  3. Help needed for verifying code
2 Posts 2 Posters 984 Views 2 Watching
  • A Offline
    A Offline
    abhisuma
    I have created a program with arduino uno for controlling humidity in my mushroom grow room.
    There are two rooms and i am trying to control humidity of each room with one pressure pump , two solenoid valves and relays. I am trying to keep the humidity range in each room in between 75 - 88.
    As per my planning if the humidity in one room is below 75 the relays connected to pressure pump and solenoid valve for that particular room to be turned on and would be turned off on exceeding 88,and the same procedure for the other room.I have created code for this and as i am beginner i think it is better to present the code to the experienced guys before testing ,pls check my codes and help to rectify any problems.
    Insert Code Here#include <dht.h>
    dht DHT;
    #define DHT1_PIN 2
    #define DHT2_PIN 4
    #define DHT1TYPE DHT11
    #define DHT2TYPE DHT11
    int pumppin =7;
    int solenoidpin =8;
    int valvepin =12;
    void setup(){
      pinMode(pumppin, OUTPUT);
      pinMode(solenoidpin, OUTPUT);
      pinMode(valvepin, OUTPUT);
      int chk =DHT.read11(DHT1_PIN);
      if (DHT.humidity <75) {
        if (digitalRead(pumppin == HIGH)){
          digitalWrite(solenoidpin, HIGH);
        }else{
          digitalWrite(pumppin, HIGH);
      if (DHT.humidity >88) {
      digitalWrite(pumppin, LOW);
          digitalWrite(solenoidpin, LOW);
        delay(5000);
        int chk2 =DHT.read11(DHT2_PIN);
          digitalWrite(valvepin, HIGH);
        }else{
          digitalWrite(valvepin, LOW);
        delay(5000);
      I think you need to check the examples on hot to use dht sensors because I'm not sure if you can instantiate only one dht object if you have 2 sensors.
      In addition I'd use more reliable sensors than DHT like sht31 or si7021.
