  3. Momentary button to control lights
29 Posts 6 Posters 9.4k Views 7 Watching
  • MasMatM Offline
    MasMatM Offline
    MasMat
    I have wrestled with this one a lot already.
    The idea: one battery powered node, with one push button (momentary).
    I want it to toggle the lights (controled by another node). Also I want the node to report battery status only when the button is pressed, otherwise sleep.
    I can't find what's wrong with my code. The node will not sleep, nor will it send messages when button is pressed. It will however check battery status on constant loop.
    Here's my code.
    If there's an easier way, I would GLADLY hear it.
    #define MY_NODE_ID 7
    //unsigned long SLEEP_TIME = 900000;  // sleep time between reads (seconds * 1000 milliseconds)
    int oldBatteryPcnt = 0;
    #define CHILD_ID_BUTTON1 3
    //#define SECONDARY_CHILD_ID 4
    #define BUTTON_PIN 2   // Arduino Digital I/O pin for button/reed switch
    //#define SECONDARY_BUTTON_PIN 3 // Arduino Digital I/O pin for button/reed switch
    MyMessage msg(CHILD_ID_BUTTON1, V_TRIPPED);
    //MyMessage msg2(SECONDARY_CHILD_ID, V_TRIPPED);
    	// Setup the buttons
    	pinMode(BUTTON_PIN, INPUT);
    	//pinMode(SECONDARY_BUTTON_PIN, INPUT);
    	// Activate internal pull-ups
    	digitalWrite(BUTTON_PIN, HIGH);
    	//digitalWrite(SECONDARY_BUTTON_PIN, HIGH);
      analogReference(INTERNAL1V1);
      #else
      analogReference(INTERNAL);
      sendSketchInfo("WCNappiBAT", "vMasi020717");
    	// Register binary input sensor to sensor_node (they will be created as child devices)
    	present(CHILD_ID_BUTTON1, S_DOOR);
    	//present(SECONDARY_CHILD_ID, S_DOOR);
    	uint8_t value;
    	static uint8_t sentValue=2;
      int NumberPushes = 0;
    	//static uint8_t sentValue2=2;
    	delay(20);
    	value = digitalRead(BUTTON_PIN);
    	if (value != sentValue) {
    		// Value has changed from last transmission, send the updated value
        NumberPushes++;
        Serial.println("Button counter:  ");
        Serial.print(NumberPushes);
        if (NumberPushes % 4 == 0) {
        send(msg.set(value==HIGH));
        Serial.println("Sent Button ON");
    		sentValue = value;
      // get the battery Voltage
    #ifdef MY_DEBUG
      Serial.println(sensorValue);
    #ifdef MY_DEBUG
      float batteryV  = sensorValue * 0.003363075;
      Serial.print(batteryV);
      Serial.println(" V");
      Serial.print(batteryPcnt);
      Serial.println(" %");
      //if (oldBatteryPcnt != batteryPcnt) {
        // Power up radio after sleep
        //oldBatteryPcnt = batteryPcnt;
    	// Sleep until something happens with the sensor
    	sleep(BUTTON_PIN-2, CHANGE, 0);
    • T Offline
      T Offline
      Topdawg2881
      To start off with I would place the button on an interrupt pin and add an interrupt into the sketch. This way the interrupt can trigger the read of the battery voltage sense and also send that information along with the button change status.
      MasMatM 1 Reply Last reply
      • T Topdawg2881
        MasMatM Offline
        MasMatM Offline
        MasMat
        @Topdawg2881 The button is on pin2 (=interrupt 0).
        I have a motion sensor that doesn't require this, but I will add
        #define INTERRUPT BUTTON_PIN-2
        Is that enough?
        • T Offline
          T Offline
          Topdawg2881
          Someone better than me may be able to help further, but another thing you define NumberPushes as equal to 0 in the loop function. Every time the loop runs through it will set it equal to 0. I would define the integer as equal to 0 in the setup or prior to the setup so that your NumberPushes ++ function will actually count correctly.
          Also what does your debug info look like? If I remember correctly if you do not connect to the gateway the loop will not run correctly.
          • T Topdawg2881
            MasMatM Offline
            MasMatM Offline
            MasMat
            @Topdawg2881 Great point! Thanks for lending your eyes.
            Moving the numberPushes out of 'loop'. I'll see what it does. I'm also working to simplify the way the presses toggle between sending on-off.
            • MasMatM Offline
              MasMatM Offline
              MasMat
              Tried moving the numberPushes. Not working. I decided to tackle the "toggle problem" another way. Still no joy.
              Anyone have time to check my writing, much appreciated. Also if someone has code that works to make a momentary switch work like a toggle, that would be greatly appreciated.
              int tripped = 1;
              int lastStatus = 1;
              int numberPushes = 0;
              int light1 = LOW;      // the current state of the output pin
              int reading;           // the current reading from the input pin
              int previous = HIGH;    // the previous reading from the input pin
              // the follow variables are long's because the time, measured in miliseconds,
              // will quickly become a bigger number than can be stored in an int.
              long time = 0;         // the last time the output pin was toggled
              long debounce = 400;   // the debounce time, increase if the output flickers
              long batteryinterval = 10000;
                #else
                sendSketchInfo("WCNappiBAT", "vMasi030717");
              // Another approach
              reading = digitalRead(BUTTON_PIN);
                // if the input just went from LOW and HIGH and we've waited long enough
                // to ignore any noise on the circuit, toggle the output pin and remember
                // the time
                if (reading == HIGH && previous == LOW && millis() - time > debounce) {
                  if (light1 == LOW)
                    light1 = HIGH && send(msg.set("1"));
                    //Serial.println("Switching on");
                  else
                    light1 = LOW && send(msg.set("0"));
              Serial.println("Switch toggling");
              delay (100);
                previous = reading;
              // if (millis() - time > batteryinterval) {
              #ifdef MY_DEBUG
              #ifdef MY_DEBUG
                    time = millis();
              	sleep(BUTTON_PIN-2, FALLING, 0);
              Boots33B 1 Reply Last reply
                Why do you use button_pin and button_pin-2?
                  @gohan BUTTON_PIN-2 was used in some early MySensors examples instead of digitalPinToInterrupt(BUTTON_PIN). Very ugly and we have gotten rid of it in the current examples but early users could still have sketches with that code.
                  • MasMatM MasMat
                    int tripped = 1;
                    int lastStatus = 1;
                      #else
                    // Another approach
                      // the time
                        if (light1 == LOW)
                        else
                    delay (100);
                      previous = reading;
                    #ifdef MY_DEBUG
                    #ifdef MY_DEBUG
                          time = millis();
                    Boots33B Offline
                    Boots33B Offline
                    Boots33
                    @MasMat Your remote switch node can never be sure if the light on the slave node is on or off (it may have been changed by the controller)
                    To toggle a light from a remote I have found it easiest to place the toggle code in the node that controls the light not in the remote switch. You can then just send a node to node message from your remote to trigger the toggle.
                    You could also use a node to node request to get the current state of the light but I think you will find it simpler using the first method.
                    Without seeing your light controller node sketch it is hard to be specific but a very simple sketch could be like bellow.
                    You can see all the work is done in the receive function.
                    If the message is from your controller (through the gateway node 0) it will just set the light to the arriving state.
                    If the message is from your remote (node 7) then it will toggle the light state.
                    /* This sketch is to control a light and also
                     *  allow control from a remote switch
                    #define LIGHT_PIN  6             // Arduino Digital  pin connected to mosfet or relay that controls light
                    #define LIGHT_ON 1                 // Output value to write to turn on attached mosfet
                    #define LIGHT_OFF 0                // Output value to write to turn off attached mosfet
                    #define CHILD_ID_LIGHT 1
                    bool state = 0;                        // State holder for light
                    MyMessage msg(CHILD_ID_LIGHT, V_STATUS);
                      pinMode(LIGHT_PIN, OUTPUT);            //set light pin as output
                      digitalWrite(LIGHT_PIN, LIGHT_OFF);    //   make sure light is off at startup
                    void presentation()  {
                      sendSketchInfo("Light controller", "1.0");
                      present(CHILD_ID_LIGHT, S_BINARY, "House Light");
                    /*-------------------------start of functions-------------------*/
                    if (message.type == V_STATUS) {                                  // check that message is for binary switch
                      if (message.sender == 0) {                                     // check if message is from gateway (node 0)
                           state = message.getBool();
                           digitalWrite(LIGHT_PIN, state ? LIGHT_ON : LIGHT_OFF); // Set Light A to the new state
                      else if (message.sender == 7) {                                  // message is from  remote (node 7)
                            state = !state;                                         // toggle light state
                            send(msg.set(state), false);                            //Message the gateway so controller will be aware of the change. No ack
                        /*-------Write some debug info-----*/
                    #ifdef MY_DEBUG
                        Serial.print(message.sensor);
                        Serial.print(" from node: ");
                        Serial.println(message.sender);
                    • Boots33B Boots33
                      #ifdef MY_DEBUG
                      MasMatM Offline
                      MasMatM Offline
                      MasMat
                      wrote on last edited by MasMat
                      @Boots33 Will try that.
                      My idea was to "let the switch be dumb" sending alternating 1 or 0. People tend to push on buttons until something happens :)
                      Also I'm using this sketch as a run-up to building a two button remote.
                      I can easily access the code the receiving node and have the remote node "just send 1or0" every time it's pushed?
                      It will need more code if I have two buttons.
                      PS where can I find the docs for "message.sender & message.destination" options?
                      mfalkviddM Boots33B 2 Replies Last reply
                      • MasMatM MasMat
                        @MasMat I'm not sure if there is a more user-friendy documentation somewhere, but the source code has some information: https://github.com/mysensors/MySensors/blob/ff0953dd05b4f5e52e7d2c39ad23d207c896ea5e/core/MyMessage.h#L345
                        • MasMatM MasMat
                          Boots33B Offline
                          Boots33B Offline
                          Boots33
                          wrote on last edited by Boots33
                          @MasMat said in Momentary button to control lights:
                          Yes that is the best way. But it doesn't really need to change from 1 or 0 it can just send the same thing all the time.
                          I can easily access the code the receiving node and have the remote node "just >send 1or0" every time it's pushed?
                          In the receive function of my sketch you can see that it will toggle on any message from node 7.
                          So it does not matter whether you send a 1 or 0 it will still toggle. This will make your switch code simpler, it does not need to know what the current state is it can for example just send a 1 every time the button is pushed and the light will toggle.
                          Multiple buttons will be fine. you will just need to use message.sensor in the receive function to test for which child sensor the message is for.
                          PS where can I find the docs for "message.sender & message.destination" >options?
                          The core files as linked to by @mfalkvidd are the place to look.
                          I used most of what you will need in previous posts and projects, have a read thru these.
                          LCD Node - display temp from other sensor - How?
                          Synchronising Light switch
                          Outdoors Touch Switch light controller
                          Display node: how to set up
                          AC Power controller with node to node remotes
                          • Boots33B Boots33
                            MasMatM Offline
                            MasMatM Offline
                            MasMat
                            @Boots33 I checked out your links. I love the outdoor touch controller!! That's awesome!
                            I'm trying to figure out the "switch"-function, but Mysensors-docs nor Google cant find much.
                            I'm trying to figure out how switch=>case works. I could use that to further my one (and two or more!) button remote. Where I get lost is why "case 4" is completely different from the other three?
                            Any advice?
                            • MasMatM MasMat
                              Any advice?
                              Boots33B Offline
                              Boots33B Offline
                              Boots33
                              the switch/case is a standard arduino function. It can be very useful and sometimes much neater than using multiple if then else statements.
                              Yes it is well suited to that task.
                              Any advice?
                              Is it this you are referring to
                              case 4:
                                       groupState = !groupState ;                   //Toggle the state
                                       send(msg.set(groupState), false);     // send new state to controller, no ack requested
                                       tone(buzzerPin, 1200, 60);                  //Play short beep to acknowledge touch
                                       break;
                              The first three case statements are sending direct node to node messages which are handled by the receiving node. The case 4 code is simply sending a standard binary switch message to my controller (Domoticz) and toggles the state of the switch in domoticz. I have that one switch set up as a group control switch in Domoticz so it turns on/off several light nodes at the same time. Sort of like a master control switch.
                              As i indicated in that original post the sketch was still in it's early testing stages. While I still have not completely finished the project yet it has been out in the garden for some months and has shown no false triggers from either rain or even birds landing on the touch pad.
                              Hope that helps. feel free to ask if you require any more info. MySensors node to node messages are really quite flexible once you get the hang of them. :)
                              • MasMatM Offline
                                MasMatM Offline
                                MasMat
                                All right. Been banging my head at this all day again.
                                I seem to be sending the message from the node OK, but the receiving node appears to have intermittent problems. And for some reason, my gateway reboots at some "combinations".
                                I have gone thru the send-node & receive-node code tens of times.
                                Help & ideas appreciated. Plz excuse the finnish in the code :)
                                Send-node
                                //destination specs
                                #define WC_SENSOR_ID 3
                                #define WC_NODE_ID 3
                                #define BUTTON_PIN 2   //pin for button
                                //#define INTERRUPT BUTTON_PIN
                                MyMessage msg(CHILD_ID_BUTTON1, V_STATUS);
                                int tripped = 1;
                                int lastStatus = 1;
                                int sentCounter = 0;
                                  #else
                                  sendSketchInfo("WCNappiBAT", "v290717");
                                	present(CHILD_ID_BUTTON1, S_BINARY);
                                  if (reading == LOW && previous == HIGH) {
                                    send(MyMessage(CHILD_ID_BUTTON1, V_STATUS).setSensor(WC_SENSOR_ID).setDestination(WC_NODE_ID).set(true));
                                    Serial.println("Toggling..");
                                    sentCounter++;
                                previous = reading;
                                if (sentCounter % 10 == 0) {
                                  delay (200);
                                And the receiving end.
                                In the code is preparations for my second "remote"
                                #define MY_NODE_ID 3
                                //#define MY_REPEATER_FEATURE
                                #define NUMBER_OF_RELAYS 6 // Total number of attached relays
                                #define RELAY_ON 0  // GPIO value to write to turn on attached relay
                                #define RELAY_OFF 1 // GPIO value to write to turn off attached relay
                                #define RELAY_7 14   //pin A0
                                #define RELAY_8 15   //pin A1
                                bool stateWC = 0;
                                bool stateKei = 0;
                                bool stateRuo = 0;
                                void before()
                                		pinMode(pin, OUTPUT);
                                 pinMode(RELAY_7, OUTPUT);
                                 digitalWrite(RELAY_7, loadState(7)?RELAY_ON:RELAY_OFF);
                                 pinMode(RELAY_8, OUTPUT);
                                 digitalWrite(RELAY_8, loadState(8)?RELAY_ON:RELAY_OFF);
                                MyMessage msgWC(3, V_STATUS);
                                MyMessage msgKei(1, V_STATUS);
                                MyMessage msgRuo(2, V_STATUS);
                                	sendSketchInfo("TeknRele8x", "v29072017");
                                		present(sensor, S_BINARY);
                                 present(7, S_BINARY);
                                 present(8, S_BINARY);
                                	if (message.type==V_STATUS) {                             	// Change relay state
                                   if (message.sensor == 7) {
                                   digitalWrite(RELAY_7, message.getBool()?RELAY_ON:RELAY_OFF);    //Write to A0
                                   // Store state in eeprom
                                   if (message.sensor == 8) {
                                    digitalWrite(RELAY_8, message.getBool()?RELAY_ON:RELAY_OFF);   //Write to A1
                                   if (message.sender == 7) {                      //Message from WC remote
                                   stateWC = !stateWC;                             // toggle light state
                                   digitalWrite(5, stateWC?RELAY_ON:RELAY_OFF);    // 5 is RELAY_3 pin
                                    saveState(message.sensor, stateWC);
                                    send(msgWC.set(stateWC), false);             //Msg gateway aware of the change. No ack
                                   if (message.sender == 8) {
                                    switch (message.sensor) {
                                      case 1:                                     //message for kitchen
                                        stateKei = !stateKei;
                                        digitalWrite(message.sensor, stateKei?RELAY_ON:RELAY_OFF);
                                        saveState(message.sensor, stateKei);
                                        send(msgKei.set(stateKei), false);             //Msg gateway aware of the change. No ack
                                        break;
                                      case 2:                                    //message for dining table
                                        stateRuo = !stateRuo;
                                        digitalWrite(message.sensor, stateRuo?RELAY_ON:RELAY_OFF);
                                        saveState(message.sensor, stateRuo);
                                        send(msgRuo.set(stateRuo), false);             //Msg gateway aware of the change. No ack
                                        break;
                                		// Write some debug info
                                To add, I would say there's nothing special in either serial output. I can elborate if nothing else appears.
                                Thanks everybody!
                                • MasMatM MasMat
                                  Send-node
                                  //destination specs
                                  int tripped = 1;
                                  int lastStatus = 1;
                                    #else
                                      sentCounter++;
                                  previous = reading;
                                    delay (200);
                                  bool stateWC = 0;
                                  bool stateKei = 0;
                                  bool stateRuo = 0;
                                  void before()
                                          break;
                                          break;
                                  Thanks everybody!
                                  Boots33B Offline
                                  Boots33B Offline
                                  Boots33
                                  Yes your send message should be ok. You are sending a V_STATUS message from node 7 sensor 3 to node 3 sensor 3
                                  Not sure what could be causing that but you will need to sort that out to get stability. I have not experienced any issues with my gateway using node to node.
                                  You will need to add code to separate the incoming messages from your controller and remotes as they will need to be treated differently. Messages from your controller will have the gateway (node 0) as the sender so this can be used.
                                  You have a lot going on in your receive function so maybe just put the code for the one node you are trying at the moment so it is easier to troubleshoot.
                                  Try something like this
                                          case 3:                                                      //incoming message is for WC relay (sensor 3)
                                            stateWC = message.getBool();                               // get the new state
                                            digitalWrite(5, stateWC ? RELAY_ON : RELAY_OFF);           // 5 is RELAY_3 pin
                                            saveState(message.sensor, stateWC);                        // save sensor state
                                            break;
                                          /*-----Add case statements for other realys as needed ----*/
                                    else  {                                                           // message is not from gateway so must be from a remote
                                      switch (message.sender) {
                                          case 7:                                                     //incoming message is from WC remote (node 7)
                                            saveState(message.sensor, stateWC);                       // Store state in eeprom
                                            break;
                                          /*-----Add case statements for other remote nodes as needed ----*/
                                      #ifdef MY_DEBUG
                                      Serial.println(message.sensor);
                                      Serial.print("from node:");
                                      Serial.print(" New status: ");
                                  MasMatM 3 Replies Last reply
                                  • Boots33B Boots33
                                              break;
                                              break;
                                        #ifdef MY_DEBUG
                                    MasMatM Offline
                                    MasMatM Offline
                                    MasMat
                                    @Boots33 That looks really clean. And you're right I have to comment out the stuff that's pre-prepared.
                                    The node is installed in a really tricky place and reprogramming is difficult (hence trying to solve everything beforehand). One day I'll learn to build & test first, install second...
                                    This morning I tested the setup again, with old settings and noticed the correct relay "fires" but doesnt really toggle. If I switch it off, it will come on but stay on regardless of presses. So the right node is receiving.
                                    I'll revise the code and re-test in a few...
                                    • Boots33B Boots33
                                                break;
                                                break;
                                          #ifdef MY_DEBUG
                                      MasMatM Offline
                                      MasMatM Offline
                                      MasMat
                                      This post is deleted!
                                      • Boots33B Boots33
                                                  break;
                                                  break;
                                            #ifdef MY_DEBUG
                                        MasMatM Offline
                                        MasMatM Offline
                                        MasMat
                                        @Boots33 So, added some tuff to keep the other relays working.
                                        The issue now is bouncing apparently.
                                        The send-node has delay but seems to fire a bunch of 1's (and 0's for some reason...?).
                                        Here's the lastest on the receiving end:
                                                  break;
                                                case 7:
                                                  break;
                                                case 8:
                                                  break;
                                                default:
                                                  break;
                                                  break;
                                            #ifdef MY_DEBUG
                                        The send-node is still
                                        //destination specs
                                          #else
                                            send(MyMessage(CHILD_ID_BUTTON1, V_STATUS).setSensor(WC_SENSOR_ID).setDestination(WC_NODE_ID).set("1"));
                                            Serial.println("Toggling remote node ");
                                            Serial.print(WC_NODE_ID);
                                            Serial.print(", sensor ");
                                            Serial.println(WC_SENSOR_ID);
                                            sentCounter++;
                                        previous = reading;
                                          delay (400);
                                          sleep(0, CHANGE, 0);
                                        • MasMatM MasMat
                                                    break;
                                                  case 7:
                                                    break;
                                                  case 8:
                                                    break;
                                                  default:
                                                    break;
                                                    break;
                                              #ifdef MY_DEBUG
                                          //destination specs
                                            #else
                                              sentCounter++;
                                          previous = reading;
                                            delay (400);
                                          Boots33B Offline
                                          Boots33B Offline
                                          Boots33
                                          @MasMat You could try increasing your delay time out to several seconds to see what happens (probably should use wait instead of delay as well) and maybe comment out the sleep line too. This may at least give you an idea of where to start.
                                          perhaps post some of the serial monitor output from the node.
