  3. Momentary button to control lights
29 Posts 6 Posters 9.9k Views 7 Watching
  • MasMatM
    MasMatM
    MasMat
    Tried moving the numberPushes. Not working. I decided to tackle the "toggle problem" another way. Still no joy.
    Anyone have time to check my writing, much appreciated. Also if someone has code that works to make a momentary switch work like a toggle, that would be greatly appreciated.
    #define MY_NODE_ID 7
    int oldBatteryPcnt = 0;
    #define CHILD_ID_BUTTON1 3
    //#define SECONDARY_CHILD_ID 4
    #define BUTTON_PIN 2   // Arduino Digital I/O pin for button/reed switch
    //#define SECONDARY_BUTTON_PIN 3 // Arduino Digital I/O pin for button/reed switch
    #define INTERRUPT BUTTON_PIN-2
    MyMessage msg(CHILD_ID_BUTTON1, V_TRIPPED);
    //MyMessage msg2(SECONDARY_CHILD_ID, V_TRIPPED);
    int tripped = 1;
    int lastStatus = 1;
    int numberPushes = 0;
    int light1 = LOW;      // the current state of the output pin
    int reading;           // the current reading from the input pin
    int previous = HIGH;    // the previous reading from the input pin
    // the follow variables are long's because the time, measured in miliseconds,
    // will quickly become a bigger number than can be stored in an int.
    long time = 0;         // the last time the output pin was toggled
    long debounce = 400;   // the debounce time, increase if the output flickers
    long batteryinterval = 10000;
    	// Setup the buttons
    	pinMode(BUTTON_PIN, INPUT);
    	//pinMode(SECONDARY_BUTTON_PIN, INPUT);
    	// Activate internal pull-ups
    	//digitalWrite(SECONDARY_BUTTON_PIN, HIGH);
      analogReference(INTERNAL1V1);
      analogReference(INTERNAL);
      sendSketchInfo("WCNappiBAT", "vMasi030717");
    	present(CHILD_ID_BUTTON1, S_DOOR);
    	//present(SECONDARY_CHILD_ID, S_DOOR);
    // Another approach
    reading = digitalRead(BUTTON_PIN);
      // if the input just went from LOW and HIGH and we've waited long enough
      // to ignore any noise on the circuit, toggle the output pin and remember
      // the time
      if (reading == HIGH && previous == LOW && millis() - time > debounce) {
        if (light1 == LOW)
          light1 = HIGH && send(msg.set("1"));
          //Serial.println("Switching on");
          light1 = LOW && send(msg.set("0"));
    Serial.println("Switch toggling");
    delay (100);
      previous = reading;
    // if (millis() - time > batteryinterval) {
      // get the battery Voltage
    #ifdef MY_DEBUG
      Serial.println(sensorValue);
    #ifdef MY_DEBUG
      Serial.print(batteryV);
      Serial.println(" V");
      Serial.print(batteryPcnt);
      Serial.println(" %");
      //if (oldBatteryPcnt != batteryPcnt) {
        // Power up radio after sleep
        //oldBatteryPcnt = batteryPcnt;
          time = millis();
    	sleep(BUTTON_PIN-2, FALLING, 0);
    Boots33B 1 Reply Last reply
      Why do you use button_pin and button_pin-2?
        @gohan BUTTON_PIN-2 was used in some early MySensors examples instead of digitalPinToInterrupt(BUTTON_PIN). Very ugly and we have gotten rid of it in the current examples but early users could still have sketches with that code.
        • MasMatM MasMat
          int tripped = 1;
          int lastStatus = 1;
          // Another approach
            // the time
              if (light1 == LOW)
          delay (100);
            previous = reading;
          #ifdef MY_DEBUG
          #ifdef MY_DEBUG
                time = millis();
          Boots33B
          Boots33B
          Boots33
          @MasMat Your remote switch node can never be sure if the light on the slave node is on or off (it may have been changed by the controller)
          To toggle a light from a remote I have found it easiest to place the toggle code in the node that controls the light not in the remote switch. You can then just send a node to node message from your remote to trigger the toggle.
          You could also use a node to node request to get the current state of the light but I think you will find it simpler using the first method.
          Without seeing your light controller node sketch it is hard to be specific but a very simple sketch could be like bellow.
          You can see all the work is done in the receive function.
          If the message is from your controller (through the gateway node 0) it will just set the light to the arriving state.
          If the message is from your remote (node 7) then it will toggle the light state.
          /* This sketch is to control a light and also
           *  allow control from a remote switch
          #define LIGHT_PIN  6             // Arduino Digital  pin connected to mosfet or relay that controls light
          #define LIGHT_ON 1                 // Output value to write to turn on attached mosfet
          #define LIGHT_OFF 0                // Output value to write to turn off attached mosfet
          #define CHILD_ID_LIGHT 1
          bool state = 0;                        // State holder for light
          MyMessage msg(CHILD_ID_LIGHT, V_STATUS);
            pinMode(LIGHT_PIN, OUTPUT);            //set light pin as output
            digitalWrite(LIGHT_PIN, LIGHT_OFF);    //   make sure light is off at startup
          void presentation()  {
            sendSketchInfo("Light controller", "1.0");
            present(CHILD_ID_LIGHT, S_BINARY, "House Light");
          /*-------------------------start of functions-------------------*/
          if (message.type == V_STATUS) {                                  // check that message is for binary switch
            if (message.sender == 0) {                                     // check if message is from gateway (node 0)
                 state = message.getBool();
                 digitalWrite(LIGHT_PIN, state ? LIGHT_ON : LIGHT_OFF); // Set Light A to the new state
            else if (message.sender == 7) {                                  // message is from  remote (node 7)
                  state = !state;                                         // toggle light state
                  send(msg.set(state), false);                            //Message the gateway so controller will be aware of the change. No ack
              /*-------Write some debug info-----*/
          #ifdef MY_DEBUG
              Serial.print(" from node: ");
              Serial.println(message.sender);
          MasMatM 1 Reply Last reply
          • Boots33B Boots33
            #ifdef MY_DEBUG
            MasMatM
            MasMatM
            MasMat
            wrote on last edited by MasMat
            @Boots33 Will try that.
            My idea was to "let the switch be dumb" sending alternating 1 or 0. People tend to push on buttons until something happens :)
            Also I'm using this sketch as a run-up to building a two button remote.
            I can easily access the code the receiving node and have the remote node "just send 1or0" every time it's pushed?
            It will need more code if I have two buttons.
            PS where can I find the docs for "message.sender & message.destination" options?
            mfalkviddM Boots33B 2 Replies Last reply
            • MasMatM MasMat
              @MasMat I'm not sure if there is a more user-friendy documentation somewhere, but the source code has some information: https://github.com/mysensors/MySensors/blob/ff0953dd05b4f5e52e7d2c39ad23d207c896ea5e/core/MyMessage.h#L345
              • MasMatM MasMat
                Boots33B
                Boots33B
                Boots33
                wrote on last edited by Boots33
                @MasMat said in Momentary button to control lights:
                Yes that is the best way. But it doesn't really need to change from 1 or 0 it can just send the same thing all the time.
                I can easily access the code the receiving node and have the remote node "just >send 1or0" every time it's pushed?
                In the receive function of my sketch you can see that it will toggle on any message from node 7.
                So it does not matter whether you send a 1 or 0 it will still toggle. This will make your switch code simpler, it does not need to know what the current state is it can for example just send a 1 every time the button is pushed and the light will toggle.
                Multiple buttons will be fine. you will just need to use message.sensor in the receive function to test for which child sensor the message is for.
                PS where can I find the docs for "message.sender & message.destination" >options?
                The core files as linked to by @mfalkvidd are the place to look.
                I used most of what you will need in previous posts and projects, have a read thru these.
                LCD Node - display temp from other sensor - How?
                Synchronising Light switch
                Outdoors Touch Switch light controller
                Display node: how to set up
                AC Power controller with node to node remotes
                • Boots33B Boots33
                  MasMatM
                  MasMatM
                  MasMat
                  @Boots33 I checked out your links. I love the outdoor touch controller!! That's awesome!
                  I'm trying to figure out the "switch"-function, but Mysensors-docs nor Google cant find much.
                  I'm trying to figure out how switch=>case works. I could use that to further my one (and two or more!) button remote. Where I get lost is why "case 4" is completely different from the other three?
                  Any advice?
                  • MasMatM MasMat
                    Any advice?
                    Boots33B
                    Boots33B
                    Boots33
                    the switch/case is a standard arduino function. It can be very useful and sometimes much neater than using multiple if then else statements.
                    Yes it is well suited to that task.
                    Any advice?
                    Is it this you are referring to
                    case 4:
                             groupState = !groupState ;                   //Toggle the state
                             send(msg.set(groupState), false);     // send new state to controller, no ack requested
                             tone(buzzerPin, 1200, 60);                  //Play short beep to acknowledge touch
                    The first three case statements are sending direct node to node messages which are handled by the receiving node. The case 4 code is simply sending a standard binary switch message to my controller (Domoticz) and toggles the state of the switch in domoticz. I have that one switch set up as a group control switch in Domoticz so it turns on/off several light nodes at the same time. Sort of like a master control switch.
                    As i indicated in that original post the sketch was still in it's early testing stages. While I still have not completely finished the project yet it has been out in the garden for some months and has shown no false triggers from either rain or even birds landing on the touch pad.
                    Hope that helps. feel free to ask if you require any more info. MySensors node to node messages are really quite flexible once you get the hang of them. :)
                    • MasMatM
                      MasMatM
                      MasMat
                      All right. Been banging my head at this all day again.
                      I seem to be sending the message from the node OK, but the receiving node appears to have intermittent problems. And for some reason, my gateway reboots at some "combinations".
                      I have gone thru the send-node & receive-node code tens of times.
                      Help & ideas appreciated. Plz excuse the finnish in the code :)
                      Send-node
                      //destination specs
                      #define WC_SENSOR_ID 3
                      #define WC_NODE_ID 3
                      #define BUTTON_PIN 2   //pin for button
                      //#define INTERRUPT BUTTON_PIN
                      MyMessage msg(CHILD_ID_BUTTON1, V_STATUS);
                      int tripped = 1;
                      int lastStatus = 1;
                      int sentCounter = 0;
                        sendSketchInfo("WCNappiBAT", "v290717");
                      	present(CHILD_ID_BUTTON1, S_BINARY);
                        if (reading == LOW && previous == HIGH) {
                          send(MyMessage(CHILD_ID_BUTTON1, V_STATUS).setSensor(WC_SENSOR_ID).setDestination(WC_NODE_ID).set(true));
                          Serial.println("Toggling..");
                          sentCounter++;
                      previous = reading;
                      if (sentCounter % 10 == 0) {
                        delay (200);
                        sleep(BUTTON_PIN-2, CHANGE, 0);
                      And the receiving end.
                      In the code is preparations for my second "remote"
                      #define MY_NODE_ID 3
                      //#define MY_REPEATER_FEATURE
                      #define NUMBER_OF_RELAYS 6 // Total number of attached relays
                      #define RELAY_7 14   //pin A0
                      #define RELAY_8 15   //pin A1
                      bool stateWC = 0;
                      bool stateKei = 0;
                      bool stateRuo = 0;
                      void before()
                      		pinMode(pin, OUTPUT);
                       pinMode(RELAY_7, OUTPUT);
                       digitalWrite(RELAY_7, loadState(7)?RELAY_ON:RELAY_OFF);
                       pinMode(RELAY_8, OUTPUT);
                       digitalWrite(RELAY_8, loadState(8)?RELAY_ON:RELAY_OFF);
                      MyMessage msgWC(3, V_STATUS);
                      MyMessage msgKei(1, V_STATUS);
                      MyMessage msgRuo(2, V_STATUS);
                      	sendSketchInfo("TeknRele8x", "v29072017");
                      		present(sensor, S_BINARY);
                       present(7, S_BINARY);
                       present(8, S_BINARY);
                      	if (message.type==V_STATUS) {                             	// Change relay state
                         if (message.sensor == 7) {
                         digitalWrite(RELAY_7, message.getBool()?RELAY_ON:RELAY_OFF);    //Write to A0
                         // Store state in eeprom
                         if (message.sensor == 8) {
                          digitalWrite(RELAY_8, message.getBool()?RELAY_ON:RELAY_OFF);   //Write to A1
                         if (message.sender == 7) {                      //Message from WC remote
                         stateWC = !stateWC;                             // toggle light state
                         digitalWrite(5, stateWC?RELAY_ON:RELAY_OFF);    // 5 is RELAY_3 pin
                          saveState(message.sensor, stateWC);
                          send(msgWC.set(stateWC), false);             //Msg gateway aware of the change. No ack
                         if (message.sender == 8) {
                          switch (message.sensor) {
                            case 1:                                     //message for kitchen
                              stateKei = !stateKei;
                              digitalWrite(message.sensor, stateKei?RELAY_ON:RELAY_OFF);
                              saveState(message.sensor, stateKei);
                              send(msgKei.set(stateKei), false);             //Msg gateway aware of the change. No ack
                            case 2:                                    //message for dining table
                              stateRuo = !stateRuo;
                              digitalWrite(message.sensor, stateRuo?RELAY_ON:RELAY_OFF);
                              saveState(message.sensor, stateRuo);
                              send(msgRuo.set(stateRuo), false);             //Msg gateway aware of the change. No ack
                      To add, I would say there's nothing special in either serial output. I can elborate if nothing else appears.
                      Thanks everybody!
                      • MasMatM MasMat
                        Send-node
                        //destination specs
                        int tripped = 1;
                        int lastStatus = 1;
                            sentCounter++;
                        previous = reading;
                          delay (200);
                        bool stateWC = 0;
                        bool stateKei = 0;
                        bool stateRuo = 0;
                        void before()
                        Thanks everybody!
                        Boots33B
                        Boots33B
                        Boots33
                        Yes your send message should be ok. You are sending a V_STATUS message from node 7 sensor 3 to node 3 sensor 3
                        Not sure what could be causing that but you will need to sort that out to get stability. I have not experienced any issues with my gateway using node to node.
                        You will need to add code to separate the incoming messages from your controller and remotes as they will need to be treated differently. Messages from your controller will have the gateway (node 0) as the sender so this can be used.
                        You have a lot going on in your receive function so maybe just put the code for the one node you are trying at the moment so it is easier to troubleshoot.
                        Try something like this
                                case 3:                                                      //incoming message is for WC relay (sensor 3)
                                  stateWC = message.getBool();                               // get the new state
                                  digitalWrite(5, stateWC ? RELAY_ON : RELAY_OFF);           // 5 is RELAY_3 pin
                                  saveState(message.sensor, stateWC);                        // save sensor state
                                /*-----Add case statements for other realys as needed ----*/
                          else  {                                                           // message is not from gateway so must be from a remote
                            switch (message.sender) {
                                case 7:                                                     //incoming message is from WC remote (node 7)
                                  saveState(message.sensor, stateWC);                       // Store state in eeprom
                                /*-----Add case statements for other remote nodes as needed ----*/
                            #ifdef MY_DEBUG
                            Serial.print("from node:");
                            Serial.print(" New status: ");
                        MasMatM 3 Replies Last reply
                        • Boots33B Boots33
                              #ifdef MY_DEBUG
                          MasMatM
                          MasMatM
                          MasMat
                          @Boots33 That looks really clean. And you're right I have to comment out the stuff that's pre-prepared.
                          The node is installed in a really tricky place and reprogramming is difficult (hence trying to solve everything beforehand). One day I'll learn to build & test first, install second...
                          This morning I tested the setup again, with old settings and noticed the correct relay "fires" but doesnt really toggle. If I switch it off, it will come on but stay on regardless of presses. So the right node is receiving.
                          I'll revise the code and re-test in a few...
                          • Boots33B Boots33
                                #ifdef MY_DEBUG
                            MasMatM
                            MasMatM
                            MasMat
                            • Boots33B Boots33
                                  #ifdef MY_DEBUG
                              MasMatM
                              MasMatM
                              MasMat
                              @Boots33 So, added some tuff to keep the other relays working.
                              The issue now is bouncing apparently.
                              The send-node has delay but seems to fire a bunch of 1's (and 0's for some reason...?).
                              Here's the lastest on the receiving end:
                                      case 7:
                                      case 8:
                                      default:
                                  #ifdef MY_DEBUG
                              The send-node is still
                              //destination specs
                                  send(MyMessage(CHILD_ID_BUTTON1, V_STATUS).setSensor(WC_SENSOR_ID).setDestination(WC_NODE_ID).set("1"));
                                  Serial.println("Toggling remote node ");
                                  Serial.print(WC_NODE_ID);
                                  Serial.print(", sensor ");
                                  Serial.println(WC_SENSOR_ID);
                                  sentCounter++;
                              previous = reading;
                                delay (400);
                                sleep(0, CHANGE, 0);
                              • MasMatM MasMat
                                        case 7:
                                        case 8:
                                        default:
                                    #ifdef MY_DEBUG
                                //destination specs
                                    sentCounter++;
                                previous = reading;
                                  delay (400);
                                Boots33B
                                Boots33B
                                Boots33
                                @MasMat You could try increasing your delay time out to several seconds to see what happens (probably should use wait instead of delay as well) and maybe comment out the sleep line too. This may at least give you an idea of where to start.
                                perhaps post some of the serial monitor output from the node.
                                • Boots33B Boots33
                                  MasMatM
                                  MasMatM
                                  MasMat
                                  #21
                                  @Boots33 I increased it already but it didnt help. I can comment out the sleep but eventually I will need it because the sensor is obviously bat powered.
                                  I also tested putting delay before the read to let things stabilize. Tried 50 but same behavior.
                                  Im not really familiar with using the interrupts. Is my syntax correct in the sleep-line? I read somewhere that pin2 =interrupt0? Or use sleep (0, falling, 0)? Instead of "change"?
                                  • MasMatM MasMat
                                    Boots33B
                                    Boots33B
                                    Boots33
                                    You still need to find the cause of the multiple sends so comment out sleep and see if that is the cause. It is an easy thing to try.
                                    I have no battery powered nodes so probably not the best person to ask on the use of sleep. I would definitely try
                                    sleep(0, FALLING, 0);
                                    and see what that brings.
                                    If you comment out sleep and the node works as expected then it may be worth starting a new thread focusing on the sleep problem, at least that may bring the problem to the attention of others who have used sleep before.
                                    Again serial output may shed further light on what is going wrong.
                                    • MasMatM
                                      MasMatM
                                      MasMat
                                      Fighting with this after a while.
                                      I got the serial output from the sending node, but it appears to send the message only once.
                                      However when I checked the gateway it seems to receive and forward the message three times. Then it reboots. Power issue? I have a NRF24-LA on the gateway so could that be pulling too much juice?
                                      Could there be a signalling bounce?
                                      Serial output from when I clicked the button on the remote:
                                      0;255;3;0;9;TSF:MSG:READ,7-7-3,s=3,c=1,t=2,pt=0,l=1,sg=0:1
                                      0;255;3;0;9;TSF:MSG:REL MSG
                                      0;255;3;0;9;TSF:MSG:SEND,7-0-9-3,s=3,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:1
                                      0;255;3;0;9;!TSF:MSG:SEND,7-0-9-3,s=3,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=NACK:1
                                      0;255;3;0;9;TSM:INIT
                                      0;255;3;0;9;TSF:WUR:MS=0
                                      0;255;3;0;9;TSM:INIT:TSP OK
                                      0;255;3;0;9;TSM:INIT:GW MODE
                                      0;255;3;0;9;TSF:MSG:READ,3-9-0,s=3,c=1,t=2,pt=1,l=1,sg=0:0
                                      IP: 192.168.0.201
                                      0;255;3;0;9;MCO:BGN:STP
                                      IP: 192.168.0.201
                                      0;255;3;0;9;MQTT connected```
                                        you could try to update mysensors to 2.2 from development branch
                                          MasMatM
                                          MasMatM
                                          MasMat
                                          @gohan I'm just gonna let my n00b flag fly here....
                                          How do I do that? Arduino IDE library?
                                          To combat the reboots, I'm rebuilding the GW with adequate power and capacitors.
                                          Hopefully that will solve some problems.
