  2. Bug Reports
  3. Raspberry Gateway 2.1.1 + signing
34 Posts 3 Posters 9.3k Views 4 Watching
  • t3chieT t3chie
    @Anticimex That is different but still not working. The architecture autodetection works. The signing debug does compile, too. But when I am starting up a node the gateway reports:
    mysgw: Starting gateway...
    mysgw: MCO:BGN:INIT GW,CP=RNNG-SQX,VER=2.2.0-beta
    mysgw: !SGN:PER:TAMPERED
    mysgw: !SGN:INI:BND FAIL
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: TSM:INIT:TSP OK
    mysgw: TSM:INIT:GW MODE
    mysgw: MCO:REG:NOT NEEDED
    mysgw: MCO:BGN:STP
    mysgw: MCO:BGN:INIT OK,TSP=1
    mysgw: TSF:MSG:READ,118-205-14,s=1,c=2,t=118,pt=6,l=0,sg=1:
    mysgw: TSF:MSG:REL MSG
    mysgw: !TSF:RTE:14 UNKNOWN
    mysgw: SGN:SGN:118!=0 NUS
    mysgw: !TSF:MSG:SEND,118-0-14-14,s=1,c=2,t=118,pt=6,l=0,sg=1,ft=0,st=NACK:
    mysgw: TSF:MSG:READ,138-29-188,s=181,c=6,t=66,pt=5,l=16,sg=0:3636023473
    mysgw: !TSF:RTE:188 UNKNOWN
    mysgw: SGN:SGN:138!=0 NUS
    mysgw: !TSF:MSG:SEND,138-0-188-188,s=181,c=6,t=66,pt=5,l=16,sg=0,ft=0,st=NACK:3636023473
    mysgw: TSF:MSG:READ,184-237-134,s=214,c=0,t=229,pt=6,l=13,sg=1:5A403EDF050D2265DF00000000
    mysgw: !TSF:MSG:PVER,3=2
    mysgw: TSF:MSG:READ,233-187-65,s=93,c=1,t=52,pt=1,l=1,sg=1:222
    mysgw: !TSF:MSG:PVER,1=2
    mysgw: TSF:MSG:READ,177-160-211,s=159,c=6,t=135,pt=4,l=11,sg=1:-2047481336
    mysgw: !TSF:MSG:PVER,0=2
    mysgw: TSF:MSG:READ,166-111-53,s=187,c=3,t=196,pt=5,l=9,sg=0:204581490
    mysgw: !TSF:RTE:53 UNKNOWN
    mysgw: SGN:SGN:166!=0 NUS
    mysgw: !TSF:MSG:SEND,166-0-53-53,s=187,c=3,t=196,pt=5,l=9,sg=0,ft=0,st=NACK:204581490
    The only node on that radio channel is ID 100 and if I disable signing, the same setup is reporting:
    mysgw: MCO:BGN:INIT GW,CP=RNNG--Q-,VER=2.2.0-beta
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: MCO:BGN:STP
    mysgw: TSF:MSG:READ,100-100-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:FPAR REQ,ID=100
    mysgw: TSF:CKU:OK,FCTRL
    mysgw: TSF:MSG:GWL OK
    mysgw: TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    mysgw: TSF:MSG:READ,100-100-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    mysgw: TSF:MSG:PINGED,ID=100,HP=1
    mysgw: TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
    mysgw: TSF:MSG:READ,100-100-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
    mysgw: TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    mysgw: TSF:MSG:READ,100-100-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.1.1
    mysgw: TSF:MSG:READ,100-100-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
    mysgw: TSF:MSG:READ,100-100-0,s=255,c=3,t=11,pt=0,l=13,sg=0:Motion Sensor
    mysgw: TSF:MSG:READ,100-100-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
    mysgw: TSF:MSG:READ,100-100-0,s=1,c=0,t=1,pt=0,l=0,sg=0:
    mysgw: TSF:MSG:READ,100-100-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
    mysgw: TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
    AnticimexA
    AnticimexA
    Anticimex
    @t3chie looks like the personalization has not finished successfully. How do you store the hmac key to the rPi? If you don't use the personalizer sketch you either need to write the checksum yourself or disable the checksum validation. It could be that the method for personalizing on rPi does not calculate and store a checksum. So either that has to change, or the checksum check should be disabled on rPi/Linux.
    t3chieT 1 Reply Last reply
    • AnticimexA Anticimex
      t3chieT
      t3chieT
      t3chie
      @Anticimex Sorry for that - when I changed Pi's I forgot to personalize the GW. But that didn't made it working:
      mysgw: TSF:LRT:OK
      mysgw: TSM:INIT
      mysgw: TSF:WUR:MS=0
      mysgw: MCO:BGN:STP
      mysgw: TSF:MSG:READ,223-72-13,s=199,c=4,t=110,pt=5,l=4,sg=0:3736138177
      mysgw: TSF:MSG:READ,151-70-68,s=120,c=3,t=166,pt=0,l=15,sg=1:?rQ?0??
      Isn't the Node ID reported changing between random values although it should only see ID 100 ?
      AnticimexA 1 Reply Last reply
      • t3chieT t3chie
        mysgw: TSF:LRT:OK
        mysgw: TSM:INIT
        mysgw: TSF:WUR:MS=0
        mysgw: MCO:BGN:STP
        AnticimexA
        AnticimexA
        Anticimex
        @t3chie it still reports !SGN:PER:TAMPERED so my original question(s) are still valid :)
          t3chieT
          t3chieT
          t3chie
          @Anticimex I use:
          ./bin/mysgw --set-soft-hmac-key D94AB9BF54D266CA517C23C870FF7A6...
          ./bin/mysgw --set-soft-serial-key 2200002200...
          How can I calculate the checksum or disable it?
          • t3chieT t3chie
            @Anticimex I use:
            AnticimexA
            AnticimexA
            Anticimex
            @t3chie just comment https://github.com/mysensors/MySensors/blob/development/core/MySigningAtsha204Soft.cpp#L127
            I'm pretty sure the problem is that on Linux, a checksum is never calculated, so I will patch the init function of the software signing backend to ignore that calculation on Linux.
            I do also note that you seem to get NACKs. I can already now say that those have to go away for signing to work. See here.
              t3chieT
              t3chieT
              t3chie
              @Anticimex Have tried to comment out line 127, but as you said no joy. I know that the radio I am using is not the best but I am still not sure if the HW is the culprit here.
              I have put that RF24 module onto a Nano with itead RF Shield and loaded a 2.1.1 Gateway Sketch including signing - that works against the same node I am testing the Pi.
              I am using the interrupt variant of the Pi cabling - could that be the problem?
              • t3chieT t3chie
                AnticimexA
                AnticimexA
                Anticimex
                @t3chie if you read the troubleshooting guide which I linked to, the topmost and most common issue is radio problems and these are not signing related. They are because you have a flaky radio connection (reasons could be many, and there are a ton of threads on the forum that discuss these). You see these when you enable signing because then full size messages are transmitted and not the relatively small messages you typically transmit.
                  t3chieT
                  t3chieT
                  t3chie
                  @Anticimex Well, I have read all troubleshooting material many times and agree that mostly it is HW. This time however it was stupidity on my side!
                  I mixed up signing with encryption on the Pi compile time flags.
                  To summarize:
                  On 2.1.1, the architecture needs to be set and signing works (have not tested encryption yet).
                  On dev, architecture needs to be left alone (not set) and checksum calculation needs to be commented out (line 127 of MySigningAtsha204Soft.cpp).
                  • t3chieT t3chie
                    To summarize:
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @t3chie ah, ok. Yes, those NUS messages indicated that something was really mixed up :)
                    I will file a pull request to fix the checksum issue. Thanks for reporting!
                    • t3chieT t3chie
                      To summarize:
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @t3chie Could I ask you a big favour to test my PR on your linux gw and node?
                      https://github.com/mysensors/MySensors/pull/885
                        t3chieT
                        t3chieT
                        t3chie
                        @Anticimex Sure, can do.
                        Would you refresh my memory - how can I check out the tree with that pullrequest?
                        • t3chieT t3chie
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @t3chie thanks!
                          git checkout -b fallberg-signing development
                          git pull https://github.com/fallberg/MySensors.git signing
                            @t3chie thanks!
                            t3chieT
                            t3chieT
                            t3chie
                            @Anticimex I did:
                            git clone https://github.com/mysensors/MySensors.git --branch development
                            cd MySensors
                            Then compile with:
                            --my-transport=nrf24
                            --my-rf24-ce-pin=22
                            --my-rf24-cs-pin=24
                            --my-rf24-irq-pin=15
                            --my-rf24-pa-level=RF24_PA_LOW
                            --my-leds-err-pin=12
                            --my-leds-rx-pin=16
                            --my-leds-tx-pin=18
                            --my-rf24-channel=76
                            --my-debug=enable
                            --my-signing=software
                            --my-signing-request-signatures
                            --my-signing-request-gw-signatures-from-all
                            --my-signing-debug
                            Result with one node restarting while others are already running:
                            mysgw: TSF:MSG:BC
                            mysgw: TSF:PNG:SEND,TO=0
                            mysgw: TSF:CKU:OK
                            mysgw: SGN:SKP:MSG CMD=3,TYPE=8
                            mysgw: TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=8,pt=1,l=1,sg=1,ft=0,st=OK:0
                            mysgw: SGN:SKP:MSG CMD=3,TYPE=24
                            mysgw: SGN:SKP:MSG CMD=3,TYPE=25
                            mysgw: TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=25,pt=1,l=1,sg=1,ft=0,st=OK:1
                            mysgw: SGN:SKP:MSG CMD=3,TYPE=15
                            mysgw: SGN:PRE:SGN REQ,FROM=100
                            mysgw: !SGN:PRE:WHI NREQ,FROM=100 REJ
                            mysgw: SGN:PRE:SGN REQ,TO=100
                            mysgw: SGN:PRE:WHI NREQ,TO=100
                            mysgw: TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
                            mysgw: SGN:PRE:XMT,TO=100
                            mysgw: TSF:MSG:READ,100-100-0,s=255,c=3,t=16,pt=0,l=0,sg=0:
                            mysgw: SGN:SKP:MSG CMD=3,TYPE=16
                            mysgw: !SGN:NCE:GEN
                            mysgw: !SGN:NCE:GEN
                            mysgw: !SGN:NCE:GEN
                            mysgw: !SGN:NCE:GEN
                            mysgw: TSF:MSG:READ,100-100-0,s=1,c=3,t=16,pt=0,l=0,sg=0:
                            mysgw: !SGN:NCE:GEN
                            mysgw: SGN:SKP:MSG CMD=3,TYPE=26
                            mysgw: TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                            mysgw: SGN:SGN:NCE REQ,TO=100
                            mysgw: TSF:MSG:READ,100-100-0,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                            mysgw: SGN:SKP:MSG CMD=3,TYPE=17
                            mysgw: SGN:NCE:FROM=100
                            mysgw: SGN:BND:NONCE=4BD28D2B47813291B354D4A856B07E7A6B496CF86FA2FF969D7C2D115FAC09DF
                            mysgw: SGN:BND:HMAC=07FF305FFEB4D1489C3C9BA63A281890DDD850573B406FB691C09C23DC12DD00
                            mysgw: SGN:BND:SIG WHI,ID=0
                            mysgw: SGN:BND:SIG WHI,SERIAL=000000000000000000
                            mysgw: SGN:SGN:SGN
                            mysgw: TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=27,pt=1,l=1,sg=1,ft=0,st=OK:1
                            Looks OK for me, right?
                            AnticimexA 3 Replies Last reply
                            • t3chieT t3chie
                              @Anticimex I did:
                              cd MySensors
                              Then compile with:
                              --my-rf24-ce-pin=22
                              --my-rf24-cs-pin=24
                              --my-leds-rx-pin=16
                              --my-leds-tx-pin=18
                              --my-debug=enable
                              --my-signing-debug
                              mysgw: TSF:MSG:BC
                              mysgw: TSF:CKU:OK
                              mysgw: !SGN:NCE:GEN
                              mysgw: !SGN:NCE:GEN
                              mysgw: !SGN:NCE:GEN
                              mysgw: !SGN:NCE:GEN
                              mysgw: !SGN:NCE:GEN
                              mysgw: SGN:SGN:SGN
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @t3chie I think so. There are a few errors in the log though but I am not sure if that is due to other nodes on your network not being configured properly.
                              • t3chieT t3chie
                                @Anticimex I did:
                                cd MySensors
                                Then compile with:
                                --my-rf24-ce-pin=22
                                --my-rf24-cs-pin=24
                                --my-leds-rx-pin=16
                                --my-leds-tx-pin=18
                                --my-debug=enable
                                --my-signing-debug
                                mysgw: TSF:MSG:BC
                                mysgw: TSF:CKU:OK
                                mysgw: !SGN:NCE:GEN
                                mysgw: !SGN:NCE:GEN
                                mysgw: !SGN:NCE:GEN
                                mysgw: !SGN:NCE:GEN
                                mysgw: !SGN:NCE:GEN
                                mysgw: SGN:SGN:SGN
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @t3chie it also looks like your gw is not always succeeding in generating nonces.
                                • t3chieT t3chie
                                  @Anticimex I did:
                                  cd MySensors
                                  Then compile with:
                                  --my-rf24-ce-pin=22
                                  --my-rf24-cs-pin=24
                                  --my-leds-rx-pin=16
                                  --my-leds-tx-pin=18
                                  --my-debug=enable
                                  --my-signing-debug
                                  mysgw: TSF:MSG:BC
                                  mysgw: TSF:CKU:OK
                                  mysgw: !SGN:NCE:GEN
                                  mysgw: !SGN:NCE:GEN
                                  mysgw: !SGN:NCE:GEN
                                  mysgw: !SGN:NCE:GEN
                                  mysgw: !SGN:NCE:GEN
                                  mysgw: SGN:SGN:SGN
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @t3chie could you please include the startup messages from the gateway? Looks like it still does not initialize properly. It should not have a problem generating nonces if it thinks personalization is OK.
                                    t3chieT
                                    t3chieT
                                    t3chie
                                    @Anticimex
                                    mysgw: MCO:BGN:INIT GW,CP=RNNG-SQ-,VER=2.2.0-beta
                                    mysgw: SGN:PER:OK
                                    mysgw: SGN:PER:OK
                                    mysgw: TSF:LRT:OK
                                    mysgw: TSM:INIT
                                    mysgw: TSF:WUR:MS=0
                                    mysgw: MCO:BGN:STP
                                    mysgw: Client 0 connected
                                    mysgw: Client 0: 255;255;3;0;20;
                                    mysgw: SGN:SKP:MSG CMD=3,TYPE=20
                                    mysgw: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                                    mysgw: Client 0: 0;255;3;0;2;
                                    mysgw: TSF:MSG:READ,198-198-0,s=255,c=3,t=21,pt=1,l=1,sg=0:0
                                    mysgw: SGN:SKP:MSG CMD=3,TYPE=21
                                    mysgw: TSF:MSG:BC
                                    mysgw: TSF:CKU:OK
                                    mysgw: !SGN:NCE:GEN
                                    PS:
                                    I am on Skype with the same Nick if you want more synchronous communication.
                                    • t3chieT t3chie
                                      @Anticimex
                                      mysgw: SGN:PER:OK
                                      mysgw: SGN:PER:OK
                                      mysgw: TSF:LRT:OK
                                      mysgw: TSM:INIT
                                      mysgw: TSF:WUR:MS=0
                                      mysgw: MCO:BGN:STP
                                      mysgw: TSF:MSG:BC
                                      mysgw: TSF:CKU:OK
                                      mysgw: !SGN:NCE:GEN
                                      PS:
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @t3chie hm, odd. And you get the validation message twice. I must have messed something up. I'll have a closer look tonight and get back to you. Thanks for helping out!
                                      • t3chieT t3chie
                                        @Anticimex
                                        mysgw: SGN:PER:OK
                                        mysgw: SGN:PER:OK
                                        mysgw: TSF:LRT:OK
                                        mysgw: TSM:INIT
                                        mysgw: TSF:WUR:MS=0
                                        mysgw: MCO:BGN:STP
                                        mysgw: TSF:MSG:BC
                                        mysgw: TSF:CKU:OK
                                        mysgw: !SGN:NCE:GEN
                                        PS:
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        #25
                                        @t3chie I believe I found the issue on my pr. Sloppy coding is all I can say... I will notify you once I have resolved it. In the meantime you can delete your copy of my branch (I tend to force push to my pull requests).
                                        git checkout development
                                        git branch -D fallberg-signing
                                        • t3chieT t3chie
                                          @Anticimex
                                          mysgw: SGN:PER:OK
                                          mysgw: SGN:PER:OK
                                          mysgw: TSF:LRT:OK
                                          mysgw: TSM:INIT
                                          mysgw: TSF:WUR:MS=0
                                          mysgw: MCO:BGN:STP
                                          mysgw: TSF:MSG:BC
                                          mysgw: TSF:CKU:OK
                                          mysgw: !SGN:NCE:GEN
                                          PS:
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          @t3chie I've pushed updates now. It should resolve the problems. I accidentally excluded the part where the backends are initialized, and there are safeguards against that so it refused to calculate nonces for signing. You should now get a "SGN:INI:BND OK" after "SGN:PER:OK"
