  3. Radio plus sensor on the SPI bus
20 Posts 2 Posters 5.8k Views 2 Watching
  • D Offline
    I am wondering if it is possible to use two devices on the SPI bus. My nodes use nRF24L01+ radios which run on the SPI BUS. I am wondering if it is possible to add a sensor that would also use the bus?
    Y 1 Reply Last reply
    • D dbemowsk
      Y Offline
      Y Offline
      @dbemowsk should work just fine.
      Beware that when using mySensors with message queuing, the other spi device driver must use SPI transactions.
      D 2 Replies Last reply
      • Y Yveaux
        @Yveaux Thanks, that is what I was hoping to hear. I have not done a lot with SPI communications, so I am still learning this end of arduino. This is what I am trying to connect: https://www.digikey.com/products/en?mpart=AS5047P-TS_EK_AB&v=961
        Thanks for the quick response.
        Y 2 Replies Last reply
        • D dbemowsk
          Y Offline
          Y Offline
          @dbemowsk you will be quite busy! That link gives 5473963 Results :laughing:
          • Y Yveaux
            @Yveaux which link are you referring to?
            • D dbemowsk
              Y Offline
              Y Offline
              @dbemowsk but I guess you mean the as5047p, correct?
              If this is for your weather station you could also just take an earth magnetic field sensor to determine the angle of rotation of a rotating magnet. Much cheaper, available as module, very sensitive, but requires a little math to get the actual angle.
              • D dbemowsk
                Y Offline
                Y Offline
                @dbemowsk said in Radio plus sensor on the SPI bus:
                The digikey link
                • Y Yveaux
                  @Yveaux said in Radio plus sensor on the SPI bus:
                  I am not sure where you are seeing these results. The link I posted was to a part listed on the DigiKey website.
                  • D Offline
                    it is an AS5047P magnetic rotation sensor.
                    • D dbemowsk
                      Y Offline
                      Y Offline
                      @dbemowsk This is what I get when clicking the link on my mobile:
                      On a PC the sensor is correctly shown...
                      • D Offline
                        This is what I see on my machine:
                        0_1499499106871_upload-8167181e-aa58-40fe-a8fa-9b1c9ad0e248
                        • D dbemowsk
                          Y Offline
                          Y Offline
                          @dbemowsk Digikey walks in mysterious ways... (on mobile browsers at least...)
                          D 1 Reply Last reply
                          • Y Yveaux
                            @Yveaux So I see.
                            This is the part I purchased though.
                            0_1499499256682_upload-a31c6af7-925d-46ff-884a-3d83ed4b8284
                            I got it on ebay with the breakout board, magnet, header connector, and the person threw in a spare chip. I am using it for my wind direction sensor for my weather station project.
                            This is a library I found for it. https://github.com/smellsofbikes/AS5047_arduino_library
                            • Y Yveaux
                              Do you have any links to some information on using transactions?
                              • D dbemowsk
                                Y Offline
                                Y Offline
                                @dbemowsk https://www.arduino.cc/en/Reference/SPI
                                Basically, SPI transfers in the driver need to be enclosed in
                                SPI.beginTransaction(...)
                                SPI.endTransaction()
                                • Y Yveaux
                                  @Yveaux Sounds simple enough. Thanks for all the help.
                                  • D Offline
                                    So I have this set up for testing on my UNO. Uusing the library from here https://github.com/smellsofbikes/AS5047_arduino_library, this is the sample code I am running.
                                    #include "AS5047.h"
                                    AS5047 myAS5047(10); // SS pin
                                      SPI.begin;
                                      Serial.begin(9600);
                                      long value;
                                      value=(360*myAS5047.sensor_read())/16383;
                                      Serial.print("measured value: ");
                                      Serial.println(value);
                                      delay(1000);
                                    Using the code as written, it works perfectly giving me a reading between 0 and 360 as I rotate the direction sensor. Two questions I have though.
                                    First, When I migrate this over to my platform on my easy newbie board, the SS pin (defined on line 4), which as I understand is acting as a CS or chip select, should be on something other than 10 because the nRF24 is on 10 and each device should have its own CS, but if I change it to another pin on my UNO and change line 4 to match the pin that I put it on, it doesn't work. Is this because I need an SPI device on pin 10 first taking care of the SS or slave select?
                                    My second question would be, how would I write this using transactions?
                                    • D Offline
                                      Comment number 7 of this post http://forum.arduino.cc/index.php/topic,19770.0.html was the basis for part of my last question.
                                      • D dbemowsk
                                        Y Offline
                                        Y Offline
                                        @dbemowsk the library you're using says 'untested' in the readme, and that looks to be true :smile:
                                        The pin mode of _ss is set to input in the constructor of AS5047.cpp which doesn't seem correct. Try setting it to output and see what happens.
                                        • Y Yveaux
                                          @Yveaux Works perfect now, thanks. Now I just need to research calling this as a transaction. Just brainstorming a bit, I will most likely have a function written to grab the value from the sensorand begin and end the transaction there, but since I have never worked with transactions, I will need to research how to write the code to do that.
