  3. Momentary button to control lights
29 Posts 6 Posters 9.9k Views 7 Watching
  • MasMatM MasMat
    @Boots33 I checked out your links. I love the outdoor touch controller!! That's awesome!
    I'm trying to figure out the "switch"-function, but Mysensors-docs nor Google cant find much.
    I'm trying to figure out how switch=>case works. I could use that to further my one (and two or more!) button remote. Where I get lost is why "case 4" is completely different from the other three?
    Any advice?
    Boots33B
    Boots33B
    Boots33
    @MasMat said in Momentary button to control lights:
    the switch/case is a standard arduino function. It can be very useful and sometimes much neater than using multiple if then else statements.
    Yes it is well suited to that task.
    Any advice?
    Is it this you are referring to
    case 4:
             groupState = !groupState ;                   //Toggle the state
             send(msg.set(groupState), false);     // send new state to controller, no ack requested
             tone(buzzerPin, 1200, 60);                  //Play short beep to acknowledge touch
    The first three case statements are sending direct node to node messages which are handled by the receiving node. The case 4 code is simply sending a standard binary switch message to my controller (Domoticz) and toggles the state of the switch in domoticz. I have that one switch set up as a group control switch in Domoticz so it turns on/off several light nodes at the same time. Sort of like a master control switch.
    As i indicated in that original post the sketch was still in it's early testing stages. While I still have not completely finished the project yet it has been out in the garden for some months and has shown no false triggers from either rain or even birds landing on the touch pad.
    Hope that helps. feel free to ask if you require any more info. MySensors node to node messages are really quite flexible once you get the hang of them. :)
    • MasMatM
      MasMatM
      MasMat
      All right. Been banging my head at this all day again.
      I seem to be sending the message from the node OK, but the receiving node appears to have intermittent problems. And for some reason, my gateway reboots at some "combinations".
      I have gone thru the send-node & receive-node code tens of times.
      Help & ideas appreciated. Plz excuse the finnish in the code :)
      Send-node
      #define MY_NODE_ID 7
      //destination specs
      #define WC_SENSOR_ID 3
      #define WC_NODE_ID 3
      int oldBatteryPcnt = 0;
      #define CHILD_ID_BUTTON1 3
      #define BUTTON_PIN 2   //pin for button
      //#define INTERRUPT BUTTON_PIN
      MyMessage msg(CHILD_ID_BUTTON1, V_STATUS);
      int tripped = 1;
      int lastStatus = 1;
      int numberPushes = 0;
      int sentCounter = 0;
      int light1 = LOW;      // the current state of the output pin
      int reading;           // the current reading from the input pin
      int previous = HIGH;    // the previous reading from the input pin
      // the follow variables are long's because the time, measured in miliseconds,
      // will quickly become a bigger number than can be stored in an int.
      long time = 0;         // the last time the output pin was toggled
      long debounce = 400;   // the debounce time, increase if the output flickers
      long batteryinterval = 10000;
      	// Setup the buttons
      	pinMode(BUTTON_PIN, INPUT);
      	//pinMode(SECONDARY_BUTTON_PIN, INPUT);
      	// Activate internal pull-ups
      	//digitalWrite(SECONDARY_BUTTON_PIN, HIGH);
        analogReference(INTERNAL1V1);
        analogReference(INTERNAL);
        sendSketchInfo("WCNappiBAT", "v290717");
      	present(CHILD_ID_BUTTON1, S_BINARY);
      reading = digitalRead(BUTTON_PIN);
        if (reading == LOW && previous == HIGH) {
          send(MyMessage(CHILD_ID_BUTTON1, V_STATUS).setSensor(WC_SENSOR_ID).setDestination(WC_NODE_ID).set(true));
          Serial.println("Toggling..");
          sentCounter++;
      previous = reading;
      if (sentCounter % 10 == 0) {
        Serial.print(batteryV);
        Serial.println(" V");
        Serial.print(batteryPcnt);
        Serial.println(" %");
        delay (200);
        sleep(BUTTON_PIN-2, CHANGE, 0);
      And the receiving end.
      In the code is preparations for my second "remote"
      #define MY_NODE_ID 3
      //#define MY_REPEATER_FEATURE
      #define NUMBER_OF_RELAYS 6 // Total number of attached relays
      #define RELAY_7 14   //pin A0
      #define RELAY_8 15   //pin A1
      bool stateWC = 0;
      bool stateKei = 0;
      bool stateRuo = 0;
      void before()
      		pinMode(pin, OUTPUT);
       pinMode(RELAY_7, OUTPUT);
       digitalWrite(RELAY_7, loadState(7)?RELAY_ON:RELAY_OFF);
       pinMode(RELAY_8, OUTPUT);
       digitalWrite(RELAY_8, loadState(8)?RELAY_ON:RELAY_OFF);
      MyMessage msgWC(3, V_STATUS);
      MyMessage msgKei(1, V_STATUS);
      MyMessage msgRuo(2, V_STATUS);
      	sendSketchInfo("TeknRele8x", "v29072017");
      		present(sensor, S_BINARY);
       present(7, S_BINARY);
       present(8, S_BINARY);
      	if (message.type==V_STATUS) {                             	// Change relay state
         if (message.sensor == 7) {
         digitalWrite(RELAY_7, message.getBool()?RELAY_ON:RELAY_OFF);    //Write to A0
         // Store state in eeprom
         if (message.sensor == 8) {
          digitalWrite(RELAY_8, message.getBool()?RELAY_ON:RELAY_OFF);   //Write to A1
         if (message.sender == 7) {                      //Message from WC remote
         stateWC = !stateWC;                             // toggle light state
         digitalWrite(5, stateWC?RELAY_ON:RELAY_OFF);    // 5 is RELAY_3 pin
          saveState(message.sensor, stateWC);
          send(msgWC.set(stateWC), false);             //Msg gateway aware of the change. No ack
         if (message.sender == 8) {
          switch (message.sensor) {
            case 1:                                     //message for kitchen
              stateKei = !stateKei;
              digitalWrite(message.sensor, stateKei?RELAY_ON:RELAY_OFF);
              saveState(message.sensor, stateKei);
              send(msgKei.set(stateKei), false);             //Msg gateway aware of the change. No ack
            case 2:                                    //message for dining table
              stateRuo = !stateRuo;
              digitalWrite(message.sensor, stateRuo?RELAY_ON:RELAY_OFF);
              saveState(message.sensor, stateRuo);
              send(msgRuo.set(stateRuo), false);             //Msg gateway aware of the change. No ack
      To add, I would say there's nothing special in either serial output. I can elborate if nothing else appears.
      Thanks everybody!
      Boots33B 1 Reply Last reply
      • MasMatM MasMat
        Send-node
        //destination specs
        int tripped = 1;
        int lastStatus = 1;
            sentCounter++;
        previous = reading;
          delay (200);
        bool stateWC = 0;
        bool stateKei = 0;
        bool stateRuo = 0;
        void before()
        Thanks everybody!
        Boots33B
        Boots33B
        Boots33
        Yes your send message should be ok. You are sending a V_STATUS message from node 7 sensor 3 to node 3 sensor 3
        Not sure what could be causing that but you will need to sort that out to get stability. I have not experienced any issues with my gateway using node to node.
        You will need to add code to separate the incoming messages from your controller and remotes as they will need to be treated differently. Messages from your controller will have the gateway (node 0) as the sender so this can be used.
        You have a lot going on in your receive function so maybe just put the code for the one node you are trying at the moment so it is easier to troubleshoot.
        Try something like this
           if (message.sender == 0) {                                        // check if message is from gateway (node 0)
                case 3:                                                      //incoming message is for WC relay (sensor 3)
                  stateWC = message.getBool();                               // get the new state
                  digitalWrite(5, stateWC ? RELAY_ON : RELAY_OFF);           // 5 is RELAY_3 pin
                  saveState(message.sensor, stateWC);                        // save sensor state
                /*-----Add case statements for other realys as needed ----*/
          else  {                                                           // message is not from gateway so must be from a remote
            switch (message.sender) {
                case 7:                                                     //incoming message is from WC remote (node 7)
                  saveState(message.sensor, stateWC);                       // Store state in eeprom
                /*-----Add case statements for other remote nodes as needed ----*/
            #ifdef MY_DEBUG
            Serial.print("from node:");
            Serial.println(message.sender);
            Serial.print(" New status: ");
        MasMatM 3 Replies Last reply
        • Boots33B Boots33
              #ifdef MY_DEBUG
          MasMatM
          MasMatM
          MasMat
          @Boots33 That looks really clean. And you're right I have to comment out the stuff that's pre-prepared.
          The node is installed in a really tricky place and reprogramming is difficult (hence trying to solve everything beforehand). One day I'll learn to build & test first, install second...
          This morning I tested the setup again, with old settings and noticed the correct relay "fires" but doesnt really toggle. If I switch it off, it will come on but stay on regardless of presses. So the right node is receiving.
          I'll revise the code and re-test in a few...
          • Boots33B Boots33
                #ifdef MY_DEBUG
            MasMatM
            MasMatM
            MasMat
            • Boots33B Boots33
                  #ifdef MY_DEBUG
              MasMatM
              MasMatM
              MasMat
              @Boots33 So, added some tuff to keep the other relays working.
              The issue now is bouncing apparently.
              The send-node has delay but seems to fire a bunch of 1's (and 0's for some reason...?).
              Here's the lastest on the receiving end:
                      case 7:
                      case 8:
                      default:
                  #ifdef MY_DEBUG
              The send-node is still
              //destination specs
                  send(MyMessage(CHILD_ID_BUTTON1, V_STATUS).setSensor(WC_SENSOR_ID).setDestination(WC_NODE_ID).set("1"));
                  Serial.println("Toggling remote node ");
                  Serial.print(WC_NODE_ID);
                  Serial.print(", sensor ");
                  Serial.println(WC_SENSOR_ID);
                  sentCounter++;
              previous = reading;
                delay (400);
                sleep(0, CHANGE, 0);
              • MasMatM MasMat
                        case 7:
                        case 8:
                        default:
                    #ifdef MY_DEBUG
                //destination specs
                    sentCounter++;
                previous = reading;
                  delay (400);
                Boots33B
                Boots33B
                Boots33
                @MasMat You could try increasing your delay time out to several seconds to see what happens (probably should use wait instead of delay as well) and maybe comment out the sleep line too. This may at least give you an idea of where to start.
                perhaps post some of the serial monitor output from the node.
                MasMatM 1 Reply Last reply
                • Boots33B Boots33
                  MasMatM
                  MasMatM
                  MasMat
                  wrote on last edited by MasMat
                  #21
                  @Boots33 I increased it already but it didnt help. I can comment out the sleep but eventually I will need it because the sensor is obviously bat powered.
                  I also tested putting delay before the read to let things stabilize. Tried 50 but same behavior.
                  Im not really familiar with using the interrupts. Is my syntax correct in the sleep-line? I read somewhere that pin2 =interrupt0? Or use sleep (0, falling, 0)? Instead of "change"?
                  • MasMatM MasMat
                    Boots33B
                    Boots33B
                    Boots33
                    You still need to find the cause of the multiple sends so comment out sleep and see if that is the cause. It is an easy thing to try.
                    I have no battery powered nodes so probably not the best person to ask on the use of sleep. I would definitely try
                    sleep(0, FALLING, 0);
                    and see what that brings.
                    If you comment out sleep and the node works as expected then it may be worth starting a new thread focusing on the sleep problem, at least that may bring the problem to the attention of others who have used sleep before.
                    Again serial output may shed further light on what is going wrong.
                    • MasMatM
                      MasMatM
                      MasMat
                      Fighting with this after a while.
                      I got the serial output from the sending node, but it appears to send the message only once.
                      However when I checked the gateway it seems to receive and forward the message three times. Then it reboots. Power issue? I have a NRF24-LA on the gateway so could that be pulling too much juice?
                      Could there be a signalling bounce?
                      Serial output from when I clicked the button on the remote:
                      0;255;3;0;9;TSF:MSG:READ,7-7-3,s=3,c=1,t=2,pt=0,l=1,sg=0:1
                      0;255;3;0;9;TSF:MSG:REL MSG
                      0;255;3;0;9;TSF:MSG:SEND,7-0-9-3,s=3,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:1
                      0;255;3;0;9;!TSF:MSG:SEND,7-0-9-3,s=3,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=NACK:1
                      0;255;3;0;9;TSM:INIT
                      0;255;3;0;9;TSF:WUR:MS=0
                      0;255;3;0;9;TSM:INIT:TSP OK
                      0;255;3;0;9;TSM:INIT:GW MODE
                      0;255;3;0;9;TSF:MSG:READ,3-9-0,s=3,c=1,t=2,pt=1,l=1,sg=0:0
                      IP: 192.168.0.201
                      0;255;3;0;9;MCO:BGN:STP
                      IP: 192.168.0.201
                      0;255;3;0;9;MQTT connected```
                        you could try to update mysensors to 2.2 from development branch
                          MasMatM
                          MasMatM
                          MasMat
                          @gohan I'm just gonna let my n00b flag fly here....
                          How do I do that? Arduino IDE library?
                          To combat the reboots, I'm rebuilding the GW with adequate power and capacitors.
                          Hopefully that will solve some problems.
                            Just download the library from github and replace the mysensors folder in the library folder on your pc
                              MasMatM
                              MasMatM
                              MasMat
                              @gohan OK. Doesn't sound too hard. Does that mean I also have to update the GW? All my other nodes as well? Or are they backwards compatible?
                                Start from gw and see if you are getting any changes. Later you may update the nodes if you want.
                                • dbemowskD
                                  dbemowskD
                                  My gateway is a serial gateway built with an easy newbie PCB and a pro mini.
                                  What I did when I upgraded my 1.4 setup to 2.0, I pulled my pro mini that I had flashed with the 1.4 setup and put a new pro mini in that had 2.0. That way if there were any problems, I could easily swap the 1.4 pro mini back in to easily be back where I started.
                                  Likewise when replacing your library, pull the MySensors folder out of your arduino libraries folder to keep as a backup until you know things will work. That way if you have to revert back, you can easily swap back the old MySensors folder. You have to completely remove it from the libraries folder though, you can't just rename it to something else.
