  3. 💬 Super-capacitor-power-supply-for-wireless-sensors-w-charger
supercapboost converterpower supply
5 Posts 5 Posters 2.5k Views 5 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/423/Super-capacitor-power-supply-for-wireless-sensors-w-charger
    TerrenceT 1 Reply Last reply
    • openhardware.ioO openhardware.io
      TerrenceT
      TerrenceT
      Terrence
      @openhardware.io Very cool.
      • B
        B
        bilbolodz
        Nice plese provide BOM because it's a little unclear which MIC5365/6 should be used
        • C
          C
          ceech
          Added. MIC5365/6's package is SC-70-5.
          • N
            N
            Noki
            @ceech
            I really like this design, however I think it has a problem:
            According to the datasheet the TPS610986DSET has no feature to disconnect the load at low battery voltages. I think the result will be that e.g. a ESP32 or other power hungry chips will not power up properly. The TPS63031 might therefore be a better fit.
            btw.: Do you still sell assembled versions of this design? Would you be willing to create a new version with the TPS63031 and probably also with 10 or 20F capacitors or an board to solder your own capacitors.
            Best regards
            Tobias
