  2. Bug Reports
  3. RFM69CW Gateway and Nodes are not working with Api newer then 2.0.0
betarfm69cwbug2.1.12.0.0gateway not responding
57 Posts 6 Posters 17.7k Views 3 Watching
  • F Floca
    i cant declare
    #define MY_RFM69_IRQ_NUM
    Is that ok for the Gateway?
    @Floca what happens if you declare it?
    • F
      F
      Floca
      wrote on last edited by Floca
      #42
      It is grey, uploads it and same thing as before.
      Sensor cant get the gateway, gateway stops at "pm open,type:2 0".
      Don't know where the problem is :/0_1500825666558_Unbennt.jpg
      • F Floca
        @Floca seems like MY_RF69_IRQ_NUM is important. If I do this
        //#define MY_RF69_IRQ_NUM MY_RF69_IRQ_PIN
        my gateway stops at
        0;255;3;0;9;6624 MCO:BGN:STP
        0;255;3;0;9;6675 MCO:BGN:INIT OK,TSP=1
        pm open,type:2 0
        and never receives any messages. I even had to restart the node after a flashed the gateway with IRQ_NUM defined. Before I restarted the node it wasn't able to get the transport up and running again, showing repeated !TSF:SND:TNR.
        • F
          F
          Floca
          seems that this is the problem...
          When it is gray, the define is not found, am i right?
          What would you think? Arduino IDE reinstalling or what could be the problem?
          • F Floca
            @Floca gray or not is just syntax highliting. It does not affect the compiled code. This is what mine looks like:
            0_1500828198558_upload-5137e11f-7ff3-409b-b5ba-d998f24bd8f8
            But what you did before, with setting both to D2, should work. Could you try that again, and reset the temperature node after you have uploaded the new sketch to the gateway?
            • F
              F
              Floca
              Ok, i delete the eeprom from both, gateway and node and flash the old scripts with additional definiton of Num IRQ for the gateway?
              • F Floca
                #47
                @Floca That there should be no need to clear the eeproms, and no need to re-flash the temperature node. Just flash the gateway with the IRQ_NUM set and restart the temperature node.
                  My node and gw have been working throughout the night.
                  • F
                    F
                    Floca
                    #49
                    I have No Reply, don't know what i do wrong :(
                     * Version 1.0 - Henrik EKblad
                     * Contribution by tekka,
                     * Contribution by Ivo Pullens (ESP8266 support)
                     * The EthernetGateway sends data received from sensors to the WiFi link.
                     * VERA CONFIGURATION:
                     * Enter "ip-number:port" in the ip-field of the Arduino GW device. This will temporarily override any serial configuration for the Vera plugin.
                     * E.g. If you want to use the defualt values in this sketch enter: 192.168.178.66:5003
                     * LED purposes:
                     * nRF24L01+  ESP8266
                     * VCC        VCC
                     * CE         GPIO4
                     * CSN/CS     GPIO15
                     * SCK        GPIO14
                     * MISO       GPIO12
                     * MOSI       GPIO13
                     * GND        GND
                      * Inclusion mode button:
                    #include <ArduinoOTA.h>
                    #define MY_BAUD_RATE 9600
                    #define MY_RADIO_RFM69
                    #define MY_RFM69_IRQ_NUM D2
                    #define MY_RFM69_IRQ_PIN D2
                    #define MY_RFM69_CS_PIN D8
                    #define MY_RFM69_FREQUENCY RFM69_433MHZ
                    #define MY_GATEWAY_ESP8266
                    #define MY_ESP8266_SSID "N3tw0rk.NET"
                    #define MY_ESP8266_PASSWORD "123456"
                    #define MY_ESP8266_HOSTNAME "RFM69-Gateway"
                    // Enable UDP communication
                    //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below
                    #define MY_PORT 5003
                    // Enable inclusion mode
                    // #define MY_INCLUSION_BUTTON_FEATURE
                    // Set blinking period
                    // #define MY_DEFAULT_LED_BLINK_PERIOD 300
                    // Flash leds on rx/tx/err
                    // Led pins used if blinking feature is enabled above
                    #if defined(MY_USE_UDP)
                    #include <WiFiUDP.h>
                    #else
                    #include <ESP8266WiFi.h>
                    	ArduinoOTA.onStart([]() {
                    		debug("ArduinoOTA start\n");
                    	ArduinoOTA.onEnd([]() {
                    		debug("\nArduinoOTA end\n");
                      ArduinoOTA.setPassword((const char *)"123");
                    	ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
                    		debug("OTA Progress: %u%%\r", (progress / (total / 100)));
                    	ArduinoOTA.onError([](ota_error_t error) {
                    		debug("Error[%u]: ", error);
                    		if (error == OTA_AUTH_ERROR) {
                    			debug("Auth Failed\n");
                    		} else if (error == OTA_BEGIN_ERROR) {
                    			debug("Begin Failed\n");
                    		} else if (error == OTA_CONNECT_ERROR) {
                    			debug("Connect Failed\n");
                    		} else if (error == OTA_RECEIVE_ERROR) {
                    			debug("Receive Failed\n");
                    		} else if (error == OTA_END_ERROR) {
                    			debug("End Failed\n");
                    	ArduinoOTA.begin();
                      // Send locally attech sensors data here
                    	ArduinoOTA.handle();
                    • F
                      F
                      Floca
                      Wich Arduino IDE Version are you using? (Last Idea)
                      • F Floca
                        @Floca good idea! I'm using 1.6.8 (haven't gotten around to upgrading in a while)
                        • F
                          F
                          Floca
                          dont know, it is not working anyway
                          • F
                            F
                            Floca
                            is there a chance to get your library Folder?
                            • F Floca
                              @Floca sure. I'm abroad now but I can zip it up when I am back home.
                              F 1 Reply Last reply
                                F
                                F
                                Floca
                                @mfalkvidd That would be great!
                                Your test Module for the Gateway was an Wemos, an NodeMcu or something else?
                                regards
                                • F Floca
                                  regards
                                  @Floca I verified both nodemcu and wemos d1 mini
                                  • archiijsA
                                    archiijsA
                                    archiijs
                                    Hi, not sure if @Floca get his nodes working, but for me, the problem got fixed with this
                                    as mentioned by @mfalkvidd Thanks!
