  3. [SOLVED] Not working: Distance Sensor connected to Arduino Uno with NRF24L01+ and adapter
7 Posts 3 Posters 2.7k Views 3 Watching
  • ArthurA
    ArthurA
    Arthur
    I am trying to get my 1st sensor board working, but stil no luck.
    What I have done:
    1. installed the latest Arduino software for Windows: v1.8.3
    2. Installed mysensor library (library manager Arduino Software: v2.1.1
    3. installed https://github.com/mysensors/MySensorsArduinoExamples: copied libraries and examples to arduino folder (overwrite the original files if needed)
    4. Used hardware:
    • Arduino Uno
    • NRF24L01+ :
      https://www.tinytronics.nl/shop/nl/communicatie/rf(id)-wifi-bt/nrf24l01-wireless-module-zwart?search=nrf24l01
    • NRF24L01+ adapter:
      https://www.tinytronics.nl/shop/nl/communicatie/nrf24l01-wireless-module-adapter-board
    Hardware connections:
    => First experiment without adapter board:
    http://schullebernd.de/wp-content/uploads/2015/10/Schaltbild_nRF24L01_ArduinUNO_mit_Elko.png
    => Second experiment with adapter board as above but without condensator and board adapterboard powered with 5volt.
    Ofcourse ultrasoon sensor connected too according https://www.mysensors.org/build/distance,
    one exception: #define TRIGGER_PIN 6 changed in 3 (because pin 6 is already used by NRF24L01)
    After uploading the Distance Sensor sketch I opened the debug window which show this:
    3 TSM:INIT
    4 TSF:WUR:MS=0
    11 !TSM:INIT:TSP FAIL
    12 TSM:FAIL:CNT=1
    14 TSM:FAIL:PDT
    10016 TSM:FAIL:RE-INIT
    10018 TSM:INIT
    10024 !TSM:INIT:TSP FAIL
    10028 TSM:FAIL:CNT=2
    10029 TSM:FAIL:PDT
    I have check everything, same results in both hardware setup (with or without NRF24L01 adapter).
    Power is ok.
    I really don't know what's wrong.
    By the way: I get a lot of warnings: "Invalid version found: 1.04": this after I have uploaded the https://github.com/mysensors/MySensorsArduinoExamples files..
    I really hope somebody can help.
    Regards,
    ;-) Arthur
    YveauxY dbemowskD 2 Replies Last reply
    • ArthurA Arthur
      What I have done:
      4. Used hardware:
      • Arduino Uno
      • NRF24L01+ :
      3 TSM:INIT
      4 TSF:WUR:MS=0
      12 TSM:FAIL:CNT=1
      14 TSM:FAIL:PDT
      10018 TSM:INIT
      10029 TSM:FAIL:PDT
      Power is ok.
      Regards,
      ;-) Arthur
      YveauxY
      YveauxY
      @Arthur welcome to the mySensors forum!
      @arthur said in Not working: Distance Sensor connected to Arduino Uno with NRF24L01+ and adapter:
      Make sure no files are overwritten in the libraries/mysensors folder.
      I think you're just using the wrong connections.
      Have a look here how to connect the radio: https://www.mysensors.org/build/connect_radio
      The pinout for Uno is the same as for Promini.
      Good luck !
      • ArthurA Arthur
        What I have done:
        4. Used hardware:
        • Arduino Uno
        • NRF24L01+ :
        3 TSM:INIT
        4 TSF:WUR:MS=0
        12 TSM:FAIL:CNT=1
        14 TSM:FAIL:PDT
        10018 TSM:INIT
        10029 TSM:FAIL:PDT
        Power is ok.
        Regards,
        ;-) Arthur
        dbemowskD
        dbemowskD
        @Arthur Can you show us how you have it wired with a schematic or something?
        ArthurA 1 Reply Last reply
        • ArthurA
          ArthurA
          Arthur
          wrote on last edited by Arthur
          Hello !
          I checked everything again, deinstalled Arduino and removed the userdata too.
          • Installed arduino again.
          • Installed mysensor library (library manager Arduino Software: v2.1.1 installed * https://github.com/mysensors/MySensorsArduinoExamples: copied libraries and examples to arduino folder (but wihout any overwriting). After a new sketch upload I see now only 2 errors:
          instead if a huge list of the same errors..
          I have checked the wire connections very secure using this images:
          https://i.stack.imgur.com/wKz2l.png
          => I have used the NRF24L01+ adapter also (no condensator needed), powersupply connected to the 5Volt pin from the Arduino Uno (original from Italy, no clone).
          => I have used the Gateway serial now, no ultrasoon sensor connected.
          => No powercable connected to the Arduino, this because it's connected with an USB-cable to my laptop which runs the Aduino software.
          But when I check the debug info, I get this: :FAIL:RE-INIT
          0;255;3;0;9;TSM:INIT
          0;255;3;0;9;!TSM:INIT:TSP FAIL
          0;255;3;0;9;TSM:FAIL:CNT=3
          0;255;3;0;9;TSM:FAIL:PDT
          0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.0
          0;255;3;0;9;TSF:WUR:MS=0
          0;255;3;0;9;TSM:FAIL:CNT=1
          0;255;3;0;9;TSM:FAIL:RE-INIT
          0;255;3;0;9;TSM:FAIL:CNT=2
          What's wrong, do I made a mistake ?
          I hope somebody can help...........
          Many thanks !
          ;-) Arthur
          • dbemowskD dbemowsk
            ArthurA
            ArthurA
            Arthur
            Pro Mini / Nano NRF24L01+ adapter
            GND GND
            5V 5V
            9 CE
            10 CSN/CS
            13 SCK
            11 M0 (MOSI)
            12 M1 (MISO)
            • ArthurA
              ArthurA
              Arthur
              Shit, it works I think.
              Bad wire, I have now this output:
              0;255;3;0;9;TSM:INIT:TSP OK
              0;255;3;0;9;TSM:INIT:GW MODE
              0;255;0;0;18;2.1.0
              0;255;3;0;9;MCO:BGN:STP
              Thanks !
              ;-) Arthur
              YveauxY 1 Reply Last reply
              • ArthurA Arthur
                0;255;0;0;18;2.1.0
                Thanks !
                ;-) Arthur
                YveauxY
                YveauxY
                @Arthur good to hear!
