mysgw: !TSF:MSG:PVER,3=2
        mysgw: TSF:MSG:READ,233-187-65,s=93,c=1,t=52,pt=1,l=1,sg=1:222
        mysgw: !TSF:MSG:PVER,1=2
        mysgw: TSF:MSG:READ,177-160-211,s=159,c=6,t=135,pt=4,l=11,sg=1:-2047481336
        mysgw: !TSF:MSG:PVER,0=2
        mysgw: TSF:MSG:READ,166-111-53,s=187,c=3,t=196,pt=5,l=9,sg=0:204581490
        mysgw: !TSF:RTE:53 UNKNOWN
        mysgw: SGN:SGN:166!=0 NUS
        mysgw: !TSF:MSG:SEND,166-0-53-53,s=187,c=3,t=196,pt=5,l=9,sg=0,ft=0,st=NACK:204581490
        The only node on that radio channel is ID 100 and if I disable signing, the same setup is reporting:
        mysgw: MCO:BGN:INIT GW,CP=RNNG--Q-,VER=2.2.0-beta
        mysgw: TSF:LRT:OK
        mysgw: TSM:INIT
        mysgw: TSF:WUR:MS=0
        mysgw: MCO:BGN:STP
        mysgw: TSF:MSG:READ,100-100-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        mysgw: TSF:MSG:BC
        mysgw: TSF:MSG:FPAR REQ,ID=100
        mysgw: TSF:CKU:OK,FCTRL
        mysgw: TSF:MSG:GWL OK
        mysgw: TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
        mysgw: TSF:MSG:READ,100-100-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
        mysgw: TSF:MSG:PINGED,ID=100,HP=1
        mysgw: TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
        mysgw: TSF:MSG:READ,100-100-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
        mysgw: TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
        mysgw: TSF:MSG:READ,100-100-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.1.1
        mysgw: TSF:MSG:READ,100-100-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
        mysgw: TSF:MSG:READ,100-100-0,s=255,c=3,t=11,pt=0,l=13,sg=0:Motion Sensor
        mysgw: TSF:MSG:READ,100-100-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
        mysgw: TSF:MSG:READ,100-100-0,s=1,c=0,t=1,pt=0,l=0,sg=0:
        mysgw: TSF:MSG:READ,100-100-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
        mysgw: TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
        • t3chieT t3chie
          mysgw: TSF:LRT:OK
          mysgw: TSM:INIT
          mysgw: TSF:WUR:MS=0
          mysgw: MCO:BGN:STP
          mysgw: TSF:LRT:OK
          mysgw: TSM:INIT
          mysgw: TSF:WUR:MS=0
          mysgw: MCO:BGN:STP
          mysgw: TSF:MSG:BC
          AnticimexA
          AnticimexA
          Anticimex
          @t3chie looks like the personalization has not finished successfully. How do you store the hmac key to the rPi? If you don't use the personalizer sketch you either need to write the checksum yourself or disable the checksum validation. It could be that the method for personalizing on rPi does not calculate and store a checksum. So either that has to change, or the checksum check should be disabled on rPi/Linux.
            t3chieT
            t3chieT
            t3chie
            @Anticimex Sorry for that - when I changed Pi's I forgot to personalize the GW. But that didn't made it working:
            mysgw: TSF:LRT:OK
            mysgw: TSM:INIT
            mysgw: TSF:WUR:MS=0
            mysgw: MCO:BGN:STP
            mysgw: TSF:MSG:READ,223-72-13,s=199,c=4,t=110,pt=5,l=4,sg=0:3736138177
            mysgw: TSF:MSG:READ,151-70-68,s=120,c=3,t=166,pt=0,l=15,sg=1:?rQ?0??
            Isn't the Node ID reported changing between random values although it should only see ID 100 ?
            • t3chieT t3chie
              mysgw: TSF:LRT:OK
              mysgw: TSM:INIT
              mysgw: TSF:WUR:MS=0
              mysgw: MCO:BGN:STP
              AnticimexA
              AnticimexA
              Anticimex
              @t3chie it still reports !SGN:PER:TAMPERED so my original question(s) are still valid :)
                t3chieT
                t3chieT
                t3chie
                @Anticimex I use:
                ./bin/mysgw --set-soft-hmac-key D94AB9BF54D266CA517C23C870FF7A6...
                ./bin/mysgw --set-soft-serial-key 2200002200...
                How can I calculate the checksum or disable it?
                • t3chieT t3chie
                  @Anticimex I use:
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @t3chie just comment https://github.com/mysensors/MySensors/blob/development/core/MySigningAtsha204Soft.cpp#L127
                  I'm pretty sure the problem is that on Linux, a checksum is never calculated, so I will patch the init function of the software signing backend to ignore that calculation on Linux.
                  I do also note that you seem to get NACKs. I can already now say that those have to go away for signing to work. See here.
                    t3chieT
                    t3chieT
                    t3chie
                    @Anticimex Have tried to comment out line 127, but as you said no joy. I know that the radio I am using is not the best but I am still not sure if the HW is the culprit here.
                    I have put that RF24 module onto a Nano with itead RF Shield and loaded a 2.1.1 Gateway Sketch including signing - that works against the same node I am testing the Pi.
                    I am using the interrupt variant of the Pi cabling - could that be the problem?
                    • t3chieT t3chie
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @t3chie if you read the troubleshooting guide which I linked to, the topmost and most common issue is radio problems and these are not signing related. They are because you have a flaky radio connection (reasons could be many, and there are a ton of threads on the forum that discuss these). You see these when you enable signing because then full size messages are transmitted and not the relatively small messages you typically transmit.
                        t3chieT
                        t3chieT
                        t3chie
                        @Anticimex Well, I have read all troubleshooting material many times and agree that mostly it is HW. This time however it was stupidity on my side!
                        I mixed up signing with encryption on the Pi compile time flags.
                        To summarize:
                        On 2.1.1, the architecture needs to be set and signing works (have not tested encryption yet).
                        On dev, architecture needs to be left alone (not set) and checksum calculation needs to be commented out (line 127 of MySigningAtsha204Soft.cpp).
                        • t3chieT t3chie
                          To summarize:
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @t3chie ah, ok. Yes, those NUS messages indicated that something was really mixed up :)
                          I will file a pull request to fix the checksum issue. Thanks for reporting!
                          • t3chieT t3chie
                            To summarize:
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @t3chie Could I ask you a big favour to test my PR on your linux gw and node?
                            https://github.com/mysensors/MySensors/pull/885
                              t3chieT
                              t3chieT
                              t3chie
                              @Anticimex Sure, can do.
                              Would you refresh my memory - how can I check out the tree with that pullrequest?
                              • t3chieT t3chie
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @t3chie thanks!
                                git checkout -b fallberg-signing development
                                git pull https://github.com/fallberg/MySensors.git signing
                                  @t3chie thanks!
                                  t3chieT
                                  t3chieT
                                  t3chie
                                  @Anticimex I did:
                                  git clone https://github.com/mysensors/MySensors.git --branch development
                                  cd MySensors
                                  Then compile with:
                                  --my-transport=nrf24
                                  --my-rf24-ce-pin=22
                                  --my-rf24-cs-pin=24
                                  --my-rf24-irq-pin=15
                                  --my-rf24-pa-level=RF24_PA_LOW
                                  --my-leds-err-pin=12
                                  --my-leds-rx-pin=16
                                  --my-leds-tx-pin=18
                                  --my-rf24-channel=76
                                  --my-debug=enable
                                  --my-signing=software
                                  --my-signing-request-signatures
                                  --my-signing-request-gw-signatures-from-all
                                  --my-signing-debug
                                  Result with one node restarting while others are already running:
                                  mysgw: TSF:MSG:BC
                                  mysgw: TSF:PNG:SEND,TO=0
                                  mysgw: TSF:CKU:OK
                                  mysgw: SGN:SKP:MSG CMD=3,TYPE=8
                                  mysgw: TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=8,pt=1,l=1,sg=1,ft=0,st=OK:0
                                  mysgw: SGN:SKP:MSG CMD=3,TYPE=24
                                  mysgw: SGN:SKP:MSG CMD=3,TYPE=25
                                  mysgw: TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=25,pt=1,l=1,sg=1,ft=0,st=OK:1
                                  mysgw: SGN:SKP:MSG CMD=3,TYPE=15
                                  mysgw: SGN:PRE:SGN REQ,FROM=100
                                  mysgw: !SGN:PRE:WHI NREQ,FROM=100 REJ
                                  mysgw: SGN:PRE:SGN REQ,TO=100
                                  mysgw: SGN:PRE:WHI NREQ,TO=100
                                  mysgw: TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
                                  mysgw: SGN:PRE:XMT,TO=100
                                  mysgw: TSF:MSG:READ,100-100-0,s=255,c=3,t=16,pt=0,l=0,sg=0:
                                  mysgw: SGN:SKP:MSG CMD=3,TYPE=16
                                  mysgw: !SGN:NCE:GEN
                                  mysgw: !SGN:NCE:GEN
                                  mysgw: !SGN:NCE:GEN
                                  mysgw: !SGN:NCE:GEN
                                  mysgw: TSF:MSG:READ,100-100-0,s=1,c=3,t=16,pt=0,l=0,sg=0:
                                  mysgw: !SGN:NCE:GEN
                                  mysgw: SGN:SKP:MSG CMD=3,TYPE=26
                                  mysgw: TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                                  mysgw: SGN:SGN:NCE REQ,TO=100
                                  mysgw: TSF:MSG:READ,100-100-0,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                                  mysgw: SGN:SKP:MSG CMD=3,TYPE=17
                                  mysgw: SGN:NCE:FROM=100
                                  mysgw: SGN:BND:NONCE=4BD28D2B47813291B354D4A856B07E7A6B496CF86FA2FF969D7C2D115FAC09DF
                                  mysgw: SGN:BND:HMAC=07FF305FFEB4D1489C3C9BA63A281890DDD850573B406FB691C09C23DC12DD00
                                  mysgw: SGN:BND:SIG WHI,ID=0
                                  mysgw: SGN:BND:SIG WHI,SERIAL=000000000000000000
                                  mysgw: SGN:SGN:SGN
                                  mysgw: TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=27,pt=1,l=1,sg=1,ft=0,st=OK:1
                                  Looks OK for me, right?
                                  AnticimexA 3 Replies Last reply
                                  • t3chieT t3chie
                                    @Anticimex I did:
                                    cd MySensors
                                    Then compile with:
                                    --my-rf24-ce-pin=22
                                    --my-rf24-cs-pin=24
                                    --my-leds-rx-pin=16
                                    --my-leds-tx-pin=18
                                    --my-debug=enable
                                    --my-signing-debug
                                    mysgw: TSF:MSG:BC
                                    mysgw: TSF:CKU:OK
                                    mysgw: !SGN:NCE:GEN
                                    mysgw: !SGN:NCE:GEN
                                    mysgw: !SGN:NCE:GEN
                                    mysgw: !SGN:NCE:GEN
                                    mysgw: !SGN:NCE:GEN
                                    mysgw: SGN:SGN:SGN
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @t3chie I think so. There are a few errors in the log though but I am not sure if that is due to other nodes on your network not being configured properly.
                                    • t3chieT t3chie
                                      @Anticimex I did:
                                      cd MySensors
                                      Then compile with:
                                      --my-rf24-ce-pin=22
                                      --my-rf24-cs-pin=24
                                      --my-leds-rx-pin=16
                                      --my-leds-tx-pin=18
                                      --my-debug=enable
                                      --my-signing-debug
                                      mysgw: TSF:MSG:BC
                                      mysgw: TSF:CKU:OK
                                      mysgw: !SGN:NCE:GEN
                                      mysgw: !SGN:NCE:GEN
                                      mysgw: !SGN:NCE:GEN
                                      mysgw: !SGN:NCE:GEN
                                      mysgw: !SGN:NCE:GEN
                                      mysgw: SGN:SGN:SGN
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @t3chie it also looks like your gw is not always succeeding in generating nonces.
                                      • t3chieT t3chie
                                        @Anticimex I did:
                                        cd MySensors
                                        Then compile with:
                                        --my-rf24-ce-pin=22
                                        --my-rf24-cs-pin=24
                                        --my-leds-rx-pin=16
                                        --my-leds-tx-pin=18
                                        --my-debug=enable
                                        --my-signing-debug
                                        mysgw: TSF:MSG:BC
                                        mysgw: TSF:CKU:OK
                                        mysgw: !SGN:NCE:GEN
                                        mysgw: !SGN:NCE:GEN
                                        mysgw: !SGN:NCE:GEN
                                        mysgw: !SGN:NCE:GEN
                                        mysgw: !SGN:NCE:GEN
                                        mysgw: SGN:SGN:SGN
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        @t3chie could you please include the startup messages from the gateway? Looks like it still does not initialize properly. It should not have a problem generating nonces if it thinks personalization is OK.
                                          t3chieT
                                          t3chieT
                                          t3chie
                                          @Anticimex
                                          mysgw: MCO:BGN:INIT GW,CP=RNNG-SQ-,VER=2.2.0-beta
                                          mysgw: SGN:PER:OK
                                          mysgw: SGN:PER:OK
                                          mysgw: TSF:LRT:OK
                                          mysgw: TSM:INIT
                                          mysgw: TSF:WUR:MS=0
                                          mysgw: MCO:BGN:STP
                                          mysgw: Client 0 connected
                                          mysgw: Client 0: 255;255;3;0;20;
                                          mysgw: SGN:SKP:MSG CMD=3,TYPE=20
                                          mysgw: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                                          mysgw: Client 0: 0;255;3;0;2;
                                          mysgw: TSF:MSG:READ,198-198-0,s=255,c=3,t=21,pt=1,l=1,sg=0:0
                                          mysgw: SGN:SKP:MSG CMD=3,TYPE=21
                                          mysgw: TSF:MSG:BC
                                          mysgw: TSF:CKU:OK
                                          mysgw: !SGN:NCE:GEN
                                          PS:
                                          I am on Skype with the same Nick if you want more synchronous communication.
                                          12.5k
