  2. Bug Reports
  3. Raspberry Gateway 2.1.1 + signing
34 Posts 3 Posters 9.3k Views 4 Watching
  • t3chieT t3chie
    @Anticimex I use:
    ./bin/mysgw --set-soft-hmac-key D94AB9BF54D266CA517C23C870FF7A6...
    ./bin/mysgw --set-soft-serial-key 2200002200...
    How can I calculate the checksum or disable it?
    AnticimexA
    AnticimexA
    Anticimex
    @t3chie just comment https://github.com/mysensors/MySensors/blob/development/core/MySigningAtsha204Soft.cpp#L127
    I'm pretty sure the problem is that on Linux, a checksum is never calculated, so I will patch the init function of the software signing backend to ignore that calculation on Linux.
    I do also note that you seem to get NACKs. I can already now say that those have to go away for signing to work. See here.
    t3chieT 1 Reply Last reply
    • AnticimexA Anticimex
      t3chieT
      t3chieT
      t3chie
      @Anticimex Have tried to comment out line 127, but as you said no joy. I know that the radio I am using is not the best but I am still not sure if the HW is the culprit here.
      I have put that RF24 module onto a Nano with itead RF Shield and loaded a 2.1.1 Gateway Sketch including signing - that works against the same node I am testing the Pi.
      I am using the interrupt variant of the Pi cabling - could that be the problem?
      AnticimexA 1 Reply Last reply
      • t3chieT t3chie
        AnticimexA
        AnticimexA
        Anticimex
        @t3chie if you read the troubleshooting guide which I linked to, the topmost and most common issue is radio problems and these are not signing related. They are because you have a flaky radio connection (reasons could be many, and there are a ton of threads on the forum that discuss these). You see these when you enable signing because then full size messages are transmitted and not the relatively small messages you typically transmit.
          t3chieT
          t3chieT
          t3chie
          @Anticimex Well, I have read all troubleshooting material many times and agree that mostly it is HW. This time however it was stupidity on my side!
          I mixed up signing with encryption on the Pi compile time flags.
          To summarize:
          On 2.1.1, the architecture needs to be set and signing works (have not tested encryption yet).
          On dev, architecture needs to be left alone (not set) and checksum calculation needs to be commented out (line 127 of MySigningAtsha204Soft.cpp).
          • t3chieT t3chie
            To summarize:
            AnticimexA
            AnticimexA
            Anticimex
            @t3chie ah, ok. Yes, those NUS messages indicated that something was really mixed up :)
            I will file a pull request to fix the checksum issue. Thanks for reporting!
            • t3chieT t3chie
              To summarize:
              AnticimexA
              AnticimexA
              Anticimex
              @t3chie Could I ask you a big favour to test my PR on your linux gw and node?
              https://github.com/mysensors/MySensors/pull/885
                t3chieT
                t3chieT
                t3chie
                @Anticimex Sure, can do.
                Would you refresh my memory - how can I check out the tree with that pullrequest?
                • t3chieT t3chie
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @t3chie thanks!
                  git checkout -b fallberg-signing development
                  git pull https://github.com/fallberg/MySensors.git signing
                    @t3chie thanks!
                    t3chieT
                    t3chieT
                    t3chie
                    @Anticimex I did:
                    git clone https://github.com/mysensors/MySensors.git --branch development
                    cd MySensors
                    Then compile with:
                    --my-transport=nrf24
                    --my-rf24-ce-pin=22
                    --my-rf24-cs-pin=24
                    --my-rf24-irq-pin=15
                    --my-rf24-pa-level=RF24_PA_LOW
                    --my-leds-err-pin=12
                    --my-leds-rx-pin=16
                    --my-leds-tx-pin=18
                    --my-rf24-channel=76
                    --my-debug=enable
                    --my-signing=software
                    --my-signing-request-signatures
                    --my-signing-request-gw-signatures-from-all
                    --my-signing-debug
                    Result with one node restarting while others are already running:
                    mysgw: TSF:MSG:READ,100-100-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                    mysgw: TSF:MSG:BC
                    mysgw: TSF:MSG:FPAR REQ,ID=100
                    mysgw: TSF:PNG:SEND,TO=0
                    mysgw: TSF:CKU:OK
                    mysgw: TSF:MSG:GWL OK
                    mysgw: SGN:SKP:MSG CMD=3,TYPE=8
                    mysgw: TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=8,pt=1,l=1,sg=1,ft=0,st=OK:0
                    mysgw: TSF:MSG:READ,100-100-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                    mysgw: SGN:SKP:MSG CMD=3,TYPE=24
                    mysgw: TSF:MSG:PINGED,ID=100,HP=1
                    mysgw: SGN:SKP:MSG CMD=3,TYPE=25
                    mysgw: TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=25,pt=1,l=1,sg=1,ft=0,st=OK:1
                    mysgw: TSF:MSG:READ,100-100-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
                    mysgw: SGN:SKP:MSG CMD=3,TYPE=15
                    mysgw: SGN:PRE:SGN REQ,FROM=100
                    mysgw: !SGN:PRE:WHI NREQ,FROM=100 REJ
                    mysgw: SGN:PRE:SGN REQ,TO=100
                    mysgw: SGN:PRE:WHI NREQ,TO=100
                    mysgw: TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
                    mysgw: SGN:PRE:XMT,TO=100
                    mysgw: TSF:MSG:READ,100-100-0,s=255,c=3,t=16,pt=0,l=0,sg=0:
                    mysgw: SGN:SKP:MSG CMD=3,TYPE=16
                    mysgw: !SGN:NCE:GEN
                    mysgw: !SGN:NCE:GEN
                    mysgw: !SGN:NCE:GEN
                    mysgw: !SGN:NCE:GEN
                    mysgw: TSF:MSG:READ,100-100-0,s=1,c=3,t=16,pt=0,l=0,sg=0:
                    mysgw: !SGN:NCE:GEN
                    mysgw: TSF:MSG:READ,100-100-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                    mysgw: SGN:SKP:MSG CMD=3,TYPE=26
                    mysgw: TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                    mysgw: SGN:SGN:NCE REQ,TO=100
                    mysgw: TSF:MSG:READ,100-100-0,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                    mysgw: SGN:SKP:MSG CMD=3,TYPE=17
                    mysgw: SGN:NCE:FROM=100
                    mysgw: SGN:BND:NONCE=4BD28D2B47813291B354D4A856B07E7A6B496CF86FA2FF969D7C2D115FAC09DF
                    mysgw: SGN:BND:HMAC=07FF305FFEB4D1489C3C9BA63A281890DDD850573B406FB691C09C23DC12DD00
                    mysgw: SGN:BND:SIG WHI,ID=0
                    mysgw: SGN:BND:SIG WHI,SERIAL=000000000000000000
                    mysgw: SGN:SGN:SGN
                    mysgw: TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=27,pt=1,l=1,sg=1,ft=0,st=OK:1
                    Looks OK for me, right?
                    AnticimexA 3 Replies Last reply
                    • t3chieT t3chie
                      @Anticimex I did:
                      cd MySensors
                      Then compile with:
                      --my-rf24-ce-pin=22
                      --my-rf24-cs-pin=24
                      --my-leds-rx-pin=16
                      --my-leds-tx-pin=18
                      --my-debug=enable
                      --my-signing-debug
                      mysgw: TSF:MSG:BC
                      mysgw: TSF:CKU:OK
                      mysgw: !SGN:NCE:GEN
                      mysgw: !SGN:NCE:GEN
                      mysgw: !SGN:NCE:GEN
                      mysgw: !SGN:NCE:GEN
                      mysgw: !SGN:NCE:GEN
                      mysgw: SGN:SGN:SGN
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @t3chie I think so. There are a few errors in the log though but I am not sure if that is due to other nodes on your network not being configured properly.
                      • t3chieT t3chie
                        @Anticimex I did:
                        cd MySensors
                        Then compile with:
                        --my-rf24-ce-pin=22
                        --my-rf24-cs-pin=24
                        --my-leds-rx-pin=16
                        --my-leds-tx-pin=18
                        --my-debug=enable
                        --my-signing-debug
                        mysgw: TSF:MSG:BC
                        mysgw: TSF:CKU:OK
                        mysgw: !SGN:NCE:GEN
                        mysgw: !SGN:NCE:GEN
                        mysgw: !SGN:NCE:GEN
                        mysgw: !SGN:NCE:GEN
                        mysgw: !SGN:NCE:GEN
                        mysgw: SGN:SGN:SGN
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @t3chie it also looks like your gw is not always succeeding in generating nonces.
                        • t3chieT t3chie
                          @Anticimex I did:
                          cd MySensors
                          Then compile with:
                          --my-rf24-ce-pin=22
                          --my-rf24-cs-pin=24
                          --my-leds-rx-pin=16
                          --my-leds-tx-pin=18
                          --my-debug=enable
                          --my-signing-debug
                          mysgw: TSF:MSG:BC
                          mysgw: TSF:CKU:OK
                          mysgw: !SGN:NCE:GEN
                          mysgw: !SGN:NCE:GEN
                          mysgw: !SGN:NCE:GEN
                          mysgw: !SGN:NCE:GEN
                          mysgw: !SGN:NCE:GEN
                          mysgw: SGN:SGN:SGN
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @t3chie could you please include the startup messages from the gateway? Looks like it still does not initialize properly. It should not have a problem generating nonces if it thinks personalization is OK.
                            t3chieT
                            t3chieT
                            t3chie
                            @Anticimex
                            mysgw: Starting gateway...
                            mysgw: MCO:BGN:INIT GW,CP=RNNG-SQ-,VER=2.2.0-beta
                            mysgw: SGN:PER:OK
                            mysgw: SGN:PER:OK
                            mysgw: TSF:LRT:OK
                            mysgw: TSM:INIT
                            mysgw: TSF:WUR:MS=0
                            mysgw: TSM:INIT:TSP OK
                            mysgw: TSM:INIT:GW MODE
                            mysgw: MCO:REG:NOT NEEDED
                            mysgw: MCO:BGN:STP
                            mysgw: MCO:BGN:INIT OK,TSP=1
                            mysgw: Client 0 connected
                            mysgw: Client 0: 255;255;3;0;20;
                            mysgw: SGN:SKP:MSG CMD=3,TYPE=20
                            mysgw: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                            mysgw: Client 0: 0;255;3;0;2;
                            mysgw: TSF:MSG:READ,198-198-0,s=255,c=3,t=21,pt=1,l=1,sg=0:0
                            mysgw: SGN:SKP:MSG CMD=3,TYPE=21
                            mysgw: TSF:MSG:BC
                            mysgw: TSF:CKU:OK
                            mysgw: TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                            mysgw: TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                            mysgw: !SGN:NCE:GEN
                            PS:
                            I am on Skype with the same Nick if you want more synchronous communication.
                            • t3chieT t3chie
                              @Anticimex
                              mysgw: SGN:PER:OK
                              mysgw: SGN:PER:OK
                              mysgw: TSF:LRT:OK
                              mysgw: TSM:INIT
                              mysgw: TSF:WUR:MS=0
                              mysgw: MCO:BGN:STP
                              mysgw: TSF:MSG:BC
                              mysgw: TSF:CKU:OK
                              mysgw: !SGN:NCE:GEN
                              PS:
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @t3chie hm, odd. And you get the validation message twice. I must have messed something up. I'll have a closer look tonight and get back to you. Thanks for helping out!
                              • t3chieT t3chie
                                @Anticimex
                                mysgw: SGN:PER:OK
                                mysgw: SGN:PER:OK
                                mysgw: TSF:LRT:OK
                                mysgw: TSM:INIT
                                mysgw: TSF:WUR:MS=0
                                mysgw: MCO:BGN:STP
                                mysgw: TSF:MSG:BC
                                mysgw: TSF:CKU:OK
                                mysgw: !SGN:NCE:GEN
                                PS:
                                AnticimexA
                                AnticimexA
                                Anticimex
                                #25
                                @t3chie I believe I found the issue on my pr. Sloppy coding is all I can say... I will notify you once I have resolved it. In the meantime you can delete your copy of my branch (I tend to force push to my pull requests).
                                git checkout development
                                git branch -D fallberg-signing
                                • t3chieT t3chie
                                  @Anticimex
                                  mysgw: SGN:PER:OK
                                  mysgw: SGN:PER:OK
                                  mysgw: TSF:LRT:OK
                                  mysgw: TSM:INIT
                                  mysgw: TSF:WUR:MS=0
                                  mysgw: MCO:BGN:STP
                                  mysgw: TSF:MSG:BC
                                  mysgw: TSF:CKU:OK
                                  mysgw: !SGN:NCE:GEN
                                  PS:
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @t3chie I've pushed updates now. It should resolve the problems. I accidentally excluded the part where the backends are initialized, and there are safeguards against that so it refused to calculate nonces for signing. You should now get a "SGN:INI:BND OK" after "SGN:PER:OK"
                                    t3chieT
                                    t3chieT
                                    t3chie
                                    @Anticimex I have checked out the signing branch and recompiled:
                                    root@automation:/usr/local/src/MySensors# ./bin/mysgw -d
                                    mysgw: SGN:PER:OK
                                    mysgw: SGN:INI:BND OK
                                    mysgw: TSF:LRT:OK
                                    mysgw: TSM:INIT
                                    mysgw: TSF:WUR:MS=0
                                    mysgw: MCO:BGN:STP
                                    mysgw: Client 0 disconnected
                                    mysgw: Ethernet client disconnected.
                                    mysgw: TSF:MSG:READ,101-101-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                    mysgw: TSF:MSG:BC
                                    mysgw: TSF:MSG:FPAR REQ,ID=101
                                    mysgw: TSF:CKU:OK
                                    mysgw: TSF:MSG:SEND,0-0-101-101,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    mysgw: TSF:MSG:READ,101-101-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                                    mysgw: TSF:MSG:PINGED,ID=101,HP=1
                                    mysgw: TSF:MSG:SEND,0-0-101-101,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                                    mysgw: TSF:MSG:READ,101-101-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
                                    mysgw: SGN:PRE:SGN REQ,FROM=101
                                    mysgw: SGN:PRE:SGN REQ,TO=101
                                    mysgw: SGN:PRE:WHI NREQ,TO=101
                                    mysgw: TSF:MSG:SEND,0-0-101-101,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
                                    mysgw: SGN:PRE:XMT,TO=101
                                    mysgw: TSF:MSG:READ,101-101-0,s=255,c=3,t=16,pt=0,l=0,sg=0:
                                    mysgw: TSF:MSG:SEND,0-0-101-101,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
                                    mysgw: SGN:NCE:XMT,TO=0
                                    mysgw: TSF:MSG:READ,101-101-0,s=255,c=0,t=17,pt=0,l=5,sg=1:2.1.1
                                    mysgw: SGN:BND:NONCE=BE1E788A73D8B77B73E8222D5A3631E99FC1157CC969C6A324AAAAAAAAAAAAAA
                                    mysgw: SGN:BND:HMAC=A50A32E714615D7559D01B4A71B86D59160FAD437C1A0A57C1D6A51BC4410E66
                                    mysgw: SGN:VER:OK
                                    mysgw: TSF:MSG:READ,101-101-0,s=255,c=3,t=16,pt=0,l=0,sg=1:
                                    mysgw: TSF:MSG:SEND,0-0-101-101,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                                    mysgw: TSF:MSG:READ,101-101-0,s=255,c=3,t=6,pt=1,l=1,sg=1:0
                                    mysgw: SGN:BND:NONCE=83B9D811BA4341EEDD7D28B1D0ED0841305E58110879203AE2AAAAAAAAAAAAAA
                                    mysgw: SGN:BND:HMAC=D48A08AA586888933B2EA56857AE12BB353875C726FC8923CFDBE38C888F5EBB
                                    mysgw: SGN:VER:OK
                                    mysgw: Client 0: 101;255;3;0;6;M
                                    mysgw: TSF:MSG:SEND,0-0-101-101,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
                                    mysgw: SGN:SGN:NCE REQ,TO=101
                                    mysgw: TSF:MSG:READ,101-101-0,s=255,c=3,t=17,pt=6,l=25,sg=0:<NONCE>
                                    mysgw: SGN:NCE:FROM=101
                                    mysgw: SGN:BND:NONCE=41DDA29AC9224192AD697FA3D433003E60DC319EA8A6014B60AAAAAAAAAAAAAA
                                    mysgw: SGN:BND:HMAC=86EAC3CDC63F39CF0F333082CF68A66555468D14BBD4AC3E546F8EE773C580C6
                                    mysgw: SGN:SGN:SGN
                                    mysgw: TSF:MSG:SEND,0-0-101-101,s=255,c=3,t=6,pt=0,l=1,sg=1,ft=0,st=OK:M
                                    mysgw: TSF:MSG:READ,101-101-0,s=255,c=3,t=11,pt=0,l=14,sg=1:Nano Motion FW
                                    mysgw: SGN:BND:NONCE=D3676555B4228F26DC34A6B43947B41439156EA5112DC17370AAAAAAAAAAAAAA
                                    mysgw: SGN:BND:HMAC=EBF256F5C55B9FE8FB5FE9A7FBB22C569D782DB73998661FD66D639049D1E624
                                    mysgw: SGN:VER:OK
                                    mysgw: TSF:MSG:READ,101-101-0,s=255,c=3,t=12,pt=0,l=3,sg=1:1.1
                                    mysgw: SGN:BND:NONCE=08F1450783D33257E28EC8B01E0ECE93A41D2826F3972F99EBAAAAAAAAAAAAAA
                                    mysgw: SGN:BND:HMAC=33B02115FA75F8E708B50E825853E80D3A70D5F804FB7E27242B357CF043F8D1
                                    mysgw: SGN:VER:OK
                                    mysgw: TSF:MSG:READ,101-101-0,s=1,c=3,t=16,pt=0,l=0,sg=1:
                                    mysgw: TSF:MSG:READ,101-101-0,s=1,c=0,t=6,pt=0,l=0,sg=1:
                                    mysgw: SGN:BND:NONCE=BAD7253134C6C7F0C0B79FFBF41914B2E0AB59DFDAB7874678AAAAAAAAAAAAAA
                                    mysgw: SGN:BND:HMAC=5BF1F9D417EB97A3C5E7880F18A839EAA464D21FE6A2F7B2D32A3C3431A7A00B
                                    mysgw: SGN:VER:OK
                                    mysgw: TSF:MSG:READ,101-101-0,s=2,c=3,t=16,pt=0,l=0,sg=1:
                                    mysgw: TSF:MSG:READ,101-101-0,s=2,c=0,t=7,pt=0,l=0,sg=1:
                                    mysgw: SGN:BND:NONCE=70410E6BD4E2E3298F348801747889920E2F5779BC0474A7D2AAAAAAAAAAAAAA
                                    mysgw: SGN:BND:HMAC=8632A9E570D1EEEBF766CC7E25C82CD06EB58F21FC0ED3CECF8FCD8B84473379
                                    mysgw: SGN:VER:OK
                                    mysgw: TSF:MSG:READ,101-101-0,s=4,c=3,t=16,pt=0,l=0,sg=1:
                                    mysgw: TSF:MSG:READ,101-101-0,s=4,c=0,t=1,pt=0,l=0,sg=1:
                                    mysgw: SGN:BND:NONCE=54C9C968967021485E45AA2047EA666C63062BFCFFDBC19423AAAAAAAAAAAAAA
                                    mysgw: SGN:BND:HMAC=1397236B072105342EA4CBBBD555B356C2022B8EB64ABBFA637781F6720483A1
                                    mysgw: SGN:VER:OK
                                    mysgw: TSF:MSG:READ,101-101-0,s=255,c=3,t=26,pt=1,l=1,sg=1:2
                                    mysgw: TSF:MSG:SEND,0-0-101-101,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                                    mysgw: TSF:MSG:READ,101-101-0,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                                    mysgw: SGN:BND:NONCE=D1294AF646074EC7CCD7CD6B02BC4619EF79B0A915648A6A07AAAAAAAAAAAAAA
                                    mysgw: SGN:BND:HMAC=127FCE6A3EF3FB0906A20BF3128A318801C5167F215ABAF4EEC0A595AFD373FB
                                    mysgw: SGN:SGN:SGN
                                    mysgw: TSF:MSG:SEND,0-0-101-101,s=255,c=3,t=27,pt=1,l=1,sg=1,ft=0,st=OK:1
                                    • t3chieT t3chie
                                      mysgw: SGN:PER:OK
                                      mysgw: TSF:LRT:OK
                                      mysgw: TSM:INIT
                                      mysgw: TSF:WUR:MS=0
                                      mysgw: MCO:BGN:STP
                                      mysgw: TSF:MSG:BC
                                      mysgw: TSF:CKU:OK
                                      mysgw: SGN:VER:OK
                                      mysgw: SGN:VER:OK
                                      mysgw: SGN:SGN:SGN
                                      mysgw: SGN:VER:OK
                                      mysgw: SGN:VER:OK
                                      mysgw: SGN:VER:OK
                                      mysgw: SGN:VER:OK
                                      mysgw: SGN:VER:OK
                                      mysgw: SGN:SGN:SGN
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @t3chie looks good to me. I cannot see any errors at least :)
                                        t3chieT
                                        t3chieT
                                        t3chie
                                        @Anticimex Thanks for your help!
                                        • MasMatM
                                          MasMatM
                                          MasMat
                                          Hi guys,
                                          I read this thread because it was the only the search found ("raspberry signing").
                                          I'm building a gw (the plan is raspberry 3, rf24). Since it's in a populated area, I want signing (my other project is remote, so no real worries there).
                                          I'm trying to figure out the configuration part for the Raspberry and some of the options:
                                          -software signing AND rf24 encryption. Two different things, right? I thought I would just use signing if that's adequate.
                                          -does master branch work or must I use dev? What's the difference in everyday use?
                                          -I think pin 7 is usefully located (pro mini) and A5 and A6 less convinient, can I use those for the signing?
                                          Also, is there a guide or a thread for a noob regarding setting this up? If not, should we start a new thread?
                                          Thanks guys. I like the info here.
