  3. 433mhz outlet
433mhz outlet
433mhz
27 Posts 10 Posters 29.8k Views 5 Watching
  • axillentA axillent
    @C.r.a.z.y. Open any transmitting example from RCSwitch
    I never did it but I think send() function is designed for this
    https://code.google.com/p/rc-switch/wiki/HowTo_Send?tm=6
    C
    C
    C.r.a.z.y.
    @axillent Thank you i know you are very helpful. I tried to copy my remote to an universal remote learner(which has no name chipset) but it didnt copy. It is hard to understand and solve for a newbie.
    I simply tried to send 10101010codes with this sketch https://code.google.com/p/rc-switch/wiki/HowTo_Send?tm=6 and didnt work.
    Something interesting i found while tranmitting,
    If i remove the delay () than signal is always sent. I made a jammer! :) Any of my 433 remotes didnt work!
    I want to learn if any universal remote learner with EV1527 Chipset works with RCSwitch?
    My plan is to copy some remote codes to EV1527 universal remote and read the code from serial with RCSwitch-rfSniffer.
    Now i will try IR SENDER-RECEIVER http://www.mysensors.org/build/ir maybe i can get new ideas for 433mhz things..
    • J jribera
      Finally managed to get this working by modifying Dwalts sketch to use the rcswitch library.
      I found this much simpler to use as it allows you to learn your existing codes using a simple RF-Sniffer sketch (Sniffer.ino) ie no need to mess around with recording signals, binary codes etc. This sketch simply displays a decimal number which you can just send back to control your devices.
      ie
      define CODE_1On 0x5FF0DC //Sniffed code converted to Hex.
      Serial.println("Turn on Socket 1");
      mySwitch.send(CODE_1On, 24); // These codes are unique to each outlet
      delay(50);
      With this working i can now safely control a number of 240V devices around the home !
      D
      D
      diggs
      @jribera Been try to get this happening myself. Can you provide the sketch you ended up using to get this happening so I can try it. I know what all my codes are, just need to get a sketch happening to interface back to my controller (Domoticz Serial)
      Cheers
      • J
        J
        jribera
        This is the sketch i'm using for controlling a number of sockets around the house.
        /*  RF433Mhz Transmitter node:
            This sketch allows On-Off-Keying (OOK) control of four 433Mhz relay outlets
            which utilize the common PT2262 encoding chip for signal transmission. The sketch could
            be easily expanded to include additional outlets.  The sensor node consists of a nano
            connected to a NRF24L01 and a 433Mhz transmitter connected to pin 3, 5V and Gnd.  The
            transmitter can run off of 3.3V as well.
            The sketch is based on the MySensors project (http://www.mysensors.org).
            Submitted by Dwalt.
        //  Include related libraries
        #include <RF24.h>
        #include <RCSwitch.h>
        //  Define Constants
        #define RF433_CHILD_ID 0
        #define NUMBER_OF_OUTLETS 4 // Each outlet will have 2 OOK codes
        //#define SEND_DATA 3
        #define CODE_1On 6287582
        #define CODE_1Off 6287574
        #define CODE_2On 6287580
        #define CODE_2Off 6287572
        #define CODE_3On 6287578
        #define CODE_3Off 6287570
        #define CODE_4On 6287577
        #define CODE_4Off 6287569
        RCSwitch mySwitch = RCSwitch();
        mySwitch.enableTransmit(3);
         Serial.begin(115200); // Not sure why this was included
         //  The node is mains powered, so why not make it a repeater.
         // Send the sketch version information to gateway
         gw.sendSketchInfo("RF433", "1.1");
         // Register outlets to gw (they will be created as child devices)
         for(int i=0; i<NUMBER_OF_OUTLETS;i++) {
           gw.present(i+1, S_LIGHT);
          gw.process();
          if (message.type==V_LIGHT) {
          int incomingLightState =  message.getBool();
          int incomingOutlet = message.sensor;
          Serial.print("Outlet #: ");
          Serial.println(message.sensor);
          Serial.print("Command: ");
         if (incomingOutlet==1) {
         if (incomingLightState==1) {
            // Turn on  socket 1
         delay(50);
         if (incomingLightState==0)  {
            // Turn off socket 1
         Serial.println("Turn off Socket 1");
        mySwitch.send(CODE_1Off, 24);
        delay(50);
         if (incomingOutlet==2) {
            // Turn on  socket 2
            Serial.println("Turn on Socket 2");
        mySwitch.send(CODE_2On, 24);
         delay(50);
            // Turn off socket 2
         Serial.println("Turn off Socket 2");
        mySwitch.send(CODE_2Off, 24);
        delay(50);
         if (incomingOutlet==3) {
            // Turn on  socket 3
            Serial.println("Turn on Socket 3");
        mySwitch.send(CODE_3On, 24);
         delay(50);
            // Turn off socket 3
         Serial.println("Turn off Socket 3");
        mySwitch.send(CODE_3Off, 24);
        delay(50);
         if (incomingOutlet==4) {
            // Turn on  socket 4
            Serial.println("Turn on Socket 4");
         mySwitch.send(CODE_4On, 24);
         delay(50);
            // Turn off socket 4
         Serial.println("Turn off Socket 4");
        mySwitch.send(CODE_4Off, 24);
        delay(50);
         delay(50);
        J 1 Reply Last reply
        • T
          treb0r
          @jribera Your sketch works perfectly :)
          I am trying to add also 433 receiver to allow domoticz update states of the switches is the Socket is switched on or off by remote control. Does anybody know how to do that? After receiving certain code change the state of the corresponding socket.
          treb0r
          P 1 Reply Last reply
          • T treb0r
            treb0r
            P
            P
            Pendragon
            treb0r
            Im an just trying to do this (also with domoticz) ;)
            Here is my first try of the function using RCSwitch.h:
            * Analyse the Radio traffic and set the states
            void readRadio()
            	if (mySwitch.available())
            		int value = mySwitch.getReceivedValue();
            		if (value == 0)
            			#ifdef DEBUG
            			Serial.print("Unknown encoding");
            		else
            			led(false,4,150);
            			#ifdef DEBUG
            			Serial.print("Received ");
            			Serial.print( mySwitch.getReceivedValue() );
            			Serial.print(" / ");
            			Serial.print( mySwitch.getReceivedBitlength() );
            			Serial.print("bit ");
            			Serial.print("Protocol: ");
            			Serial.println( mySwitch.getReceivedProtocol() );
            			if (value == 4373) //Stehlampe ON
            				#ifdef DEBUG
            				Serial.println("Stehlampe ON detected");
            			else if (value == 4372 ) //Stehlampe OFF
            				#ifdef DEBUG
            				Serial.println("Stehlampe OFF detected");
            				resend((msgLight1.set(0)),m_repeat);
            			else if (value == 1048597 ) //Vitrine ON
            				#ifdef DEBUG
            				Serial.println("Vitrine ON detected");
            				resend((msgLight2.set(1)),m_repeat);
            			else if (value == 1048596 ) //Vitrine OFF
            				#ifdef DEBUG
            				Serial.println("Vitrine OFF detected");
            				resend((msgLight2.set(0)),m_repeat);
            			mySwitch.resetAvailable();
            • J jribera
                  Submitted by Dwalt.
              #include <RF24.h>
              //  Define Constants
                gw.process();
                  // Turn on  socket 1
               delay(50);
              delay(50);
                  // Turn on  socket 2
               delay(50);
              delay(50);
                  // Turn on  socket 3
               delay(50);
              delay(50);
                  // Turn on  socket 4
               delay(50);
              delay(50);
               delay(50);
              J
              J
              justinthegeek
              @jribera What version of mysensors was this coded for? I'm having issues building this on 1.4 for some reason.
              • J justinthegeek
                J
                J
                jribera
                @justinthegeek
                Also 1.4
