  3. irq pin for nrf24l01
14 Posts 5 Posters 6.5k Views 6 Watching
  • rozpruwaczR
    rozpruwaczR
    rozpruwacz
    Hi all,
    I wonder what is the story with the irq pin. In the MyConfig.h there is a MY_RX_MESSAGE_BUFFER_FEATURE option which states that for nrf MY_RF24_IRQ_PIN must be defined and as I understand the irq pin will be used. if MY_RX_MESSAGE_BUFFER_FEATURE is not defined the irq pin is not used ? On the other hand in the "Connecting Radio" section of the tutorial there is this: "The IRQ is currently not used by the MySensors library so it can be left un-connected" so is it used or not ? and what is the MY_RX_MESSAGE_BUFFER_FEATURE ?
    • rozpruwaczR
      rozpruwaczR
      rozpruwacz
      anybody hear me ? please help ! :)
        If you use the MY_RX_MESSAGE_BUFFER_FEATURE, you must connect the IRQ pin. Otherwise it's not needed.
        I'll update the documentation.
        • rozpruwaczR
          rozpruwaczR
          rozpruwacz
          ok, thanks. What MY_RX_MESSAGE_BUFFER_FEATURE actually do ? what are the cons nad pros in the context of the repeater node ?
          YveauxY 1 Reply Last reply
          • rozpruwaczR rozpruwacz
            YveauxY
            YveauxY
            @rozpruwacz said in irq pin for nrf24l01:
            What MY_RX_MESSAGE_BUFFER_FEATURE actually do?
            The nrf24 radios can only buffer 3 incoming messages at most, if more come in they will be lost.
            For repeaters and gateway (basically non-sleeping sensors) this feature enables immediate retrieval of incoming messages and buffering in internal ram. For crowded networks, or sensors which send a lot of data at once, this feature reduces packet loss.
            Drawbacks are the increased use of ram (amount of messages buffered can be configured) and the nrf irq has to be connected.
              Ok, updated doc. @Yveaux, feel free to update the text I wrote.
              • rozpruwaczR
                rozpruwaczR
                rozpruwacz
                @Yveaux said in irq pin for nrf24l01:
                thanks ! so i guess it is better to use that buffer in my repeater node.
                  rozpruwaczR
                  rozpruwaczR
                  rozpruwacz
                  @hek said in irq pin for nrf24l01:
                  "NRF24L01+ & ESP8266" section should be also updated ?
                    YveauxY
                    YveauxY
                    @rozpruwacz beware that it hasn't been tested extensively. I've using it on avr for a long time though.
                    • rozpruwaczR
                      rozpruwaczR
                      rozpruwacz
                      understand, but now i'm designing the device which hopefully will run for couple of years, so sooner or later this irq pin wiil be necessary.
                      • Z
                        Z
                        zen85
                        so if i use an esp8266 as gateway AND i want to use the bufferfeature - to which pin do i have to actually connect the irq on the esp8266? The documentation is not helping me here.
                        • Z zen85
                          YveauxY
                          YveauxY
                          @zen85 said in irq pin for nrf24l01:
                          ESP8266 does not support message queuing, sorry.
                          Z 1 Reply Last reply
                          • YveauxY Yveaux
                            Z
                            Z
                            zen85
                            @yveaux
                            thx.
                            would this feature work on a esp32 gw then?
                            • Z zen85
                              @yveaux
                              thx.
                              @zen85 unfortunately not.
                              See https://www.mysensors.org/apidocs-beta/group__RF24SettingGrpPub.html#ga6b3dbadceeb1dfca62b2e920d926bd4a for details (MY_RX_MESSAGE_BUFFER_FEATURE section)
