  3. OpenHAB
  4. openHAB 2.2 binding
openHAB 2.2 binding
132 Posts 32 Posters 89.6k Views 34 Watching
  • L LastSamurai
    @gonzalonal said in openHAB 2.2 binding:
    Yes, sure. I'll do that to keep track.
    By the way, I have RGBW led strip and I am using it with mysensors with no issues. Would you mind telling me what's wrong so I can recreate the scenario?
    You can find the issues here. Basically you (I ;)) can't set RGBW nodes to display pure white colors via openhab, dimming is not working (error confirmed by TimO) and most importantly ACK isn't working properly (for me at least). If you can help with any of this (especially the conversion HSB <=> RGBW) you are most welcome.
    G
    G
    gonzalonal
    wrote on last edited by gonzalonal
    #61
    Please kindly check my contribution in the git issue. Maybe it will help to clarify your issues.
    @LastSamurai said in openHAB 2.2 binding:
    • L
      L
      LastSamurai
      @gonzalonal I saw it earlier but did not understand it fully. I will take another look at it later.
      @TimO I might have found the error... maybe. I reflashed the motion sensor (with cleared eeprom before) and removed the static id and signing. Now I see that the problem seems to be that the node is unable to get an ID. Any idea what's happening herer? Is there a setting concerning that somewhere?
      Log from the node:
      102477 TSM:FAIL:RE-INIT
      102479 TSM:INIT
      102488 TSM:INIT:TSP OK
      102490 TSM:FPAR
      102492 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      103426 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
      103432 TSF:MSG:FPAR OK,ID=0,D=1
      104501 TSM:FPAR:OK
      104503 TSM:ID
      104503 TSM:ID:REQ
      104507 TSF:MSG:SEND,255-255-0-0,s=55,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      106516 TSM:ID
      106516 TSM:ID:REQ
      106520 TSF:MSG:SEND,255-255-0-0,s=20,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      108529 TSM:ID
      108529 TSM:ID:REQ
      108533 TSF:MSG:SEND,255-255-0-0,s=241,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      110542 TSM:ID
      110542 TSM:ID:REQ
      110546 TSF:MSG:SEND,255-255-0-0,s=206,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      112556 !TSM:ID:FAIL
      112558 TSM:FAIL:CNT=6
      112560 TSM:FAIL:DIS
      112562 TSF:TDI:TSL
      Log from the openhab server:
      15:21:32.127 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 255;34;3;0;3;
      15:21:34.135 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 255;0;3;0;3;
      15:21:36.147 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 255;221;3;0;3;
      and lots more similar requests with different ids.
      T 1 Reply Last reply
      • L LastSamurai
        Log from the node:
        102479 TSM:INIT
        102490 TSM:FPAR
        104501 TSM:FPAR:OK
        104503 TSM:ID
        104503 TSM:ID:REQ
        106516 TSM:ID
        106516 TSM:ID:REQ
        108529 TSM:ID
        108529 TSM:ID:REQ
        110542 TSM:ID
        110542 TSM:ID:REQ
        112556 !TSM:ID:FAIL
        112560 TSM:FAIL:DIS
        112562 TSF:TDI:TSL
        TimO
        @LastSamurai Upgrade the binding. You're using the current beta of MySensors and the request for I'd has changed.
        L 1 Reply Last reply
        • T TimO
          L
          L
          LastSamurai
          @TimO Ahh thank you! I am using version 2.2 linked in the first post of this thread though. Where do I get a newer version? Maybe I overlooked it but I am not seeing any newer releases.
          • L LastSamurai
            TimO
            @LastSamurai just replace the jar from the link above. I'm doing small changes from time to time.
            • T TimO
              L
              L
              LastSamurai
              @TimO Thank you again for the help. Everything is now back up and running :+1: With the new jar my node could finally get a new id and after also enabling signing again everything worked as expected.
              Can I see anywhere that you updated the jar file? I am using the current beta of mysensors mostly so I would also need to use an updated version of the openhab plugin.
              • N
                N
                Nicklas Starkel
                @TimO , is this binding supported via mysensors MQTT gateway?
                In previous bending inormation you had some text indicating that you would implement it. But all that is gone.
                So I'm thinking you either implemented it, or aborted that feature :)
                • N Nicklas Starkel
                  TimO
                  @Nicklas-Starkel It happens, that MQTT support is sadly still on the to do list. There were some changes in the Smarthome MQTT library and we need to adopt them now.
                  Here's the Issue: https://github.com/tobof/openhab2-addons/issues/98
                  N 1 Reply Last reply
                  • T TimO
                    N
                    N
                    Nicklas Starkel
                    @TimO, cool that you are stil on it, even if it's on the "todo-list".
                    Kudos and keep up the great work :)
                    • gahlawathomeG
                      gahlawathomeG
                      gahlawathome
                      @TimO
                      Can we use this binding for MQTT once the PR is available in OpenHAB?
                      It is a separate mqtt generic binding in ESH for things discovery but I cannot make out if this will solve the dependency issue or not.
                      https://github.com/eclipse/smarthome/pull/3876
                      • L
                        L
                        LastSamurai
                        @TimO My sketches are sending the nodes remaining battery power to the controller via a V_VOLTAGE. Openhab 2 with your binding doesn't seem to be able to read these values. Is this an error (possibly on my side) or does the not yet support this?
                        • L LastSamurai
                          TimO
                          @LastSamurai Did you connect a channel / item for V_VOLTAGE? If the sensor is not represented by the sketch you need to connect it manually.
                          • gahlawathomeG gahlawathome
                            @TimO
                            TimO
                            @gahlawathome I'm currently looking into the new MQTT implementation in smartphone. It should work without the PR above. The PR will bring us a new option to connect a MQTT binding with OpenHAB!
                            • T TimO
                              L
                              L
                              LastSamurai
                              wrote on last edited by LastSamurai
                              #74
                              @TimO I am not sure what you mean.
                              My sketch sends a presentation:
                               present(CHILD_ID_BATTERY, S_MULTIMETER);
                              and in openhab I added these (tried both sensor kinds)
                              // things
                              customSensor abc [nodeId=26, childId=1]
                              multimeter def [nodeId=17, childId=1]
                              // and items
                              Number 	voltageSensorWZ ... { channel="mysensors:multimeter:gwSerial:def:volt" }
                              Is there anything i am missing here?
                              • L LastSamurai
                                // things
                                // and items
                                TimO
                                @LastSamurai
                                The channel is not correct:
                                channel="mysensors:multimeter:gwSerial:voltageSensorWZ:volt"
                                It's confusing, but that's the way OpenHAB2 handles channels. :confused:
                                • T TimO
                                  @LastSamurai
                                  L
                                  L
                                  LastSamurai
                                  #76
                                  @TimO Thanks for your help though I am afraid you mixed something up there. The channel linking to the item itself doesn't really make sense ;)
                                  Not 100% sure why it did not work earlier for me but I now got it to work like this:
                                  // thing
                                  multimeter		voltTHWohnzimmer	[nodeId=1, childId=2]
                                  // item
                                  Number 	voltageSensorWZ 		"Spannung [%3f mV]" 		<poweroutlet_eu> 	(grVolt, grWZ)	{ channel="mysensors:multimeter:gwSerial:voltTHWohnzimmer:volt" }
                                  My error in the code above seems to have been that I defined most as customSensor instead of multimeter.
                                  • gerritvG
                                    gerritvG
                                    gerritv
                                    @TimO said in openHAB 2.2 binding:
                                    @LastSamurai
                                    Is the pattern:
                                    <binding name>:<mysensors type>:<gateway id>:<thing name>:<data name> ?
                                    • gerritvG
                                      gerritvG
                                      gerritv
                                      wrote on last edited by gerritv
                                      #78
                                      Just to let you know that I am very happy with this binding.
                                      One thing for others to be aware of:
                                      If you use PaperUI for configuring etc, make sure you leave Simple Mode off if you expect to use Groups later on. Simple mode adds the items (including the VAR1-5 :-() automatically but they are not 'managed'. This means you will get 404 and 405 errors on trying to edit them later on.
                                      My solution was to let the binding autodiscover and add the Things. Then add 1 Item manually so that the \\192.168.0.123\openHAB-share\openhab2-userdata\jsondb\org.eclipse.smarthome.core.items.Item.json
                                      file gets created and filled with an example to clone. I then added the various sensors using Name of pattern <binding name><sensorname><nodeid>_<dataname>, e.g. "mysensors_light_level_node4_last_update": { "class": "org.eclipse.smarthome.core.items.ManagedItemProvider$PersistedItem", "value": { "groupNames": [ "gLastUpdated" ], "itemType": "DateTime", "tags": [], "label": "Last", "category": "calendar" } },
                                      You must stop Openhab before editing the file (else you will lose your edits) but once it starts up again you will see the Items listed in PaperUI (and VSCode if you use that). You can then add the Channel/Item links for each Thing.
                                      • F
                                        F
                                        fredswed
                                        Thanks for some great work @TimO ! Version 2.2 now works smoothly with my simple OpenHAB setup (2.2 snapshot).
                                        One thing I noticed is that the gateway thing configuration page says "Disable network sanity check" even though the logic has been reversed in v2.2.
                                        So the UI needs to be similarly changed to "Enable startup check" instead.
                                        While I'm at it, could you please also clarify (in the UI) what "Send delay" is? Please also add that timing is in ms. If I understand things correctly it could say "Minimum time between messages sent to the gateway (ms)"
                                        Also, the comment for "Imperial/Metric selection" could use some clarification. Preferably change the label to "Imperial units" and the explanation to "Use imperial units (default is metric)."
                                        And finally it would be great to add add that the time is given in "...(minutes)" for the Network sanity check interval.
                                        • L
                                          L
                                          LastSamurai
                                          I have just updated to the stable openHAB 2.2 Version and everything seemed to be working just fine in the beginning but after the next restart I got this error:
                                          10:31:19.727 [WARN ] [fig.xml.osgi.XmlDocumentBundleTracker] - The XML document '/ESH-INF/binding/binding.xml' in module 'org.openhab.binding.mysensors' could not be parsed: The XmlConfigDescriptionProvider must not be null!
                                          It seems like I can still control my devices just fine but I just wanted to make sure that this doesn't cause errors down the line. So @TimO any idea where this error is coming from?
