  3. Mysensor Ethernet gateway message definition
3 Posts 2 Posters 1.1k Views 2 Watching
  • F
    F
    FredRoot
    Hi All,
    I have setup my Raspberry Pi as an Ethernet gateway and I have programmed the MotionSensor sample sketch to my arduino pro mini.
    When I execute the gateway in debug mode "sudo ./bin/mysgw -d" I get the following output:
    mysgw: TSF:MSG:READ,1-1-0,s=2,c=1,t=16,pt=0,l=1,sg=0:0
    What does the s=2, c=1, t=16... mean?
    • F FredRoot
      Hi All,
      @FredRoot see https://forum.mysensors.org/post/43373
      If you remove the "mysgw: " part you can use the log parser, like this.
      F 1 Reply Last reply
        F
        F
        FredRoot
        @mfalkvidd Thank you. This will help a lot
