  3. Momentary button to control lights
29 Posts 6 Posters 9.4k Views 7 Watching
  • Boots33B Boots33
    @MasMat You could try increasing your delay time out to several seconds to see what happens (probably should use wait instead of delay as well) and maybe comment out the sleep line too. This may at least give you an idea of where to start.
    perhaps post some of the serial monitor output from the node.
    MasMatM Offline
    MasMatM Offline
    MasMat
    wrote on last edited by MasMat
    #21
    @Boots33 I increased it already but it didnt help. I can comment out the sleep but eventually I will need it because the sensor is obviously bat powered.
    I also tested putting delay before the read to let things stabilize. Tried 50 but same behavior.
    Im not really familiar with using the interrupts. Is my syntax correct in the sleep-line? I read somewhere that pin2 =interrupt0? Or use sleep (0, falling, 0)? Instead of "change"?
    Boots33B 1 Reply Last reply
    • MasMatM MasMat
      Boots33B Offline
      Boots33B Offline
      Boots33
      @MasMat said in Momentary button to control lights:
      You still need to find the cause of the multiple sends so comment out sleep and see if that is the cause. It is an easy thing to try.
      I have no battery powered nodes so probably not the best person to ask on the use of sleep. I would definitely try
      sleep(0, FALLING, 0);
      and see what that brings.
      If you comment out sleep and the node works as expected then it may be worth starting a new thread focusing on the sleep problem, at least that may bring the problem to the attention of others who have used sleep before.
      Again serial output may shed further light on what is going wrong.
      • MasMatM Offline
        MasMatM Offline
        MasMat
        Fighting with this after a while.
        I got the serial output from the sending node, but it appears to send the message only once.
        However when I checked the gateway it seems to receive and forward the message three times. Then it reboots. Power issue? I have a NRF24-LA on the gateway so could that be pulling too much juice?
        Could there be a signalling bounce?
        Serial output from when I clicked the button on the remote:
        0;255;3;0;9;TSF:MSG:READ,7-7-3,s=3,c=1,t=2,pt=0,l=1,sg=0:1
        0;255;3;0;9;TSF:MSG:REL MSG
        0;255;3;0;9;TSF:MSG:SEND,7-0-9-3,s=3,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:1
        0;255;3;0;9;!TSF:MSG:SEND,7-0-9-3,s=3,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=NACK:1
        0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.1
        0;255;3;0;9;TSM:INIT
        0;255;3;0;9;TSF:WUR:MS=0
        0;255;3;0;9;TSM:INIT:TSP OK
        0;255;3;0;9;TSM:INIT:GW MODE
        0;255;3;0;9;TSF:MSG:READ,3-9-0,s=3,c=1,t=2,pt=1,l=1,sg=0:0
        IP: 192.168.0.201
        0;255;3;0;9;MCO:BGN:STP
        IP: 192.168.0.201
        0;255;3;0;9;MQTT connected```
          you could try to update mysensors to 2.2 from development branch
          MasMatM 1 Reply Last reply
            MasMatM Offline
            MasMatM Offline
            MasMat
            @gohan I'm just gonna let my n00b flag fly here....
            How do I do that? Arduino IDE library?
            To combat the reboots, I'm rebuilding the GW with adequate power and capacitors.
            Hopefully that will solve some problems.
              Just download the library from github and replace the mysensors folder in the library folder on your pc
                MasMatM Offline
                MasMatM Offline
                MasMat
                @gohan OK. Doesn't sound too hard. Does that mean I also have to update the GW? All my other nodes as well? Or are they backwards compatible?
                  Start from gw and see if you are getting any changes. Later you may update the nodes if you want.
                  • D Offline
                    My gateway is a serial gateway built with an easy newbie PCB and a pro mini.
                    What I did when I upgraded my 1.4 setup to 2.0, I pulled my pro mini that I had flashed with the 1.4 setup and put a new pro mini in that had 2.0. That way if there were any problems, I could easily swap the 1.4 pro mini back in to easily be back where I started.
                    Likewise when replacing your library, pull the MySensors folder out of your arduino libraries folder to keep as a backup until you know things will work. That way if you have to revert back, you can easily swap back the old MySensors folder. You have to completely remove it from the libraries folder though, you can't just rename it to something else.
